TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Apr 17, 2018 at 7:18 PM
    #3181
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    I bought a handheld. Not self tuner.
    Hopefully it, my aem meth kit, and my 160 tstat all come this week
    Roostfactor, jojotoo and cdelgado14 like this.
  2. Apr 17, 2018 at 7:21 PM
    #3182
    cdelgado14
    cdelgado14 Well-Known Member
    Alice,Texas
    Supercharged micro machine ;)
    Bilstein 3 inch w/ 5100's
    K
    Keep us updated brotha!
    Roostfactor likes this.
  3. Apr 17, 2018 at 7:45 PM
    #3183
    GT7
    Grant
    Phoenix
    2013 DCLB
    I will!
  4. Apr 17, 2018 at 8:58 PM
    #3184
    mr.trd
    mr.trd Are you Recreationally Insane?
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Icon coilovers w 14" 700lb springs, Icon billet UCA w/ Delta joints, custom built Icon rear resi-shocks, Icon stage 3 rear leaf pack, Archive Garage Hammer Hangers w/ homemade spreader bar, superbumps up front and timbren bumps in the rear, Crown brake lines, U-bolt flip,4.88's with front ARB locker and ARB dual compressor mounted behind back seat, 285/75R17 BFG A/T KO2's on Bronze Icon Alloy Compression's, 5th gen T4R budget big brake kit, CBI Off-Road Fab. custom Trailmaster 2.0 with swing-away tire carrier, CBI custom tube front bumper, CBI kickout sliders, CBI full flat belly skids including gas tank,CBI Ditch Light brackets w/ Heretic Studio Quattro's, Heretic Studio's 30" Amber on the front, Heretic Studio 40" bar under the Front Runner Roof Rack, Expedition Essentials RAM mount, Leer used shell, OEM black chrome sport headlights, fog lights always on mod, rear locker anytime mod, TRD supercharger, URD Ucon-EMS, Deatschwerks 255 fuel pump w/ URD external fuel filter kit, AFE intake paired to a Safari Snorkel, URD spec-U exhaust w/ factory Tundra muffler behind URD equal length headers.
    The problem is the blue only lasts about 20 minutes. Then it turns black from running on the back side on the idlers.
    Torspd, Roostfactor and GT7 like this.
  5. Apr 17, 2018 at 9:26 PM
    #3185
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    That means either you make the bracket and buy all the parts OR you buy a plug and play kit that comes with all the parts pre drilled , shaped, and ready for install.
  6. Apr 17, 2018 at 10:02 PM
    #3186
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    Pulled out the little brass restrictor jet today.... I'm sure this has been asked in the last 160 pages, but why put it in there Toyota?
  7. Apr 18, 2018 at 12:29 AM
    #3187
    Taco Suave
    Taco Suave Taco Fever
    Griffin
    Oxnard
    2012 TRD Off Road
    Go fast stuff
    Ok, Id probably go for the diy
    Roostfactor[QUOTED] likes this.
  8. Apr 18, 2018 at 4:29 AM
    #3188
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    :annoyed::bananadead:
  9. Apr 18, 2018 at 4:37 AM
    #3189
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    This thread, and the Turbo BS thread. My two favorite.
  10. Apr 18, 2018 at 5:16 AM
    #3190
    ThomasMore66
    Dallas/Fort Worth & Durango
    And it hasn’t been shutdown like most of the old ones.
  11. Apr 18, 2018 at 5:17 AM
    #3191
    ThomasMore66
    Keeping you from doing something stupid.
  12. Apr 18, 2018 at 6:21 AM
    #3192
    Roostfactor
    TX panhandle
    Think of the bypass valve as suspension. You have a shock for damping and a spring. You just removed the shock.
    jojotoo likes this.
  13. Apr 18, 2018 at 6:47 AM
    #3193
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    I really wonder if the knock ovtune heard when he dyno’d my truck was from removing that jet. Maybe boost comes on sooner than the tune expected. I guess I cannot say for sure unless I put it back in, put the trd tune back on and have him do some more pulls with his equipment hooked up listening for knock. Only reason I think so is because he said there would be some light knock then it would go super rich.
  14. Apr 18, 2018 at 7:48 AM
    #3194
    Roostfactor
    TX panhandle
    It's possible, or it could be the TRD tune starting to go lean before going into open loop.
    The restrictor jet just dampens the bypass valve so by removing it it slams open and shut instead of moving more slowly.
    Norton, jojotoo and Murphinator like this.
  15. Apr 18, 2018 at 8:38 AM
    #3195
    Taco Suave
    Griffin
    Oxnard
    2012 TRD Off Road
    Go fast stuff
    Stock injectors or trd SC injectors?
    loginfailed likes this.
  16. Apr 18, 2018 at 8:47 AM
    #3196
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    I'm gonna put it back in, get me an AFR and boost gauge, then re-do this mod. No point in flying in the blind.
    Biscuits and Roostfactor like this.
  17. Apr 18, 2018 at 8:48 AM
    #3197
    GT7
    Grant
    Phoenix
    2013 DCLB
    Trd sc
  18. Apr 18, 2018 at 8:54 AM
    #3198
    Taco Suave
    Griffin
    Oxnard
    2012 TRD Off Road
    Go fast stuff
    Oh man, so it sounds like it would be a good idea to upgrade before a 2.55 then?
  19. Apr 18, 2018 at 9:00 AM
    #3199
    GT7
    Grant
    Phoenix
    2013 DCLB
    This is the general consensus, but it has been done
  20. Apr 18, 2018 at 9:09 AM
    #3200
    Taco Suave
    Griffin
    Oxnard
    2012 TRD Off Road
    Go fast stuff
    Do you know anyone else with data on this?
