TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Aug 30, 2020 at 12:09 PM
    brian.gonz
    brian.gonz Well-Known Member
    Brian
    Manor, Texas
    Supercharged 2012 TRD Sport DC
    TRD Supercharger, Relentless Fab Stingray, TRD Pro Wheels, BFG, AMP Research Runners.
    Hello all I just upgraded from a 1st gen to a 2012 TRD supercharged. I have a whole lot to learn as it's a different engine and my first boosted vehicle. The supercharger was installed at the dealership in 2012 so assuming from what I have read it should have the "TRD tune" is there any way to tell forsure if it's been tuned and is there better options for tuning. I dont know anything about tuning so I'm not really looking to do it myself as I dont want to mess anything up but I would like to get as much power as possible and still keep the reliability as it's my daily driver. Thanks in advance I will continue reading more on this thread and others that I find but if anyone has any particular threads to point me in the right direction it would be greatly appreciated.
    MightyMouseTom likes this.
  2. Aug 30, 2020 at 12:44 PM
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    @brian.gonz
    If the blower was installed by the toyota dealership, i would assume that they flashed it with the TRD supercharger tune as it is part of the factory install procedure to retain warranty, etc. So its pretty safe to say that you have the TRD blower tune.
    If you want a tune that is more optimized, you'll need to purchase HP Tuners and have out resident ECU tuner @JustDSM sprinkle his engine magic with AT transmission tune spice from @nd4spdbh
    BassAckwards and 12TRDTacoma[OP] like this.
  3. Aug 30, 2020 at 1:46 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    You must be talking about @o0opackersfano0o video
  4. Aug 30, 2020 at 1:57 PM
    Camby
    Camby Well-Known Member
    Brian
    Denver
    2006 Tacoma TRD Off-Road
    Magnuson Supercharger TRD CAI Catch Can After market dual exhaust Heated Mirror Kit Install Aftermarket Head and Tail lights Several accessory Mods
    You had posted a youtube clip, running with "TRD tune and NST Kit + 2.5 pulley" no???
  5. Aug 30, 2020 at 3:02 PM
    420taco
    420taco Well-Known Member
    Justin
    PA
    In open loop power enrichment the stock TRD tune is gonna be rich regardless of pulley size. It’s closed loop part throttle that has to be dialed in.
    12TRDTacoma[OP] likes this.
  6. Aug 30, 2020 at 3:50 PM
    3pooches
    3pooches Well-Known Member
    VA & WV
    15 tacoma dcsb Sc Linked, 2014 reg cab locked
    Is there a learning process for the urd uconn? My truck won’t run with it installed, unplug it, truck acts fine. When it’s plugged in the truck is flooding. I don’t have my ecu flashed for a supercharger, it is flashed to eliminate sais and rear o2’s. Truck has 630 injectors and a 7th injector I haven’t plugged in.
  7. Aug 30, 2020 at 4:17 PM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    Has the Ucon been programmed for the larger injectors? And all the other goodies? If not, that would explain it.
    3pooches[QUOTED] likes this.
  8. Aug 30, 2020 at 5:07 PM
    3pooches
    VA & WV
    Yes, Pulley, injectors, and ucon where all from a previously working setup.
  9. Aug 30, 2020 at 5:27 PM
    TRON
    Yup! Not sure where you are getting 12lbs of boost or AFRs in the 10s though. That pulley ratio setup was getting me about 8lbs boost since I’m at 5500ft. My TRD reflash never had my AFRs in the 10s that I can recall. I’ve always been in the 11s even when I started boost referencing. Then again my TRD reflash was done over 10 years ago.
    Torspd likes this.
  10. Aug 30, 2020 at 6:55 PM
    findingthingsout
    findingthingsout Well-Known Member
    midwest
    08 Tacoma TRD O/R A.C. MT
    Boost, armor, lights, big tires, no savings.
    Did you do the exhaust cam gears?
  11. Aug 30, 2020 at 7:15 PM
    TRON
    Yes it learns but not that extreme. Sounds like guardian protection. You don’t have any CELs? You need to talk with Scott
    I don’t see how your stock ECM could run those 61lbs dekas.
  12. Aug 31, 2020 at 4:41 AM
    3pooches
    VA & WV
    Yes
  13. Aug 31, 2020 at 4:46 AM
    3pooches
    VA & WV
    No cel without ucon. With ucon it flashs sometimes as it’s dying. I have no idea either. The a/f without ucon is around 14-15, with ucon it floods as soon as it turns over and dies.
  14. Aug 31, 2020 at 6:24 AM
    420taco
    Justin
    PA
  15. Aug 31, 2020 at 6:42 AM
    Darkgoatracer
    Darkgoatracer Well-Known Member
    Nick
    Northern VA
    2012 trd sport tacoma
    Stock
    Shoulda just 2jz swapped it imo
    420taco and 3pooches like this.
  16. Aug 31, 2020 at 7:01 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Mike Singer? Never heard of her. :p
    Yeah I had an issue with my Fleetrunner back in the day but I have reason to believe that the belt was old stock from my local auto parts store which is why I most likely had issues with it.
  17. Aug 31, 2020 at 9:18 AM
    DocME
    California
    '07 FJ Cruiser
    You should get a hold of URD and get a programming meeting setup with Scott. I can't help but to think there's a minor discrepancy between the vehicle it was in originally and yours. It is interesting that you say the stock ECU runs the 61 pound injectors, as it should be programmed for the TRD injectors.
    Things that would be useful to know:
    - What tune is on the stock ECU? Has anything be changed on the stock ECU?
    - Does the stock ECU have the TRD calibration?
    - Was the tune in the UCON expecting a TRD calibration or Stock?
    Either way, I don't think your problem is going to be fixed on the forum. You'll have to reach out to Scott. Should only take him a few minutes of tweaking.
    Don't abandon ship just yet!
    Athlaos, Torspd and SUMOTNK like this.
  18. Aug 31, 2020 at 12:00 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Contacted URD?
  19. Aug 31, 2020 at 12:20 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    why get in touch of the manufacturer of a part when you can get online and ask random people on a forum?
  20. Aug 31, 2020 at 12:48 PM
    3pooches
    VA & WV
    Yea I emailed them over the weekend. They got back to me. I think I’m going to have justdsm make me a tune.
