TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Apr 14, 2018 at 7:26 AM
    #3041
    ThomasMore66
    Dallas/Fort Worth & Durango
    Bracket is from Cravenspeed. You’ll probably need to add a clutch to your list.
  2. Apr 14, 2018 at 9:28 AM
    #3042
    TacoTuesday94
    TacoTuesday94 Well-Known Member
    Ry
    Huntington Beach CA
    Supercharged 4.0 2010
    Is there any reason why I shouldn’t do the boost reference or bypass restrictor removal mod?
    Because I just did both this morning and now my truck drives amazingly. So what’s the catch? Why wouldn’t Magnuson do this in the first place?
  3. Apr 14, 2018 at 11:06 AM
    #3043
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Signal issue/change after a certain year.
    Ive seen the issue pop up here over the years but cant remember exact year trucks effected.
  4. Apr 14, 2018 at 11:09 AM
    #3044
    inwood customs
    Dave
    Are you doing this blind or do you have a wideband 02 setup?
    Everytime i did the boost referencing i ran STUPID rich. Like bottomed out the gauge at 10:1 and bet it was in the 9's at wot. Truck acted like it too, sluggish when the pedal was buried, but would wake up if i modulated it.
    Maggy i assume was worried about initial knock. The boost comes on faster and at part throttle when around 13 and 14:1
    Roostfactor likes this.
  5. Apr 14, 2018 at 11:10 AM
    #3045
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    I still get occasional p0420 and p0430 codes even with the ucon and Scott tweaking it multiple times.
    I had the same issue with the o2 sim when it was installed before the ucon.
  6. Apr 14, 2018 at 11:13 AM
    #3046
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    My o2 sim almost never gave me a code, and my ucon never did not even once
  7. Apr 14, 2018 at 11:13 AM
    #3047
    Roostfactor
    TX panhandle
    I still have my restrictor in. It dampens the spring force in the bypass valve. So people have had some pinging with it removed.
    Konvict KROG likes this.
  8. Apr 14, 2018 at 11:14 AM
    #3048
    Roostfactor
    TX panhandle
    Maybe one of the differences in ecu's since mine is a 15.
    Konvict KROG and inwood customs like this.
  9. Apr 14, 2018 at 11:18 AM
    #3049
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    At what rpm does pinging occur
  10. Apr 14, 2018 at 11:21 AM
    #3050
    Roostfactor
    TX panhandle
    I dont think its rpm dependent but boost dependent.
    inwood customs likes this.
  11. Apr 14, 2018 at 11:24 AM
    #3051
    jojotoo
    jojotoo Well-Known Member
    Brandon
    Socal
    2015 DCLB
    Thought I was the only one ..
  12. Apr 14, 2018 at 11:27 AM
    #3052
    GT7
    Grant
    Phoenix
    2013 DCLB
    That stinks guys
    inwood customs and Roostfactor like this.
  13. Apr 14, 2018 at 11:29 AM
    #3053
    Roostfactor
    TX panhandle
    Another 15 as well.
    inwood customs and GT7 like this.
  14. Apr 14, 2018 at 11:38 AM
    #3054
    jojotoo
    Brandon
    Socal
    2015 DCLB
    Yup .. I know of 2 others, 15’s ..
    After about 5 sessions with Scott.. pretty much gave up.
    Clear code and go about my day.
  15. Apr 14, 2018 at 11:45 AM
    #3055
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Am I correct to understand 15's and the 02 sim give codes despite tuning?
  16. Apr 14, 2018 at 11:53 AM
    #3056
    GT7
    Grant
    Phoenix
    2013 DCLB
    Finally got ovtune site to work! Im excited.
  17. Apr 14, 2018 at 11:53 AM
    #3057
    Roostfactor
    TX panhandle
    Correct. Maybe OVTune will be more sucessful.
  18. Apr 14, 2018 at 11:58 AM
    #3058
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Order 2 and I'll do your shock relocation for free :D
    Biscuits and GT7[QUOTED] like this.
  19. Apr 14, 2018 at 12:00 PM
    #3059
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Wish I could download my tune.
  20. Apr 14, 2018 at 12:06 PM
    #3060
    TacoTuesday94
    Ry
    Huntington Beach CA
    Yup, totally blind. I’m on the Magnuson 2.85 pulley tine. Should I go back to non boost reference?
