TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Feb 5, 2021 at 10:38 AM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    It is downstream. +1 to this.
  2. Feb 5, 2021 at 10:47 AM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    So should I just not do nothing because I’m switching to longtubes and hp? If I do the sensor swapped to try to replicate it, is it the 2 rear sensors (the ones plugged into the y-pipe?)
    I always get confused. The way I’m understanding it is the front 2 sensors are flow sensors and the rear 2 are the o2 sensors.
  3. Feb 5, 2021 at 10:54 AM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    P0420 is a pretty harmless code. Get the long tubes and HPtuners installed. They are great mods :thumbsup:
  4. Feb 5, 2021 at 11:03 AM
    zippsub9
    Halfmoon, NY
    14 DCLB
    both are o2. The ones just after the exhaust valves existing the engine are also called upstream since they are before or upstream of any converter and get an untainted registration of the exhaust. The ones after the first set of cats are sometimes called downstream. Not all vehicles have multiple sets of cats. The downstream tell you how well the cats are working for obvious reasons. The upstream are what your engine makes adjustments off of for fueling and efficiency in general terms.
  5. Feb 5, 2021 at 11:23 AM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Gotcha. So then to check cat vs sensor to replicate the code, am I doing this downstream or up?
  6. Feb 5, 2021 at 11:32 AM
    zippsub9
    Halfmoon, NY
    14 DCLB
    this is a downstream code, after cat. Minor issue. Swap them in the y-pipe to confirm if it is the sensor or the cat.
    JuanitoBonito[QUOTED] likes this.
  7. Feb 5, 2021 at 12:13 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    To complement for clarity for all, the front ones (pre-catalytic converters, and also AKA upstream sensors) are named WRAF sensors. Wideband Ratio Air Fuel sensors. Piezoelectric sensors.
  8. Feb 5, 2021 at 12:56 PM
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    I’m also pretty sure the UCOM EMS allows one to not worry about o2 sims as the UCON does all the calculating and sends fade data to the OEM ECU.
    someone can verify or fact check me haha
    BassAckwards likes this.
  9. Feb 5, 2021 at 1:26 PM
    ARoman83
    ARoman83 Well-Known Member
    Alex
    Wisco
    '15 TRD OR DCSB PreRunner
    Only legal stuff
    Get rid of it!!! :anonymous:
  10. Feb 5, 2021 at 1:32 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    Upstream yes, downstream no
  11. Feb 5, 2021 at 2:06 PM
    findingthingsout
    findingthingsout Well-Known Member
    midwest
    08 Tacoma TRD O/R A.C. MT
    Boost, armor, lights, big tires, no savings.
    ???I'm running UCON, no sims here. Up and down present. Catless headers and Y-pipe. I added Hi Flow cat after Y pipe.
  12. Feb 5, 2021 at 2:20 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    Them I stand corrected. It must piggyback both altogether.
  13. Feb 5, 2021 at 2:23 PM
    findingthingsout
    midwest
    I had thought the downstream ones could be removed when I original installed the UCON. Figured they just checked the condition of the cats and could be deleted/ spoofed in code, but ended up having to reconnect.
    zippsub9 likes this.
  14. Feb 5, 2021 at 2:51 PM
    Amo-cat3
    Amo-cat3 Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    per Gadget at URD you still need the secondary o2 sensors for the system to function properly. Even though youehave sims there is still feedback the ecu needs.
    mr.trd and zippsub9 like this.
  15. Feb 5, 2021 at 4:50 PM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    A note about sims VS using hptuner software to disable the CEL. If you use sims you will pass an OBD2 emissions scan. If you disable the check engine light then the monitors will read as not ready, which is no good for places like California. YMMV so just throwing that out there.
    nudavinci64, TireFire and JasonLee like this.
  16. Feb 5, 2021 at 4:52 PM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Yup.....I get 1 “incomplete” or “not ready”. That will be used on the Sai
    JasonLee and Murphinator[QUOTED] like this.
  17. Feb 5, 2021 at 5:16 PM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Thank you! This is correct.
    There is also one more option (which is of limited practical use). You can disable the CEL from illuminating if the code pops up, and still keep the monitors functioning. However, if you do trip the code you'll still fail for obvious reasons but you won't have to have the light glaring at you.
    Murphinator[QUOTED] likes this.
  18. Feb 5, 2021 at 5:20 PM
    Skootter14
    Jeremy
    you mind taking a pic of your headers/cat/ypipe set up?
  19. Feb 5, 2021 at 6:01 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    as i understood the sims worked well unless you have a 2015 truck. can confirm they did no help on mine. id just go hp tune for said solution.
  20. Feb 5, 2021 at 6:35 PM
    TacoJova
    TacoJova Well-Known Member
    Central Oregon
    21 Ram TRX Sold 2015 White DCSB Offroad
    Supercharger Hybrid audio stage 3 and stage 2 rear with 2 image Dynamics IDQ10's and alpine amps Bilstein 5100 with OME 887 Dakars and Icon 2.0 in the rear URD SPEC U Headers URD Y Pipe Borla muffler 18" Magnaflow Resonator Morimoto fogs
    Sims didn’t work for mine either
