TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Aug 16, 2020 at 12:27 PM
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    thought you need to upgrade your valve seat in the head if your running titanium valves
    Just something I remember hearing.
  2. Aug 16, 2020 at 12:31 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    Install for the URD LT headers is super strait forward. Just be sure to undo the steering linkage in order to get the drivers side to fit in.
  3. Aug 16, 2020 at 5:02 PM
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    Traditional titanium valves are relatively soft, and require special seats. The Toyota valves are a sinter/forged powdered metal matrix. They work great with with the same seats as some of the gas engines... which may also be a MMC.
    Good read on the valves https://pdfs.semanticscholar.org/a231/975e132fe9dba7e38b79fde6620ffc03a9b5.pdf
    skyking3 likes this.
  4. Aug 16, 2020 at 5:31 PM
    aboftofbeam
    aboftofbeam Well-Known Member
    Karl
    San Diego, CA
    2012 Taco Off Road DBCB
    S/C, UCON, 2.8 pulley, bedrug, Crashnburn's ultimate headlight/tailight upgrade, Moroso oil-catch can, soundproofing, speaker and H/U replacements, bed stiffeners, SHMELLFAB Sliders, ICON AAL.
    Hey guys. Looking for opinions on this or feedback from anyone with electronic or the same boost gauge. I have been questioning the way mine reads for a while but kept chasing leaks. Got my hands on a MightyVac pressure/vacuum pump to do some system testing. With nothing running other than accessory power, the needle is jumping steadily +/- 1-3 pounds.
    Was going to upload a couple seconds of video but that is kicking my ass. The gauge is an Innovate MTX-A. Is everyone else rock steady or bouncey?
  5. Aug 16, 2020 at 6:22 PM
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    Been over a year since my last power mods but the truck is still running like a screamin banshee.
    Hit the dunes and sand drags again yesterday for the annual Toyota Takeover and despite a mid-80s day with a heat-soaked blower, she performed well.
    Next mod is snow performance stage 3 water meth kit awaiting delivery. Considering stepping down to a 2.3 pulley to boost faster since the current drag strip is so short of a track and I cant hit full boost on the 2.5 pulley before the strip ends. May step up to 33s and a regear too because my 265/75/16s aired down for sand are still spinning out on launches using the rear locker and 4-hi. Need bigger tires for better traction.
  6. Aug 16, 2020 at 7:06 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Water/Meth and 2.3 all day long :thumbsup:
  7. Aug 16, 2020 at 7:40 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    :popcorn::popcorn::cheers:
  8. Aug 16, 2020 at 8:39 PM
    Bfox
    Bfox Well-Known Member
    Tacoma
    A lot of stuff
    Hey fellas, I can use some help here. I bought my truck already fitted with a super charger. It has a 3.0 pully and from what the last owner told me has a “dealership tune” after driving it from the east coast to Texas (el Paso elevation 3500ft ) the AFR is all messed up and giving me lean conditions also throwing the code for it as well. Here’s the kicker it will sit normal at 14.7 for roughly 30 mins of driving then go between 11-13.5 no matter how much/ little gas I give it. Additionally i have To smash that paddle for it go into boost range. I’ve unplugged the battery for hours already to no change, still happens.
    any ideas of what could be happening?
    is it possible that the ecu has dropped what ever tune it had?
    could that fancy new hp tuner help?
  9. Aug 16, 2020 at 9:04 PM
    nudavinci64
    Robert
    Someone here is I’ll have some knowledge and the dealer tune is likely the standard TRD tune which tends to run rich rather than lean. could have faulty valve.
    how many miles are on it?
  10. Aug 16, 2020 at 9:15 PM
    Bfox
    Tacoma
    A lot of stuff
    110k Here’s the thing though this just started after moving here. Not Sure what happened to the ecu to make this go weird. Anything you got to offer would be much appreciated, thanks .
  11. Aug 16, 2020 at 9:23 PM
    TRON
    You might want to start out with identifying exactly what code is popping up? ;)
    nudavinci64 and JacksonTacoma like this.
  12. Aug 16, 2020 at 9:33 PM
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    The term "dealership tune" one would think is the TRD tune but lean issues you are describing seem to be more in common with the Bullydog tune issues. For most, the TRD tune was overly rich, but safe and reliable. If you do have the TRD tune then I'd guess you have some other fuel-related issue and the tune or ECU itself is not the culprit.
    Do you have a TRD stamped blower or a Magnuson stamped blower?
    RyanL and henryp like this.
  13. Aug 16, 2020 at 9:49 PM
    Bfox
    Tacoma
    A lot of stuff
    I’ll have to wait for the code to pop up again, I keep clearing it.
    sc says trd on it.
    the previous owner didn’t mention bully dog, I would have taken note of that. But than again who knows.
  14. Aug 16, 2020 at 9:51 PM
    Bfox
    Tacoma
    A lot of stuff
    Also maf is clean, and fresh air filter.
  15. Aug 16, 2020 at 10:12 PM
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    TRD stamped blower means 99.9% probability its TRD tune. Have to check the calibration ID on the ECU to know for sure. And let us know the code that's popping up.
  16. Aug 16, 2020 at 10:36 PM
    TRON
    Depending on the actual code. My guess is either an exhaust leak before your wrafs or intake leak near the MAF.
    nudavinci64 likes this.
  17. Aug 17, 2020 at 7:12 AM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    There is a possibility of a fuel pump going south.
    henryp likes this.
  18. Aug 17, 2020 at 8:25 AM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    I've blinded off my fuel pump in tank pre screen....its a possibility but shouldn't really effect when boost is being seen. That sounds more like the valve on the back of the supercharger. Or a cracked vacuum line.
  19. Aug 17, 2020 at 8:51 AM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    I am curious he said his truck is going lean but his afr is at 11-13 with no boost? That would be rich, no? Unless its higher than 12 afr with boost then I understand. But it sounds like something else is wrong if it’s dumping the fuel like crazy even when not boosting.
    DocME likes this.
  20. Aug 17, 2020 at 9:10 AM
    Bfox
    Tacoma
    A lot of stuff
    Thank you everyone for your input. I think we are missing a few things here. I don’t believe it’s a leak or lack of fuel pressure because the truck will run perfectly fine at 14.7 for roughly 30-45mins then start acting weird. I’m currently out in a drive trying to get it to pop that code.
