TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Apr 20, 2018 at 5:04 PM
    #3321
    HamerMan
    HamerMan Well-Known Member
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    When I changed my fuel pump
    URD thingy says 6 psi but the gauges say 9.
    Stock sized injectors, but with the 7th injector
    Yes, to a walbro 190 when I did the 7th injector
  2. Apr 20, 2018 at 5:09 PM
    #3322
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Which brand boost gauge do you have?
  3. Apr 20, 2018 at 5:12 PM
    #3323
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Is the boost gauge reading from the same source as the URD ecu?
  4. Apr 20, 2018 at 5:16 PM
    #3324
    HamerMan
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    It's a shitty vato zone one. It's called equius or something. Yes it's from the same source. I'm waiting on money for a gauge pillar with an AEM wideband and boost gauge
  5. Apr 20, 2018 at 5:21 PM
    #3325
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    I went to the tundra filler.
    12TRDTacoma[OP] likes this.
  6. Apr 20, 2018 at 5:28 PM
    #3326
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Alright good. I want to make sure which is the actual boost pressure. I have a feeling the autozone one is off.
    A few criticisms. I hate the fact that URD still sells the 190 LPH. They might as well just sell the 255LPH since it allows more room for growth before hitting max duty cycle. Next is more of a question, but are those upgraded OEM injectors which came with the charger, or stock sized injectors
    Biscuits and inwood customs like this.
  7. Apr 20, 2018 at 5:37 PM
    #3327
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    With a 2.2" pulley? It probably is about 9 psi. I make 7.5 psi on the stock pulley, so that sounds about right.
    Have you considered that the engine is performing exactly as it should? These aren't positive displacement blowers, so expecting massive low end gains might not be realistic.
  8. Apr 20, 2018 at 5:56 PM
    #3328
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    I think @Biscuits is talking fuel with 7th and @TRON is talking water/meth. Am I correct here?
  9. Apr 20, 2018 at 5:59 PM
    #3329
    Roostfactor
    TX panhandle
    Whoa whoa whoa...throttle back turbo!
    Which supercharger do you have @HamerMan? If it's a TRD then it is positive displacement.
    inwood customs likes this.
  10. Apr 20, 2018 at 6:17 PM
    #3330
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    My eyebrows complement your "whoa"'s.
  11. Apr 20, 2018 at 6:18 PM
    #3331
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Ive been popcorn for a bit now waiting for it.
  12. Apr 20, 2018 at 6:23 PM
    #3332
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    You are correct regarding what I was asking about.
    Seems like a silly question, but I recently experienced a situation at work where something very similar was set up and there was an uneven distribution which caused a loss of throughput and reliability.
    Roostfactor[QUOTED] likes this.
  13. Apr 20, 2018 at 6:29 PM
    #3333
    HamerMan
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    I agree. I also wish I had the 255 not the 190. And as for injectors, they are the actual stock injectors. I only got one injector for the setup which was the 7th. I toyed around with the idea of pulling the supercharger and putting on the pink top injectors in.
    Yes it is the 1st gen grey blower
  14. Apr 20, 2018 at 7:13 PM
    #3334
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Do you know the factory HP, and the size of your OEM injectors? As well as the size of the 7th injector.
  15. Apr 20, 2018 at 7:25 PM
    #3335
    HamerMan
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    Factory HP of the 3.4 should be 190 at the crank. Size of the OEM and 7th aren't known. I'm on a road trip to Vegas right now so I can't get the info for you right now lol.
  16. Apr 20, 2018 at 7:29 PM
    #3336
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Win some coin, and upgrade your injectors. Lol
    Roostfactor, oni06 and inwood customs like this.
  17. Apr 20, 2018 at 7:35 PM
    #3337
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    This post right here is a BIG deal. Excellent find! I will be adding this to the original post thread, as well as to my own truck. I always did feel the stupid filler neck was too big for the blower.
  18. Apr 20, 2018 at 8:08 PM
    #3338
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Wow I boned that.
    Carry on.
  19. Apr 20, 2018 at 8:09 PM
    #3339
    Roostfactor
    TX panhandle
    All good bro...happens to the best of us!
  20. Apr 20, 2018 at 8:12 PM
    #3340
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    It appears Gadget may have boned it to...from the U Tune AIC guide, talking about their test 5VZ-FE:
