TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Nov 12, 2020 at 3:25 PM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    BassAckwards[QUOTED] likes this.
  2. Nov 12, 2020 at 3:43 PM
    jamesepoop
    jamesepoop Well-Known Member
    California
    2007 Fj Cruiser
    So this isn't a first right? I'm installing the heater core hoses and mine came with Gates 19mm (3/4). My heater core and connections are 16mm (5/8). Maggy provided a 3/4 connector too. Anyone using HPS heater hoses? I spliced my old 16mm hoses together for now but thinking I might go HPS and splice those
  3. Nov 12, 2020 at 5:04 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    s
    splices work. shop around at napa and Amazon.
  4. Nov 12, 2020 at 5:06 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    i would aim for keeping the 3/4 so the volume its supposed to flow is as designed. i dont think 5/8 is bad unless in an extremely hot climate.
    Athlaos and jamesepoop[QUOTED] like this.
  5. Nov 12, 2020 at 5:35 PM
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    PM me
    nudavinci64 and mr.trd like this.
  6. Nov 12, 2020 at 7:09 PM
    jamesepoop
    California
    2007 Fj Cruiser
    My stock heater lines are 5/8. You mean keep 5/8? Or is yours 3/4? Picked up Dorman #56438 metal 5/8 connector like the stock piece (or at least my FJ does).
  7. Nov 12, 2020 at 7:14 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    regardless of the size of pipe do research before changing things. ask me how i know...
  8. Nov 12, 2020 at 7:36 PM
    jamesepoop
    California
    2007 Fj Cruiser
    @White lightning boosted just wanted to follow the damn instructions but their damn parts won't let me. Damn damn damnity gad damn:rofl:
  9. Nov 13, 2020 at 6:01 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    probably no big deal. just trying to not advise hastey/no thought of reprocussions/ regret syle installs. i mean, what thread needs more than one village idiot. i mean explorer.:anonymous:
  10. Nov 13, 2020 at 6:29 PM
    jamesepoop
    California
    2007 Fj Cruiser
    I came here to ask first as I figured you guys came across this issue. Starting with the oversized hoses on the coolant bottles. I just don't want to re-do these heater hoses later because I was lazy. I ordered HPS silicone hoses but I'm going to stick to rubber. Reading up about how much silicone "sweats" makes it seem it's less up to the job.
  11. Nov 13, 2020 at 6:32 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    silicone is great for color themes. standard black is far more cost effective. make the hoses function properly. get the bling in billet custom parts.:D
    jamesepoop[QUOTED] likes this.
  12. Nov 13, 2020 at 6:41 PM
    jamesepoop
    California
    2007 Fj Cruiser
    I finished splicing my old hoses (it was pretty close on the angles), but I don't have any idea how old these are. Luckily Maggy is sending the replacement extension hose that were meant for the kit. I'll order new rubber asap.
  13. Nov 13, 2020 at 6:44 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    right on! i made friends with some folks at oreillys. they just let me wander in back searching for hoses with the bends i wanted. good times. and returnable as they were for mockups.
  14. Nov 13, 2020 at 10:56 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    I used 1/2" inlets and outlets for my old coolant tank for the longest of time. It was really no big deal @jamesepoop
  15. Nov 14, 2020 at 1:46 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Sorry for the delay gents, but finally got some time to do some logging and compare the UCon and HPTuners in my truck.
    My setup for the comparison is the following except for with the HP tuned ECU, I am running the FPR mod and no 7th.
    - 2013 4wd 6spd
    - URD lightweight flywheel & stage 3 clutch
    - Magnuson S/C w/ 2.5” pulley w/ rip mod
    - URD TCAI
    - Roush Tensioner
    - TRD 455cc injectors
    - URD 7th injector
    - Snow performance stage 3 boost cooler spraying 625ml/min above 7psi
    - URD Spec-u headers
    - JFR Y-pipe
    - TRD Catback (catless)
    - Mildly ported TB & S/C inlet
    - 4.10 gears
    Initial impressions that the HPTuned ECU is much smoother as far as power delivery goes. It is also smoother when quickly tipping-in the throttle or letting off quickly to decelerate. UCon always was a little rough at times when doing these things so that was the first thing i noticed that was a pleasant change.
    The throttle mapping seems to make things feel a little peppier, and it feels like the truck gets up to speed quicker. Top end power felt to be largely unchanged, but the low and mid-range power seems to come on a little quicker. The max MAF I had with the UCon was 346.7g/s, but I was unable to get an accurate Max MAF on the HPtuned ECU since it was pegged at 323 g/s above about 5200 rpms with the URD intake piping.
    In lieu of a direct max MAF comparison, I have taken the MAF values from both sets of logs at the RPMs below while going WOT in 3rd & 4th gears. The highest RPM readings there are represent where the MAF was maxed out with HP tuners so I looked at the UCon logs and used that as the stopping point for the MAF comparison. Obviously there is a lot more than just air flow that should be compared, but I don't have the knowledge to do that unfortunately.
    Intake air temp 73*F HPTuner Log
    Intake air temp 60*F UCon Log
    3rd gear pull MAF readings:
    4000RPMs
    UCon: 243.6 g/s
    HPT: 241.93 g/s
    4500RPMs
    UCon: 277.03 g/s
    HPT: 278.03 g/s
    5000RPMs
    UCon: 309.4 g/s
    HPT: 312.52 g/s
    5237RPMs
    UCon: 321.5 g/s
    HPT: 323.9 g/s
    4th gear MAF readings:
    4600RPMs
    UCon: 283.7 g/s
    HPT: 285.06g/s
    5000RPMs
    UCon: 306.8g/s
    HPT: 313.20g/s
    5217RPMs
    UCon: 318.2 g/s
    HPT: 323.85g/s
    Overall, I'd say working with Justin to get an HPTune that is custom for your truck is a big upgrade for drivability and the ability to tailor the tune to your particular upgrades. The power delivery and the transition between shifts feels smoother, and I really like the idea of using the stock ECU to keep things simple and reliable. If you are on the fence about this, I'd say that it is well worth it.
    If yall have any questions, please feel free to ask away
  16. Nov 14, 2020 at 2:11 PM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    I appreciate you sharing your thoughts, observations and testing results!
    I am glad you're pleased with the outcome. I do however feel bad about overlooking your last email. I will get back to you this evening with a reply there. Sorry about that!
  17. Nov 14, 2020 at 3:05 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I really need to get to sending you another log. The hesitation off idle from a stop is so hot or miss though. Sometimes it does it. Others it does not.
    mr.trd likes this.
  18. Nov 14, 2020 at 6:42 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    Finally got around to installing block off plates and uploading a new tune from @JustDSM . Works flawlessly. No codes. Two thumbs up!
  19. Nov 14, 2020 at 7:31 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    One less problem to worry about
  20. Nov 14, 2020 at 7:54 PM
    BassAckwards
    I appreciate the opportunity to do the comparison and have you tune the truck. I found it pretty interesting myself.
    Don't sweat it man, life happens, just get around to it whenever you have a chance! I'm in no rush at all
    TodayWasTHeDaY likes this.
