TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Aug 26, 2020 at 5:00 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Thanks a bunch! Yeah if you have a video around somewhere I'd love to see it. I'm not gonna lie I'm a little intimidated to take apart the steering wheel and air bag stuff. I'd really like to get a good idea of what i'm in for before i tear it apart since it isnt my truck..
  2. Aug 26, 2020 at 7:04 PM
    aboftofbeam
    aboftofbeam Well-Known Member
    Karl
    San Diego, CA
    2012 Taco Off Road DBCB
    S/C, UCON, 2.8 pulley, bedrug, Crashnburn's ultimate headlight/tailight upgrade, Moroso oil-catch can, soundproofing, speaker and H/U replacements, bed stiffeners, SHMELLFAB Sliders, ICON AAL.
    I once used a piece of metal similar to a "STOP" sign to fix a rusted out floor pan :rofl:
  3. Aug 26, 2020 at 8:01 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Whats better... More filter media or more capacity for oil on a FI setup?
    Norton and BassAckwards[QUOTED] like this.
  4. Aug 26, 2020 at 8:08 PM
    TRON
    Seems like Nate took my measurements and ran with them! I’m happy these quick change hubs are lining up with everyone else. Shows how consistent TRD and magnuson have been with the blower design
  5. Aug 26, 2020 at 9:19 PM
    BassAckwards
    Definitely advantageous to have more oil, but i do think the drain back valve is important since the filter is inverted. I change the oil and filter every 3k so the amount of media is probably not gonna matter too much in the grand scheme of things, I'm more concerned about the filter having to reprime every time you crank it up
  6. Aug 26, 2020 at 11:15 PM
    racebug68
    racebug68 Well-Known Member
    Travis
    Chandler, AZ
    05 DCLB 4x4 TRD SPORT SILVER
    I can't leave anything well enough alone
    I have a brand new OEM clockspring for the steering wheel controls. I had airbag issues, but ended up being the wire going to the front crash sensors got broken somehow. Never needed to take the clockspring out of the box, but bought it because I assumed I would need to replace it. let me know if interested, I'll get a pic/part number, and look up how much I paid so I can have some idea of the amount of money I will loose...
    BassAckwards[QUOTED] likes this.
  7. Aug 27, 2020 at 5:16 AM
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    ThomasMore66, Athlaos, mr.trd and 4 others like this.
  8. Aug 27, 2020 at 6:13 AM
    TRON
    Nice! Glad your engine is running smooth. The 3.73 ratio is so different. My 3rd gear pull at 3k is closer to 65-95.
    What nozzle size are you running?
    Athlaos and BassAckwards like this.
  9. Aug 27, 2020 at 6:17 AM
    MightyMouseTom
    MightyMouseTom Balance off road vs on road performance
    Tom
    San Antonio, Texas
    2013 Black DCSB
    2inch lift, 285/75/17 Nitto Trails Grapplers, Billy 6112/5100s AAL, Alpine Design Cab mount relocation, TRD Supercharger w/URD pulley, Volant Ram Air Intake, TRD Exhaust, Katzkin, TechDeck, Ram mounts, Audio w/hideaway kicker amp, CBI skid, Custom grille, and SS3 fogs
    this is how I felt this morning for some reason. I lost so much giddy up when I went up in tire size. I can’t wait for headers to get here but gears have to come next.
  10. Aug 27, 2020 at 7:11 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  11. Aug 27, 2020 at 7:27 AM
    Nateclimb
    Nateclimb Well-Known Member
    UT
    15 Inferno Pro SC'ed
    So it looks like it does have the anti-drain back.
    https://performanceparts.ford.com/part/CM-6731-FL820
    Would this make you want to change filters? I change my oil ever 5k and live in Utah. I visit Montana often in the winter, so my truck sees a wide range of temps. -20 in the winter up to 105 in the summer, I tend to drive hard at times. I'm okay spend a little more on oil and filters if it gives me pice of mind.
