TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Apr 20, 2018 at 11:54 PM
    #3361
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    I can you to fix the links to the pictures please John. :)
  2. Apr 21, 2018 at 12:12 AM
    #3362
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    How do I do this?
  3. Apr 21, 2018 at 5:48 AM
    #3363
    FinnJ
    FinnJ Well-Known Member
    Finland
    2007 FJ Cruiser 6M/T
    TRD SC, UCON, CNG conversion, RC 6" (lifted 4"/3" air suspension) w/FOX 2.5, 315/70R17 Duratracs, RECARO seats, etc.
    There was the balance drillings in my Torque-U flywheel.
    I changed the clutch (Centerforce Dual-Friction) few weeks/2k miles ago, along with a new slave cyl and URD sleeve/TO bearing. First it tended to slip a little, then it started to hold well, but now it won’t disengage well when cold. After warming up it’s ok. The clutch pedal feels ok, no extra play and it start to hold at the right spot. Should I do something or just drive more break-in?
  4. Apr 21, 2018 at 11:40 AM
    #3364
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    FINALLY!!! Back in the world of the living. I’ve been on a training exercise with no phone/internet access. Looks like i missed quite a bit the past few weeks...gotta get caught up
    Roostfactor, oni06, jojotoo and 2 others like this.
  5. Apr 21, 2018 at 11:41 AM
    #3365
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    Welcome back, brother!
    Skootter14[QUOTED] likes this.
  6. Apr 21, 2018 at 11:49 AM
    #3366
    Skootter14
    Jeremy
    Glad to be back!
    Spent the last 3 weeks in the desert at ft irwin, ca. TONS of awesome Baja trails in the open that I had zero access to living out of a hmmwv for 3 weeks.
    I wish it wasn’t a 20+ hour drive from WA haha, I’d be out here monthly running the truck.
    Biscuits likes this.
  7. Apr 21, 2018 at 3:23 PM
    #3367
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    I would start small on the nozzle. My small nozzle was rated for up to 400hp. Next size up was good to 600hp. I would t-tap off the washer fluid line if you insist on using that tank. Then you could benefit from the low level light the washer tank already has.
  8. Apr 21, 2018 at 4:31 PM
    #3368
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Is it true only Canadian models have the low wiper fluid light? I’ve never seen one on my truck.
  9. Apr 21, 2018 at 4:33 PM
    #3369
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Mine doesnt and its a canadian model :anonymous:
  10. Apr 21, 2018 at 4:33 PM
    #3370
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I keep mine topped off. Never realized there was a light. :notsure:
  11. Apr 21, 2018 at 5:15 PM
    #3371
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Just checked the manual. No mention of a low fluid indicator. Sounds like another project to plan on doing. :D
    7M0919376 sensor $2 rockauto
    7M0919382 grommet $2 rockauto
    1J0973202 pigtail $10 eBay
    Just need a little wiring and an LED mounted somewhere. :thumbsup:
    @GT7
  12. Apr 21, 2018 at 5:26 PM
    #3372
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Send me the IMG links in a private message and I'll fix it for you.
  13. Apr 21, 2018 at 5:31 PM
    #3373
    Biscuits
    God damn dude, why aren't you working for Toyota? :thumbsup:
    Roostfactor likes this.
  14. Apr 21, 2018 at 5:31 PM
    #3374
    GT7
    Grant
    Phoenix
    2013 DCLB
    The kit comes with one
    loginfailed[QUOTED] and Biscuits like this.
  15. Apr 21, 2018 at 5:36 PM
    #3375
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Sweet! Didn't know that!
  16. Apr 21, 2018 at 5:39 PM
    #3376
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Did you get the kit with the tank or without?
  17. Apr 21, 2018 at 5:41 PM
    #3377
    GT7
    Grant
    Phoenix
    2013 DCLB
    Without, havent set it up because I got a new afr sensor and of course it doesnt fucking work. So I need to return it
  18. Apr 21, 2018 at 5:42 PM
    #3378
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    So the non-tank kit comes with the level sensor? Nice!
  19. Apr 21, 2018 at 5:43 PM
    #3379
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    What're ya'll running for boost gauges. I need to get a new one and they all go way further than necessary
    Roostfactor and loginfailed like this.
  20. Apr 21, 2018 at 5:46 PM
    #3380
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
