TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Nov 20, 2020 at 11:47 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Tis the season gents.
    Also, I'm a little late here, but boost season is now here. ;)
  2. Nov 20, 2020 at 11:52 AM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Yes, my motor likes the chill in the air.
  3. Nov 20, 2020 at 9:56 PM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    Boost season is when covid first started and all the highways and city streets were empty
  4. Nov 20, 2020 at 10:33 PM
    mr.trd
    mr.trd Are you Recreationally Insane?
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Icon coilovers w 14" 700lb springs, Icon billet UCA w/ Delta joints, custom built Icon rear resi-shocks, Icon stage 3 rear leaf pack, Archive Garage Hammer Hangers w/ homemade spreader bar, superbumps up front and timbren bumps in the rear, Crown brake lines, U-bolt flip,4.88's with front ARB locker and ARB dual compressor mounted behind back seat, 285/75R17 BFG A/T KO2's on Bronze Icon Alloy Compression's, 5th gen T4R budget big brake kit, CBI Off-Road Fab. custom Trailmaster 2.0 with swing-away tire carrier, CBI custom tube front bumper, CBI kickout sliders, CBI full flat belly skids including gas tank,CBI Ditch Light brackets w/ Heretic Studio Quattro's, Heretic Studio's 30" Amber on the front, Heretic Studio 40" bar under the Front Runner Roof Rack, Expedition Essentials RAM mount, Leer used shell, OEM black chrome sport headlights, fog lights always on mod, rear locker anytime mod, TRD supercharger, URD Ucon-EMS, Deatschwerks 255 fuel pump w/ URD external fuel filter kit, AFE intake paired to a Safari Snorkel, URD spec-U exhaust w/ factory Tundra muffler behind URD equal length headers.
    Pretty sure I just took teeth off the rear ring again. Going to have to open it up tomorrow. But that little Honda in Mexico had no clue what it was asking for. Punks. But if I did loose another rear end? Who really won? It was either that or towing the camper last week to elk camp and back. Wonder if maybe there is enough pressure on it that the axle is deforming just enough to not help the ring and pinion mesh correctly.
  5. Nov 21, 2020 at 12:12 AM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    Liked the win. Disliked the ring.
  6. Nov 21, 2020 at 9:29 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Never made it home more quickly, on week days......
  7. Nov 21, 2020 at 9:46 AM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
  8. Nov 21, 2020 at 9:52 AM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    tx2k all week long
  9. Nov 21, 2020 at 9:53 AM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    stonks man
  10. Nov 22, 2020 at 4:07 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Got almost 125K miles and thinking whether to get a new rack and pinion? Can anybody attest better handling afterwards. I obviously don’t drive off road but want tighter handling on the curves. :D
    12TRDTacoma[OP] and JustDSM like this.
  11. Nov 22, 2020 at 4:11 PM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    I would assume you've already got poly rack bushings to start?
    12TRDTacoma[OP] likes this.
  12. Nov 22, 2020 at 4:11 PM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    If no leaks then I wouldn't. Could check the bushings and the tie rod joints for play. There are other options to improve handling.
  13. Nov 22, 2020 at 4:25 PM
    TRON
    So a power steering flush and some energy bushings is just as good as a new one?
    Have a small leak at my boots on the R&P. Dropping the stance helped with handling but I really want some high end coil-overs. But finding a good brand that will fit and not rub my transfer case axles is the trick. What coilovers your running? @Lucario Runner
  14. Nov 22, 2020 at 4:42 PM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Hmm, I guess it depends on how far you wanna go, you could rebuild your oem or get a new one ($500-600) I personally would buy a new oem, build it to my spec and install it and rebuild the old and store it. My tacoma runs the bilstein 6112 one the lowest setting but I will make a revision on the driver side by rising it up one to be level and upgrading to 650 springs due to, imo, too much brake dive for my liking and off set the weight of the supercharger. Later down the road I'll prob get the bilstein 8112 zone control when I can confirm that it'll work with bigger sway bars. other than that on the taco it'll probably get camburg uca and dirt king lca. spindle gusset most likely pending clearance. on the rear the frame will be boxed, rear sway bar and a lateral control arm will be added. For you I would look into some different wheels (20x10-11, squared or staggered) and tires 40 profile or 35.
  15. Nov 22, 2020 at 5:08 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I though heavily about how to use my coilovers and the cv-shafts.
    What coilovers do the GMC Cyclone use?
    Getting lower control arms with the extra tab, and the added strut mount behind the normal shock tower are the simplest. Should UCA clearance not be an issue.
    Ultimately, it will take some measurements and fabrications.
  16. Nov 22, 2020 at 5:08 PM
    JustDSM
    Justin
    Ogden, UT
    They were torsion bar'd up front. Can you believe that!
  17. Nov 22, 2020 at 5:14 PM
    TRON
    What made you take out your transfer case axles? The transmission?
  18. Nov 22, 2020 at 5:44 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Never looked before. Must be why the Syborg truck went coilover. Torsion bars make sense for room, but nowhere near adequate. Not when AWD Rally cars existed at the time.
    Transmission and coilovers. Had to. Never got the AWD transfer case for the T56 Magnum, so there hadn't been the strong push to figure it out.
    I wonder how much shorter the RAV 4 struts are? Or maybe adapting another car's which has the clearance.
  19. Nov 22, 2020 at 5:47 PM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    To strum up a little more debating. I brought this up in the appropriate thread and now the next best. What is your guys take on switching from the TRD blower to the new Procharger set up? Also, other than the upper and lower stock intakes being replaced and the stock coolant manifold spacer, what other parts do you think would need to go back to stock for the Procharger set up?/
  20. Nov 22, 2020 at 6:24 PM
    TacoJova
    TacoJova Well-Known Member
    Central Oregon
    21 Ram TRX Sold 2015 White DCSB Offroad
    Supercharger Hybrid audio stage 3 and stage 2 rear with 2 image Dynamics IDQ10's and alpine amps Bilstein 5100 with OME 887 Dakars and Icon 2.0 in the rear URD SPEC U Headers URD Y Pipe Borla muffler 18" Magnaflow Resonator Morimoto fogs
    If it was out when I did mine I would have gone procharger but now that I have the Maggy I wouldn’t spend the money or effort to change. If I had the time and money to go for something else it would most likely be turbo
    jamesepoop and nudavinci64 like this.
