TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Apr 22, 2018 at 10:27 AM
    #3401
    ThomasMore66
    Dallas/Fort Worth & Durango
    Is yours back in? You started this...
    loginfailed and Roostfactor like this.
  2. Apr 22, 2018 at 10:27 AM
    #3402
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    I lost mine so :notsure:
    loginfailed likes this.
  3. Apr 22, 2018 at 10:29 AM
    #3403
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    I put mine back in yesterday because I thought I was hearing some knocking at initial throttle when it used to not be there. Then again my plugs are shot to shit and in need of replacement so it could be a combination of things.
  4. Apr 22, 2018 at 10:29 AM
    #3404
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You can use welding tips as a substitute.
    It really isn't a huge deal unless you are having lean tip in issues.
    loginfailed and GT7[QUOTED] like this.
  5. Apr 22, 2018 at 10:36 AM
    #3405
    ThomasMore66
    PITA to put back in.
    loginfailed and GT7 like this.
  6. Apr 22, 2018 at 10:39 AM
    #3406
    12TRDTacoma
    Rob
    Concordia
    Boosted
    It is?
    I mean if you got big hands it is. You know what they say about big hands... ;)
    :p
  7. Apr 22, 2018 at 10:40 AM
    #3407
    ThomasMore66
    Big gloves?
  8. Apr 22, 2018 at 10:42 AM
    #3408
    12TRDTacoma
    Rob
    Concordia
    Boosted
    That's right! Ahahaha.
  9. Apr 22, 2018 at 10:53 AM
    #3409
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    You could always leave the restrictor out of the valve, cut the vacuum line where it is easily acceptable, and add a restrictor there. Make sure you have tight connections on it to prevent vacuum leaks.
    loginfailed and 12TRDTacoma[OP] like this.
  10. Apr 22, 2018 at 10:55 AM
    #3410
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    Bitch mitts.
    Masshole19 and 12TRDTacoma[OP] like this.
  11. Apr 22, 2018 at 10:56 AM
    #3411
    Roostfactor
    TX panhandle
    I had mine out yesterday when I had my sc off for 640cc injectors. I drilled half way down the restrictor with a 1/16" drill bit. I figured it still has the small orifice but less restriction since that restrictor is about 1/2" long.
    Truck is running bitchen!
    Norton, GT7, jojotoo and 3 others like this.
  12. Apr 22, 2018 at 11:06 AM
    #3412
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I don't believe tip in issues should exist if you are properly tuned on your truck, but since most of us do not have a solid and stable tune the issues appear with it removed. Of course like I was saying it may not be everyone who is experiencing that issue.
    I got the 2.5 so there is already a lot more speed on the pulley since it is smaller and a lot of extra boost that otherwise normally doesn't exist with the bigger pullies.
  13. Apr 22, 2018 at 11:17 AM
    #3413
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I took my restrictor jet back out after installing the 640cc injectors. Haven’t noticed the lean tip in that I did before.
  14. Apr 22, 2018 at 11:23 AM
    #3414
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You are tuned also though right?
    loginfailed[QUOTED] likes this.
  15. Apr 22, 2018 at 11:26 AM
    #3415
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    640 UCON S3 tune
  16. Apr 22, 2018 at 11:28 AM
    #3416
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Ah yeah, so I believe removing the restrictor if you have mods only amplifies the shortcomings of the 455cc injectors and the incredibly rich TRD tune. If you are tuned right and have the proper fueling support you should have no issues running restrictor off especially with lean tip in issues.
  17. Apr 22, 2018 at 12:04 PM
    #3417
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I decided on a SpeedHut gauge, anyone know what the difference between all of the AFR gauges they have. Some say AEM, some Innovate, but to my knowledge all those use the LSU 4.9 sensors anyway so what's the deal
  18. Apr 22, 2018 at 12:05 PM
    #3418
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    The different controllers have different output voltages / slopes or whatever. Just get the one that matches your wide band controller.
  19. Apr 22, 2018 at 12:05 PM
    #3419
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    I just recently ran my windshield wiper fluid tank empty, and there was no warning light. 2014 TRD Sport DCSB
  20. Apr 22, 2018 at 12:08 PM
    #3420
    Speedytech7
    Ah okay that makes sense. Hmm I wonder if I can get an AEM wideband controller minus the gauge, really the only thing I would want other than being able to view the AFR instantly would be the output feature for linking with a piggyback or logger.
