TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jul 24, 2020 at 7:43 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    The cap Kelby put on mine was INCREDIBLY tight. Like tighter than it needs to be but I still managed to make it fit after pulling it off. Unfortunately the nipple that protrudes out from the side is one of those in between sizes so you will either be too loose or too tight. There is no in between.
    BassAckwards and nudavinci64 like this.
  2. Jul 24, 2020 at 7:59 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    too tight... too loose. first boost problems.
  3. Jul 24, 2020 at 8:30 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I prefer it to be too tight over too loose, but then again that nipple is just there to act as an overflow. Sort of like the radiator how it has an overflow for a reservoir.
    henryp likes this.
  4. Jul 24, 2020 at 8:41 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Hey does the lotec gauge pod work for 09 and up w/the air bags?
    Also I was thinking of cerakoting or powder coating my coolant can. Most likely something close to swb.
  5. Jul 24, 2020 at 9:13 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I have it in my 12. So.. yes.
    Norton likes this.
  6. Jul 24, 2020 at 9:22 PM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Mine works just fine. Just have to Dremmel the holes out a tad
    Norton and 12TRDTacoma[OP] like this.
  7. Jul 24, 2020 at 9:49 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Same I have it in my 13'
  8. Jul 24, 2020 at 10:25 PM
    nudavinci64
    Robert
    I read up on some of the other threads but from my boosted folks. Considering the Toyota WS Trans fluid is not the greatest with heat. What do folks recommend? I see Valvoline MaxLife come up a lot. I also live down the street from an Amsoil dealer. Considering my last trip with trans temps I would like to give it some extra treatment when I swap out the fluid.
    would a drain and fill with a new kind work or would I need to have someone do a full flush before the fill? Also thinking I will try to do the valve body job at the same time.
  9. Jul 24, 2020 at 10:51 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Well here is the thing Rob, if you are going to pull the valve body out you are automatically going to lose 9.5 quarts easily on a truck which has a 11 quart capacity tranny. If you are looking at fully changing fluid brands right now is the greatest time to do it more than ever because it will give you a chance to really start out clean. After you drive maybe 3-500 miles do a quick drain and fill to lose the rest of what old stuff you had in there and you should be back in business no problem.
  10. Jul 24, 2020 at 10:55 PM
    nudavinci64
    Robert
    Exactly what I was thinking. Since I will pretty much empty it any other stuff to consider if I go with non Toyota fluid? I was thinking going with some Amsoil since its close by and great heat properties.
  11. Jul 24, 2020 at 10:57 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Maxxlife or Amsoil is great. I use maxxlife.
    Norton likes this.
  12. Jul 24, 2020 at 11:03 PM
    nudavinci64
    Robert
    Great thats what I have been hearing. I see a ton of folks using Maxxlife. Amsoil is close and I know its good shite.
    Norton likes this.
  13. Jul 24, 2020 at 11:20 PM
    Lucario Runner
    Robert
    06 Toyota 4Runner
  14. Jul 25, 2020 at 9:33 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    +1. As @JuanitoBunito said, some minor adaptation is probably required and the fit ends up being ~90%, which was good enough for me too.
    +1 for Amsoil. While we have no A/T vehicles, my GT500 and C7Z both require ATF in their Tremec 6MT and 7MT, respectively. Changing from OEM to Amsoil improved shifting in both cars. It's not scientific, but I believe that indicates better lubrication.
  15. Jul 25, 2020 at 10:12 AM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Ok who here can give me tips on removing this god forsaken belt. Well I have it loose but it appears the tensioner has to come out. Is it just the two 14mm bolts holding it in? Who ever put them on last tightened them down to a metric fck ton.
  16. Jul 25, 2020 at 10:21 AM
    henryp
    henryp A member of TW
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    Consider removing the wheel well liner to reach the tensioner mount bolt. Tensioner Mount has to come out
    12TRDTacoma[OP] likes this.
  17. Jul 25, 2020 at 10:23 AM
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    Is it just the 2 bolts on the ftont and one on the side that has a bracket going toward the ac compressor?
  18. Jul 25, 2020 at 10:56 AM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Yup 3. The tensioner takes some back and forth to loosen up and slide out
    lemon177, 12TRDTacoma[OP] and henryp like this.
  19. Jul 25, 2020 at 11:05 AM
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    Got the bolts out. Bow my problem is my breaker bar is stuck in the tensioner :bananadead:
    I am having a great time
    loginfailed and 3pooches like this.
  20. Jul 25, 2020 at 11:21 AM
    henryp
    Henry
    Montana
    Shoot, I had the same problem. Keep at it steady. I’ve stripped bolts before trying to hurry myself.