    I'm thinking the above filter with Amsoil 5w-30, or Pennzoil ultra Platinum 5w-30.
    What oil do you use?
  12. Aug 27, 2020 at 7:56 AM
    BassAckwards
    It very well might.. I live in Texas and it's pretty hot here so Ive been running 10w40 M1 full synthetic. Most motor oils these days are great compared to what they used to be, so I don't think you can go wrong picking a brand. It's changing it out regularly that's the most important thing imo
    Athlaos, Nateclimb[QUOTED] and Norton like this.
  13. Aug 27, 2020 at 8:12 AM
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    #2 nozzle i think forget the size
  14. Aug 27, 2020 at 8:40 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    I'm intrigued by this filter, about which I was previously unaware. Not sure I'll switch, because they're 3-4 times the ($4-$5) cost of the Toyota 90915-YZZD3 filters I currently use, but they appear to be another good choice.
    Like @BassAckwards, I believe regular oil changes are the key, so I don't think you'll go wrong with either of those oil choices. The climate here is similar to yours and, FWIW, I switched to Amsoil Signature Series 0W-30 Synthetic Motor Oil several years ago. I did so because most engine wear is at startup, and 0W- oils' improved cold flow properties should minimize that.
    +1. Agree completely with this.
  15. Aug 27, 2020 at 9:55 AM
    mr.trd
    mr.trd Are you Recreationally Insane?
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Icon coilovers w 14" 700lb springs, Icon billet UCA w/ Delta joints, custom built Icon rear resi-shocks, Icon stage 3 rear leaf pack, Archive Garage Hammer Hangers w/ homemade spreader bar, superbumps up front and timbren bumps in the rear, Crown brake lines, U-bolt flip,4.88's with front ARB locker and ARB dual compressor mounted behind back seat, 285/75R17 BFG A/T KO2's on Bronze Icon Alloy Compression's, 5th gen T4R budget big brake kit, CBI Off-Road Fab. custom Trailmaster 2.0 with swing-away tire carrier, CBI custom tube front bumper, CBI kickout sliders, CBI full flat belly skids including gas tank,CBI Ditch Light brackets w/ Heretic Studio Quattro's, Heretic Studio's 30" Amber on the front, Heretic Studio 40" bar under the Front Runner Roof Rack, Expedition Essentials RAM mount, Leer used shell, OEM black chrome sport headlights, fog lights always on mod, rear locker anytime mod, TRD supercharger, URD Ucon-EMS, Deatschwerks 255 fuel pump w/ URD external fuel filter kit, AFE intake paired to a Safari Snorkel, URD spec-U exhaust w/ factory Tundra muffler behind URD equal length headers.
    That looks like me in overdrive. LOL except I don't pull nearly that hard! Very Nice!
    Athlaos likes this.
  16. Aug 27, 2020 at 10:06 AM
    mr.trd
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Looks like I am way overpaying with my filter. I run the TRD filter for like $15 each. But mainly run it just so that I can mover a product on the shelf but also have one on the shelf to show people when they ask. I get lots of asks but not many sales. I stock the TRD replacement for the D3 and the A1 that I use on my Taco and Camry. The A1 replacement is nice to have to show people the media difference since it is a open element. And just switched oil from the Redline 0w40 to the Pennzoil platinum 5w30 and use 5K intervals. Going to try the ultra platinum but undecided on weight still.
  17. Aug 27, 2020 at 12:59 PM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    man. You may not have as much airflow as I do, but you’d win hands down from the weight difference.
  18. Aug 27, 2020 at 3:25 PM
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    Xrunners should almost always have a leg up on us 4WD guys lugging extra crap around. That's some pretty decent acceleration.
    12TRDTacoma[OP] and JustDSM like this.
  19. Aug 27, 2020 at 4:19 PM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    That’s only 6° of timing too ;)
    12TRDTacoma[OP] and mr.trd like this.
  20. Aug 27, 2020 at 4:25 PM
    BassAckwards
    I will definitely keep you in mind if I decide to swap it out. Thanks for reaching out man
