TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Dec 30, 2020 at 5:33 AM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Where do they have them down there? Not much weight I can shed lol. Rear bumper and spare tire would be about it, though that is probably 250lbs or so
  2. Dec 30, 2020 at 5:34 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I may just have to plan some time off for this...
  3. Dec 30, 2020 at 6:32 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    ET Motopark in San Tan. There are other drags in other places of Phx as well.
    Hell yeah!!
  4. Dec 30, 2020 at 6:51 AM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Ah yeah I know where that is. Used to be one of my favorite mx tracks to ride when I lived down there. But dang it’s a haul from up here lol. Still, if we made a wheeling weekend out of it it could be fun.
    XPOTRPR[QUOTED] likes this.
  5. Dec 30, 2020 at 7:23 AM
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
    Everything back to stock PCV to SCer, coolant to TB. Clear P2111 code. Disconnect Neg lead on battery set for 2hrs. connect, Start let idle, warm-up. Min later code comes up back to Limp mode. :(
  6. Dec 30, 2020 at 7:34 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Need you to do something. Pull off the intake tube. Observe throttle position. Turn truck to ON position. Observe. Note any changes.
    Have someone depress the throttle pedal while you watch. Slowly. Full open to full close. Make sure it operates properly.
    Then inspect the plug and wires.
    Amo-cat3 and BenMara[QUOTED] like this.
  7. Dec 30, 2020 at 7:39 AM
    BenMara
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    So ON position, not RUN. to check TB position.
  8. Dec 30, 2020 at 7:51 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Do that first before checking in the RUN state.
    Keep the MAF plugged in to reduce the chance of another CEL.
  9. Dec 30, 2020 at 10:52 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Again, what the heck is a P2111? We need the code description or we can't help you bro.
  10. Dec 30, 2020 at 11:03 AM
    Amo-cat3
    Amo-cat3 Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    faulty throttle body, or throttle plate stuck open
  11. Dec 30, 2020 at 11:04 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Pretty sure that's a Throttle Actuator Control System code indicating a stuck open condition.
    EDIT: @Amo-cat3 and I were typing the same thing at the same time.
  12. Dec 30, 2020 at 11:22 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Ahh... Yeah, as Tor indicated it is probably best to remove the intake tubing and watch the blade as the throttle is depressed.
    Rare that throttle bodies fail on these trucks, but they are electronics after all and this is an imperfect world. I am curious if he had the issue prior to the install.
  13. Dec 30, 2020 at 12:04 PM
    BenMara
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    It moves, Friend mentioned it might have to be recalibrated since I disconnected the MAF and TB. I dunno I'm just happy I have another vehicle to drive.
  14. Dec 30, 2020 at 12:17 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Negative.
    TB that came with the vehicle, or larger size?
    Was it dropped?
    How does the wiring look? At the plug and the pins inside it.
    The ecu may not be receiving the feedback.
    12TRDTacoma[OP] likes this.
  15. Dec 30, 2020 at 12:25 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    This.
    Larger TB size will 10/10 times give you a code if it has not been calibrated. As has been proven a larger TB does nothing for you so if you did indeed go larger you may want to consider throwing the OE back on, or doing the hard work necessary to recalibrate it including opening up the housing and turning the screw out as needed.
    If you are using the OE TB then if you did drop it there is your issue there.
    If nothing has happened to it since the install then it is indeed probable that you just have a defective unit. If your unit is good then check the pins and the wiring to it. Make sure you didn't punch it anywhere along the way. @BenMara.
  16. Dec 30, 2020 at 12:32 PM
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    @BenMara
    Throw another stock 70mm throttle body on it and test. If the problem goes away, then it narrows down to the harness plug/pins or wiring harness.
    I know another guy had offered already, but I have a stock TB you can use to test with. Let me know if you want it shipped out.
  17. Dec 30, 2020 at 12:38 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Eddie, we haven't met yet but based on our previous interactions you are one of this topics MVPs when it comes to being helpful as far as replacement parts and one offs are concerned.
    jamesepoop and SUMOTNK[QUOTED] like this.
  18. Dec 30, 2020 at 12:57 PM
    BenMara
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    It's the stock one, it was totally disconnected from the manifold. Never dropped. The only thing I did was coolant bypass.
  19. Dec 30, 2020 at 1:05 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Why did you do a coolant bypass? I'm wondering if that is causing you issues.
  20. Dec 30, 2020 at 1:13 PM
    SUMOTNK
    Eddie
    Thanks for the compliment Rob! The reality is I'm a poor troubleshooter compared to you guys and tend to throw parts at a problem as an attempt to fix it. Not economical nor efficient but complementary to the real troubleshooting advice/tips given by the bigger brains in this thread!
