TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Apr 13, 2018 at 9:14 PM
    #3021
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    Today's episode is replaying on A&E right now.
    Think of COPS on steroids.
    Roostfactor likes this.
  2. Apr 13, 2018 at 9:16 PM
    #3022
    Biscuits
    It's unfortunate that the Arizona State Troopers declined contract renewal with Live PD. I really liked several of the Troopers.
  3. Apr 13, 2018 at 9:20 PM
    #3023
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    I didnt know that happened. Bummer now I cant see tweakers down the street
    Roostfactor and Biscuits[QUOTED] like this.
  4. Apr 13, 2018 at 9:31 PM
    #3024
    ThomasMore66
    Dallas/Fort Worth & Durango
    Meh. All those shows are fake news.
    12TRDTacoma[OP] likes this.
  5. Apr 13, 2018 at 9:55 PM
    #3025
    TacoTuesday94
    TacoTuesday94 Well-Known Member
    Ry
    Huntington Beach CA
    Supercharged 4.0 2010
    Per request I'm reposting this here. Any suggestions or corrections welcome.
    I searched many different forums and spent a couple hours trying to figure out which belt I should get, what size belt, how to do the swap, blah, blah, blah. The point is, I am sharing the fruits of my labor with you!
    This is for the TRD/Magnuson supercharger for the 4.0L V6 Tacoma 2005-15.
    Belt Needed:
    70.5 in, 5 rib
    Possible Belts you could use:
    -Goodyear gatorback got re branded to Continental elite. part # 4050705
    -Dayco Poly Rib belt, Premium Part # 5050705
    -Gates Micro V Part # K050705/5PK1793
    -Toyota Part# PTR30-35040
    Personal Experience:
    -I have been running a Gates micro V for the past 5K miles or so. Tons of cracks, did not hold up well. Switching to Continental Elite soon.
    -I haven't done the swap yet, but since the dealership is trying to charge me $180 for a simple swap; I will be soon.
    -I would also recommend treating your new belt with some kind of rubber protectant before hand.
    Install How To:
    Video shows belt swap after pulley swap.
    In case the clickable link doesn't work https://youtu.be/gSrhiG-cKo8?t=5m54s
    This video says it's a 12mm nut, but going over the manual it seem this is not the case. For those of you who have done this before. What size are the nuts?
    Steps:
    1)Remove skid plate to access tensioner from underside. All access will be through the underside and potentially the drivers side wheel well.
    2)Loosen tensioner (1/2 in square drive) and remove belt from pulley located on supercharger (will probably need a friend or loved one for this part)
    3)Remove the 2 M8 (per manual) bolts from the tensioner support bracket (this piece is mounted on the inside diameter of the belt, one bolt is on the tensioner, the other is on the ac compressor)
    4)Remove the tensioner bracket (2 M10 bolts per manual)and remove old belt.
    5)Slide New belt in from top, place in upper pulleys
    6)Reroute belt down through engine
    7)Reinstall tensioner assembly (torque 2 M10 nuts to 29ft lbf)
    8)Reinstall support bracket (torque tensioner nut first, then acc nut to 19ft lbf)
    9)Make sure belt is routed correctly.
    10)Loosen tensioner and place belt on tensioner pulley
    11)Put skid plate back on
  6. Apr 13, 2018 at 10:20 PM
    #3026
    GT7
    Grant
    Phoenix
    2013 DCLB
    I use a 69.5 inch belt. Which can be found in this thread. I also access the tensioner from the top. No assembly/ disassembly required
  7. Apr 13, 2018 at 10:21 PM
    #3027
    StOrMyThEtAcO
    StOrMyThEtAcO @stormythetaco
    Cody
    CO
    18 TRD Sport mom bus
    All of them
    This is why the 4runners (I can only speak for the Offroad model) is so much nicer than the tacomas... They are still built in Japan an sent here
  8. Apr 13, 2018 at 10:30 PM
    #3028
    TacoTuesday94
    Ry
    Huntington Beach CA
    How do yo manage that? The tensioner support bracket runs right through the middle of the belt?
  9. Apr 13, 2018 at 10:31 PM
    #3029
    GT7
    Grant
    Phoenix
    2013 DCLB
    Breaker bar? I use a 1/2 breaker bar. Pops right in the tensioner.
  10. Apr 13, 2018 at 10:33 PM
    #3030
    TacoTuesday94
    Ry
    Huntington Beach CA
    So you do still take that off. You just use a long ass wrench is what you're saying. I'm talking about the bracket that goes from the tensioner to the ac compressor.
