TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Feb 13, 2021 at 7:31 AM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Not sure what you’re trying to argue but cool
    Yes there is a conversion plate out there. Seen it in the past when I contemplated the swap. Worst case I can have the hubs drilled to the 6 lug bolt pattern.
    TheFang likes this.
  2. Feb 13, 2021 at 8:00 AM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    Well, if it can do this then I’m in!!
    JuanitoBonito and BassAckwards like this.
  3. Feb 13, 2021 at 8:13 AM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Eggsactly! 10.5” ring gear, 36 spline semi float axles. Sorry for calling it a “one ton”
  4. Feb 13, 2021 at 10:46 AM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    There is a delay buzzing sound after attempting to crank and not fire. What could that be? Sounds like it’s coming from the engine bay
  5. Feb 13, 2021 at 10:58 AM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    are you sure you dont have low voltage? check your battery.
  6. Feb 13, 2021 at 1:03 PM
    TRON
    Engine cranks and turns over just fine. But will not fire and start on cold starts. If I turn key “ON” for a minute before cranking it usually starts up.
    rheath08[QUOTED] likes this.
  7. Feb 13, 2021 at 1:11 PM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    Any trouble codes?
  8. Feb 13, 2021 at 1:16 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    I'd check simple things like ur gas cap seal and fuel reg before tearing into the tank.
  9. Feb 13, 2021 at 1:42 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    I was talking about the 5lug Tundra axle
  10. Feb 13, 2021 at 1:43 PM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    My dam p0420 code came back this morning after deleting it with the scanner, driving, and long idle warm ups for a week.
    TodayWasTHeDaY likes this.
  11. Feb 13, 2021 at 7:52 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    I know, just noting usually see them with converted 6 lug.
  12. Feb 14, 2021 at 6:39 AM
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    RH cat.
    Kind of funny. I would reset the code (mine was p0430) and drive the truck for a couple days before the light would come on. My cat was completely gone. As in absent. It disintegrated and went out the pipe.
    henryp and JuanitoBonito[QUOTED] like this.
  13. Feb 14, 2021 at 9:27 AM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    In case you need some engine break in advice, this is what my engine builder has to say!
    Norton, JasonLee and BillDaCat8 like this.
  14. Feb 14, 2021 at 9:31 AM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    guy living in 2077 with dat variable stroke engine.
    Darkgoatracer, Torspd, henryp and 3 others like this.
  15. Feb 14, 2021 at 9:33 AM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Yeah I was rather hopeful. After putting in drive and idle time. I got to thinking it might just stay off. Funny thing is, both times the light came on, it was on the way home from work on a cold weekend morning.
  16. Feb 14, 2021 at 9:35 AM
    JustDSM
    Justin
    Ogden, UT
    Boy oh' Boy, his wife is probably truly upset. She probably has Virgin territory since he never gets up to speed.
    nudavinci64, TireFire, Torspd and 7 others like this.
  17. Feb 14, 2021 at 9:37 AM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    wonder what the guys thoughts are on static speed engines. is it redline or normal?
    TacoJova and JustDSM[QUOTED] like this.
  18. Feb 14, 2021 at 9:42 AM
    TacoJova
    TacoJova Well-Known Member
    Central Oregon
    21 Ram TRX Sold 2015 White DCSB Offroad
    Supercharger Hybrid audio stage 3 and stage 2 rear with 2 image Dynamics IDQ10's and alpine amps Bilstein 5100 with OME 887 Dakars and Icon 2.0 in the rear URD SPEC U Headers URD Y Pipe Borla muffler 18" Magnaflow Resonator Morimoto fogs
    Lol on one of my f80 groups a guy went as far to take off valve covers for a simple spark plug replacement. Sometimes I don’t know if it’s trolling or legit cause he had pictures and everything
    nudavinci64 and JustDSM[QUOTED] like this.
  19. Feb 14, 2021 at 9:47 AM
    BillDaCat8
    Jake
    PHX
    I just hope he doesn’t vote!
    Torspd, Norton, SUMOTNK and 1 other person like this.
  20. Feb 14, 2021 at 9:54 AM
    rheath08
    Russell
    Bakersfield, CA
    I just can't...:smack:
    Norton, SUMOTNK and JustDSM[QUOTED] like this.
