TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Aug 3, 2020 at 8:23 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    I need better reasons.
    Just tell me its a GM and it will break and thats probably enough to keep me away.
    GM cars are like prostitutes, fun to look at, but you best dare not touch. :rofl:
    rheath08 likes this.
  2. Aug 3, 2020 at 8:25 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    That's another bad place to be, but bad in all the best ways. ;) Hang around here more frequently, you'll gain some excellent knowledge here and some good laughs along the process.
    aboftofbeam[QUOTED] likes this.
  3. Aug 3, 2020 at 8:41 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    I presume you have the stock injectors for the TRD SC and they are the 455s. The reflash on your stock ECU you ran before the ucon will run the 455s no problem. So take the Ucon out and plug the harness back into the stock ECU.
  4. Aug 3, 2020 at 8:45 PM
    aboftofbeam
    aboftofbeam Well-Known Member
    Karl
    San Diego, CA
    2012 Taco Off Road DBCB
    S/C, UCON, 2.8 pulley, bedrug, Crashnburn's ultimate headlight/tailight upgrade, Moroso oil-catch can, soundproofing, speaker and H/U replacements, bed stiffeners, SHMELLFAB Sliders, ICON AAL.
    Yep, 455s are in and I still have the original injectors. The ECU is still the Non-TRD, stock flash.
  5. Aug 3, 2020 at 8:53 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    That'll give you a good baseline as to whether or not the misfire will be there but I wouldn't run it reliably with the base non TRD flash. Just as a temporary diagnose tool.
    Hit up @JustDSM to get your baseline HPT modified TRD flash tune. It's worth the effort and money involved to make the switch.
  6. Aug 3, 2020 at 9:03 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Not sure. Probably wrong, but thought he retained 4x4?
  7. Aug 3, 2020 at 9:07 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    I weigh a shit ton but I will say those tires are not helping ya. I run 315's as well and when I went non S/C from 285 on a re gear to 315 is was very noticeable. The tires are sooooooo heavy, but then again its prob a lot better than stock.
    TacoJova likes this.
  8. Aug 3, 2020 at 9:11 PM
    nudavinci64
    Robert
    If you like speedhut wait for some sales. The booster if you run an AGM is $100 or so from a company in AU or there is some diode you can add. I have the booster, along with a RedArc BDDC charger so it gets to the operating quick. Still takes a few second either way.
    Norton likes this.
  9. Aug 3, 2020 at 9:34 PM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    I mean you’ve got the Tacoma just in case the GM breaks down :anonymous:
  10. Aug 3, 2020 at 10:08 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Jesus. :laugh: You are enabling me here bro!
    Kelvin[QUOTED] likes this.
  11. Aug 3, 2020 at 10:09 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    I thought so too, but just went through his IG and I can’t seem to see front axles in the thing. Needless to say it’s a show piece that gets a few light pulls a year which is a shame.
  12. Aug 3, 2020 at 10:10 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Plus your Chevrolegs and shoebarus as back up to the backup
  13. Aug 3, 2020 at 10:31 PM
    henryp
    henryp A member of TW
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    Just get an ISF or if you wanna spend more $$ a GSF. Lexus/toyo have lots in common, won't have to get a bunch of new tools or figure out different engineering. Still same crappy aftermarket tuning support though, but not something we're not used to already.
  14. Aug 3, 2020 at 11:16 PM
    EchoLake
    EchoLake Well-Known Member
    Sacramento
    '15 MGM TRD OR AC 6MT
    Magnuson Supercharger, Speedhut AFR and Boost Gauges, TRD ECU Reflash, Factory Nav Unit, TRD Skidplate, VIP alarm, 265/75R16 Cooper Discoverer ATP, 1" KSP Spacers, hub centric (hold comments lol), TRD Pro Grill, Raptor Lights on with ignition. Upcoming - purchased, not yet installed: Body matched rear bumper (rattle can), Kicker Hideaway, JL Audio 6x9 components w/80Hz Bass Blockers, Hellwig anti-roll bar, TRD Short Shifter, Knock-off TRD Shifter (non-Qball), black throwback plates. Plans: more.
    Thanks for the advice, ordered the diode with fuse from HKB and an AGM battery. I think low voltage is the issue on warm starts, will try the diode and battery before the new O2 sensor and report back.
  15. Aug 3, 2020 at 11:18 PM
    TRON
    I remember this build and was hoping there would be an easier stock 4x4 control solution. So my question still stands. Is there really a rsgear that’s new for tacomas? Cause an LS3 T56 stock control 4x4 looking xrunner would be sweet!! :D
  16. Aug 3, 2020 at 11:41 PM
    Kelvin
    Kelvin Wheeeeee
    Can’t say no to muscle :D
    The GTO of that era we’re pretty cool too. Driven exclusively by douchebags, but still cool.
    I actually looked at prices for GSF’s. Maybe I can afford one in 3 years. Compared to that G8 though I’d bet they’re a lot more expensive to mod. There’s not enough of them out for HP Tuners to support it either.
  17. Aug 4, 2020 at 12:02 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I agree man, the GTOs we're almost douchebag exclusive cars. It was horrible. I feel like the current G8 market is relatively small and there isn't enough out there for me to justify buying one. I found one I could buy for a little under 9K but it's been through 5 owners and I don't know if I want to inherit that potential evil with that many owners in the picture.
    Then again, if I treat it like a simple car and enjoy it as such I can't be too disappointed for that price right? Especially with 300HP right out of the box with a major tuning platform for support.
  18. Aug 4, 2020 at 6:06 AM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    i believe the double roller is made in 'merica.
  19. Aug 4, 2020 at 6:10 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    is it rwd??
  20. Aug 4, 2020 at 6:45 AM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Yes