  11. Apr 13, 2018 at 10:35 PM
    #3031
    GT7
    Grant
    Phoenix
    2013 DCLB
    I dont take anything off. No socket, just the wrench. Pop it in, release tension, remover belt and install new one. I left my steel skid on. Just reached up through and got the belt lined up.
  12. Apr 13, 2018 at 10:43 PM
    #3032
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    There is a bracket that is installed as he stated. It does make it a pita to change the belt. Maybe it's not needed and why you dont have yours installed. Maybe I should remove mine in case I need to change my belt in the middle of nowhere.
  13. Apr 13, 2018 at 10:49 PM
    #3033
    Konvict KROG
    Konvict KROG Live Free or Die Trying
    Louisiana
    Old Toyota's, Power Wagon, and a Tacoma
    Traded the 2015 TRD Pro 6spd Supercharged on a PowerWagon and could not be happier. My 2011 Tacoma with the TX Baja package (Added by me) is still treating me great. My 1985 Toyota never skips a beat.
    And why the have less problems.
  14. Apr 13, 2018 at 11:00 PM
    #3034
    TacoTuesday94
    Ry
    Huntington Beach CA
    You know what, it just occurred to me that you could easily swap the belt without removing the whole tensioner assembly. Just that little bracket. Damn.
  15. Apr 13, 2018 at 11:07 PM
    #3035
    Roostfactor
    TX panhandle
    Exactly! The bracket is the only thing making the belt change problematic.
  16. Apr 13, 2018 at 11:18 PM
    #3036
    TacoTuesday94
    Ry
    Huntington Beach CA
    Actually hold up. I'm getting confused. I think the bracket only runs through the main serpentine belt. Not the supercharger belt. SO you don't even need to remove the bracket, like GT7 said. you would just have to feed the belt in between the tensioner and the idler pulley. Then you could route it around the crank and the lowest idler pulley. I think .
  17. Apr 13, 2018 at 11:45 PM
    #3037
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    I totally agree with you. Japan still has very high work control standards.
    Similar to TBI. It's effective and it is a very simple design. Of course don't talk to GM about their longevity.
    I wish it was that easy. The entire tensioner assembly has to be removed. No other way around it.
    This ^^
    Yeah no I have analyzed it. It HAS to come off to change the belt. A redesign would be cool and very time saving for swapping belts.
  18. Apr 14, 2018 at 1:03 AM
    #3038
    Konvict KROG
    Louisiana
    My belt is 2 years old lol.
    Probably ready for a change.
    Doing some window shopping here..
    Glow shift 10 color black
    -dual intake temp (like the before/after charge cooler as above)
    -digital boost/vacuum (but i like the 15 psi analog, just picked it for a match)
    -ambient air (2015 yo)
    Glow shift 7 color
    -water temp (toyota gauge is grey area)
    -oil (curious, probably use a sandwich plate)
    Innovative
    -3891 aka DLG1
    Snow performance
    -212 w 2.5 gallon (recommended above)
    You Arrre Deeee
    -spec U headers
    -y pipe
    -fuel pump kit w AEM 320
    -o2 sim
    -suregrip 2.8, yeah I really want that quick change but I just can't cut my snout just yet.
    With the snow kit, how do you think buying a throttle body spacer, and drilling the nozzle into it.. that puts me right after the TB plate before the blower and keeps me from drilling in the blower, other than the cooler lid for temp sensors.
    Also, for gauges I am thinking boost/afr over wheel (cant think of the brand for that mount)
    Oil and water temp in front of the shifter
    Ambient and intake air at the useless sunglasses cubby
    I already have a RX75 plus pro in the upper left. And a cobra dash cam near the mirror, and hopkins insight progressive brake ratio monitor in bottom corner near A pillar, manual trigger near shifter.
    Already have the TRD catback stockn stock air box, no intent to change it currently
    Any thoughts? Or experiences? I have never bought or used glow shift. I did not like thier dual afr kit, it said it only reads up/down to 10:1
  19. Apr 14, 2018 at 4:01 AM
    #3039
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Consult gadget about the 02sim.
    It doesnt work well with certain years.
  20. Apr 14, 2018 at 4:40 AM
    #3040
    Konvict KROG
    Louisiana
    Interesting!
    I surely will, thanks for the heads up! I wonder why.
