TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Apr 23, 2018 at 7:52 PM
    #3461
    N/Es06
    N/Es06 Well-Known Member
    06 icons inchworm rotrex
    Yea the 65mm was no good. On the 76 I turned the "idle" and sealed the TB and adapter plate with some HT RTV. A/F guage is still wonky. It tries to hang around 14.7 but fluctuates between high 13s to mid 15s. Good news is whatever happened the other day with the OBDll code hasn't come back yet. Driver side sounds loud though like what I imagine valve chatter would be and I think I got an exhaust leak on the driver side as well. :censored:
  2. Apr 23, 2018 at 7:55 PM
    #3462
    N/Es06
    My bad. No there wasn't any silicone or gasket.
    Yes I did.
    Roostfactor[QUOTED] likes this.
  3. Apr 23, 2018 at 7:57 PM
    #3463
    N/Es06
    I think I've experienced limp mode. Could you describe it please?
    And no D!*k jokes.lol
  4. Apr 23, 2018 at 8:16 PM
    #3464
    jojotoo
    jojotoo Well-Known Member
    Brandon
    Socal
    2015 DCLB
    Lol .. no power when you step on the peddle.
    Roostfactor likes this.
  5. Apr 23, 2018 at 8:18 PM
    #3465
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Just like no power when you need to, um you know limp mode from :proposetoast:
  6. Apr 23, 2018 at 8:34 PM
    #3466
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Did you word it verbatim like @oni06 said? :D
  7. Apr 23, 2018 at 9:01 PM
    #3467
    ThomasMore66
    Dallas/Fort Worth & Durango
    My 70 mm is on its way. You guys are discouraging...
  8. Apr 23, 2018 at 9:05 PM
    #3468
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Mine worked fine. If only my ovtune would load on my handheld:annoyed:
  9. Apr 23, 2018 at 9:16 PM
    #3469
    ThomasMore66
    Waiting to purchase the OV.
  10. Apr 23, 2018 at 9:17 PM
    #3470
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    No sir, it conveyed our irritation, and the inconvenience of money being pulled from our accounts for a non existent purchase and then waiting for the refund to show back into our account. Also noted the fact that its happend twice in the span of a few days, and also happend about a year ago and needs to be addressed.
  11. Apr 23, 2018 at 9:23 PM
    #3471
    GT7
    Grant
    Phoenix
    2013 DCLB
    Not too impressed but Im patient. He hasnt ever emailed me back or ever acknowledged me. @White lightning boosted has a very similar experience.
    I will say without a doubt as frustrated as I have been at times with URD products, they are better then this.
    Norton, Roostfactor, Biscuits and 2 others like this.
  12. Apr 23, 2018 at 9:37 PM
    #3472
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Yeah, urd has frustrated me too. Only gives me one sticker per order.
    Konvict KROG, JuanitoBonito and oni06 like this.
  13. Apr 23, 2018 at 9:49 PM
    #3473
    racebug68
    racebug68 Well-Known Member
    Travis
    Chandler, AZ
    05 DCLB 4x4 TRD SPORT SILVER
    I can't leave anything well enough alone
    This. I want to know more details please! With the additional fuel pressure, I would think that you get quite a bit more margin out of the TRD injectors. According to an online calculator, a 455cc/min injector at 43.5psi will act like a 512cc/min injector at 55psi. At 38psi, it is equivalent to 425cc/min. How is the TRD tune handling the closed loop and open loop AFR? I can completely believe that the TRD injectors run out of room with std fuel pressure and boost that is nearly double compared to what they were designed to handle. But with rising pressure...
    Want to know what the duty cycle is on the top end, whether the AFR at cruise and light throttle (still in vacuum) is impacted with the lower fuel pressure. And what are the short term and long term fuel trims doing? Most importantly, what is the situation after driving it around for a few weeks? Please let us know!
    Overall request - is the TRD tune in it's overly rich initial condition good at keeping up with the higher boost engine's demands when the fuel pressure is varied according to vacuum and boost? And not just at idle and full throttle, gotta know about the regular drivability.
    It seems like this could be a sweet spot with the smaller pulley, yet not adding complexity and cost associated with the other methods of getting more fuel.
  14. Apr 23, 2018 at 10:41 PM
    #3474
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Fuck me man......this dont sound promising at all!!!
  15. Apr 23, 2018 at 10:45 PM
    #3475
    GT7
    Grant
    Phoenix
    2013 DCLB
    Im willing to bet the tunes are good. With futher updates like he has talked about, they should keep getting better.
    We will see. Instead of nagging him, I want to see what happens. I sent him two emails, because I forgot to mention all of my mods in the first email. That was 6 days ago. :popcorn::playball:
    Norton, jojotoo, Roostfactor and 2 others like this.
  16. Apr 23, 2018 at 10:52 PM
    #3476
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Good call @GT7 let's see.
  17. Apr 23, 2018 at 10:56 PM
    #3477
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Im sure the guy is swamped to all hell.....but time will tell i guess huh
  18. Apr 23, 2018 at 11:03 PM
    #3478
    N/Es06
    I've been needing to invest in a clutch lately. Unfortunately the hydro bearing has been out of stock for at least a couple months now. I e-mailed URD and Gadget told me his machinist is getting two new knees. I'm not sure if he is sincere and the guy's getting surgery or if he's implying his machinist is slacking and will be needing new knees.
  19. Apr 23, 2018 at 11:36 PM
    #3479
    12TRDTacoma
    Rob
    Concordia
    Boosted
    This was something I was looking at when I was doing my initial calculations when switching to the 2.5 pulley while using the 455 injectors, which is why I never sweat using them in that combination when I did, as long as I boost referenced it, that is.
  20. Apr 24, 2018 at 2:15 AM
    #3480
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    I’ll let you know once I pull it out and drive it. It’s still in the garage right now. Finishing up some exterior stuff. But I will drive it for some time and let you know about the afr and I’ll have to check the fuel trims and the injector duty cycle.
