TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jan 29, 2021 at 2:48 PM
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    To summarize, the "wrong" ones are indeed the correct ones for supercharged applications?
    And the "correct" ones are the right ones for NA ?
    dpanibratets[QUOTED] likes this.
  2. Jan 29, 2021 at 3:11 PM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    That is correct.
    Stating the right ones are wrong when in fact they are right for us boosted guys could lead to dangerous problems. I'm sure Rob is rolling over is his ban grave right now and would jump on this if he could.
  3. Jan 29, 2021 at 3:14 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    @PhoS found this. Extremely beneficial for the guys pushing the upper limits, needing more resolution and duty cycle from their MAF sensor, while not having to rescale anything.
  4. Jan 29, 2021 at 3:35 PM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    That doesn't make sense to me. If the new sensor is not maxing out in the smaller housing then it's scaled wrong in the ecu. Nothing to do with resolution.
    Athlaos likes this.
  5. Jan 29, 2021 at 4:30 PM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    @TodayWasTHeDaY I am going with the FRS Torsen. I already bought one, it'll sit on my shelf for a while longer I think (less money going around in my business now which means less moneys for re-gear and such). There is a phrenulum inside the differential that interferes with the FRS torsen that the driveline shop with have to clearance for me, and I'll have to get a machine shop to drill out the holes to attach the ring gear. Overall should be a lot cheaper than the $1000+ CAD carrier that @BassAckwards linked to, so I'll be happy enough. When it comes to AWD, I will look into that for the future - would be a pretty awesome overall upgrade, for now I'll do it in stages.
  6. Jan 29, 2021 at 4:47 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    The original sensor maxes out in the OEM 3". This sensor does not.
    It is has a higher duty cycle in g/s for a 3" tube because it is for vehicles which make more HP in OEM trim. They flow more.
    This is also me assuming that the OEM tubing size that comes with the MAF listed above, is actually a 3" as well.
  7. Jan 29, 2021 at 5:00 PM
    TodayWasTHeDaY
    Russ
    Calgary
    The input to the ecu is a simple 0-5 volts I believe. A different sensor may send out a different voltage for the same flow but the ecu will see the wrong value in that case unless the ecu upper range value (at 5v) is changed.
    The sensors range is different and the ecu has to be adjusted to match.
    I could be wrong though...
    Paging @JustDSM
    JustDSM likes this.
  8. Jan 29, 2021 at 5:00 PM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    There is no duty cycle on a MAF. It's simply a heated element that the ECU supplies current too to maintain a specific temperature. The voltage that is required to maintain that temperature is used in a lookup table (that we're all familiar with now) which the ECU then reports as airflow (in g/sec).
    The two MAF's "flow" the same, one has a smaller orifice to sample the incoming air (ie: lower resolution). This would be the Subaru/Mazda MAF 197-6040. See below:
    Our stock MAF is identical, except it has a larger orifice to sample the air charge (higher resolution). The larger orifice means that the ECU reaches it's 5v capacity at a lower airflow, but is more sensitive to smaller changes in airflow. Seen below:
  9. Jan 29, 2021 at 5:14 PM
    JustDSM
    Justin
    Ogden, UT
    100% accurate!
    Spot on! These MAF's will require a different voltage to maintain the sensing element's temperature with identical air charges being sampled. This will require a different MAF calibration curve to account for. You'll have to redefine what the airflow amount is for a given voltage. Just as you would if scaling for a larger housing with the original MAF.
    I'd say you were pretty spot on brother!
  10. Jan 29, 2021 at 5:20 PM
    TodayWasTHeDaY
    Russ
    Calgary
    Thanks Justin!
    I deal with industrial sensors a lot so there's a lot of parallels. A sensor is usually a 'dumb' device and something else has to process and interpret the the signal, in this case the ecu.
  11. Jan 29, 2021 at 6:42 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    I just got the TRD Sport edition. LSD in the back and option for all wheel when I need it.
    I don’t know why anyone would want all wheel drive all the time
  12. Jan 29, 2021 at 6:52 PM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    Rally ready taco?
  13. Jan 29, 2021 at 7:07 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Because I didn’t leave 4wd for a week and a half. Made me wonder why I dropped 3mpg for this tank
  14. Jan 29, 2021 at 7:15 PM
    TodayWasTHeDaY
    Russ
    Calgary
    Speaking of lsd (trippy) I ordered a truetrac the other day so pretty excited to get that installed whenever it arrives! Be real nice to have a mechanical lsd and not a half assed computer controlled one.
    Also have an afe momentum scoop to install on my bastardized magnum intake and piles of wiring projects to keep me busy. Fun times.
    rheath08, BassAckwards and Athlaos like this.
  15. Jan 29, 2021 at 7:24 PM
    Athlaos
    Leigh
    Edmonton
    answer: Canadian winters. Or, one just has too much torque all the time. Or both.
    mr.trd and TodayWasTHeDaY like this.
  16. Jan 29, 2021 at 8:00 PM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    Looks good! So orange! Next stop gears.
    jamesepoop[QUOTED] likes this.
  17. Jan 29, 2021 at 8:15 PM
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    I was gonna guess someone talking up GM or Dodge. Usually gets him fired up lol
  18. Jan 29, 2021 at 8:33 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Where'd you get it from? Been wanting a truetrac for my 86 pickup.
  19. Jan 29, 2021 at 8:41 PM
    TodayWasTHeDaY
    Russ
    Calgary
    I did it through east coast gear supply. Price was a little more than urd but I got a master install kit with bearings/shims and marking compound and a dial indicator. Everything I need minus a third member gasket.
    nudavinci64, mr.trd, rheath08 and 2 others like this.
  20. Jan 29, 2021 at 9:15 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    have trutrac and scoop. would reccomed, 5 stars.
