TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Sep 29, 2020 at 8:10 AM
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    A battery powered drill worked perfect for me. Very quick and easy.
  2. Sep 29, 2020 at 8:27 AM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    So, it is easier to do the pulley swap and snout cut with the supercharger out of the engine, but the shavings you need to be concerned with are the ones that could be sucked into the housing while you're shaving the snout. When it's on the engine both sides of the supercharger are sealed. Just be aware of them and take proper precautions. Only takes 10 minutes to cut the snout. Its a relatively painless job.
  3. Sep 29, 2020 at 10:05 AM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    just be verrrrrry careful. by hand it take 30-60 minutes and honestly the safest way to do it. Ask me how I know but you do not want that bolt to break in the snout. It is a real PIA to get out.
    I did it on the engine and put some shop towels all around it so I would limit any shavings. When you do it by hand the shavings are more controlled as well.
    Norton and rmepilot[QUOTED] like this.
  4. Sep 29, 2020 at 11:37 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    NO DRILLS to cut the snout!
    I'm saying this to save you costly time and heartaches of having to attempt to remove broken bolts and in @nudavinci64 's case weeks worth of issues and then having to have sleeves custom made to fit over the snout to keep the extractor drill bit aligned true and straight. It can get real ugly real fast if you aren't careful, so NO DRILLS!
  5. Sep 29, 2020 at 11:41 AM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    I thought impacts were the problem but not drills?
  6. Sep 29, 2020 at 11:41 AM
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
    This is why I plan things weeks in advance. :thumbsup:
    DocME and BassAckwards like this.
  7. Sep 29, 2020 at 11:47 AM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    I used a drill without a problem. Don't put it on the hammer setting. Impacts are a definite no no
    Norton and JacksonTacoma like this.
  8. Sep 29, 2020 at 11:48 AM
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    A drill is fine on a low speed setting. The only potential issue would be if you have a dull snout cutter. No issues at all for me with a sharp cutter.
    Edit: I used a non-impact drill. I have a video somewhere of when I cut mine with a standard battery-powered drill
    jamesepoop, Norton and mightytacoman like this.
  9. Sep 29, 2020 at 11:49 AM
    rmepilot
    Rob
    Huntsville, AL
    Full or dull?
    Mine will be used, but only one time previously.
  10. Sep 29, 2020 at 11:51 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Whatever you guys want to do.. I can't tell you what to do, but impacts and drills for me on these snouts are a no no. Normally imna huge proponent of impacts and air or battery powered tools, but in this case slow and steady wins the race, at least for me.
    As for the sharpness of the cutter, obviously the easier it is to cut the sharper it is. If you have a sharp one, that would be the most ideal and make the entire process a little easier to do.
  11. Sep 29, 2020 at 11:53 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    I used a small ratchet when cutting my snout down and it only took maybe 25 minutes. Make sure you have the cutting blade on the snout cutter facing the right direction or it will take forever. Mine went pretty quick, pressing on the pulley was a little more difficult but still very doable. If i can do it, so can you
  12. Sep 29, 2020 at 11:55 AM
    BassAckwards
    Putting the right amount of pressure on the blade with the spring goes a long way to speed things up too. make sure you have it snug but not tight
  13. Sep 29, 2020 at 12:03 PM
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    I know you're just looking out for everyone :thumbsup:
    It would definitely be a bad day to break a bolt off!:annoyed:
  14. Sep 29, 2020 at 12:10 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I've done it twice but luckily the bolt came out really easily.
    nudavinci64 and rmepilot like this.
  15. Sep 29, 2020 at 12:39 PM
    DocME
    California
    '07 FJ Cruiser
    I used a drill on mine. Just like anything else, don’t go cowboy on it. Take your time and be accurate.
  16. Sep 29, 2020 at 2:50 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    I also used a drill and had no problems. If you're prone to breaking things, skip the power tool. If not, it can be done safely.
  17. Sep 29, 2020 at 3:04 PM
    mr.trd
    mr.trd Are you Recreationally Insane?
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Icon coilovers w 14" 700lb springs, Icon billet UCA w/ Delta joints, custom built Icon rear resi-shocks, Icon stage 3 rear leaf pack, Archive Garage Hammer Hangers w/ homemade spreader bar, superbumps up front and timbren bumps in the rear, Crown brake lines, U-bolt flip,4.88's with front ARB locker and ARB dual compressor mounted behind back seat, 285/75R17 BFG A/T KO2's on Bronze Icon Alloy Compression's, 5th gen T4R budget big brake kit, CBI Off-Road Fab. custom Trailmaster 2.0 with swing-away tire carrier, CBI custom tube front bumper, CBI kickout sliders, CBI full flat belly skids including gas tank,CBI Ditch Light brackets w/ Heretic Studio Quattro's, Heretic Studio's 30" Amber on the front, Heretic Studio 40" bar under the Front Runner Roof Rack, Expedition Essentials RAM mount, Leer used shell, OEM black chrome sport headlights, fog lights always on mod, rear locker anytime mod, TRD supercharger, URD Ucon-EMS, Deatschwerks 255 fuel pump w/ URD external fuel filter kit, AFE intake paired to a Safari Snorkel, URD spec-U exhaust w/ factory Tundra muffler behind URD equal length headers.
    I tend to break more things with hand tools than power tools. Now I am scared. But I think it is time to find me a snout cutter and send an email to smooth flow. Just a 2.7, nothing extreme. Just want to get into boost a little earlier. And a Rousch and another RPM in factory length this time.
  18. Sep 29, 2020 at 7:55 PM
    nudavinci64
    Robert
    Very true but also be careful with any high powered drills, hammer drills etc. just the word to that wise. it wasn’t all that bad manual but yes my mistake is everyone else’s blessing hahaha
    Murphinator[QUOTED] and rmepilot like this.
  19. Sep 29, 2020 at 7:56 PM
    nudavinci64
    Robert
    Yah it was prob 30-60 min. Didn’t take very long. Cutting oil and a sharp blade.
    BassAckwards[QUOTED] likes this.
  20. Sep 29, 2020 at 7:57 PM
    nudavinci64
    Robert
    CarID has them for $45 for the belt. Just ordered a pair.
    Athlaos likes this.
