TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Feb 18, 2021 at 8:59 PM
    Kini
    Kini Well-Known Member
    Alaska
    2008 FJ Cruiser
    Hey, I got a brand new URD 2.8 you can have for shipping costs.
    ARoman83, TVH475[QUOTED] and SUMOTNK like this.
  2. Feb 19, 2021 at 6:17 AM
    TVH475
    TVH475 Well-Known Member
    Montrose CO
    That's awesome, but I ordered everything yesterday. Much appreciated!
    Kini[QUOTED] likes this.
  3. Feb 19, 2021 at 7:49 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  4. Feb 19, 2021 at 7:58 AM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
  5. Feb 19, 2021 at 7:58 AM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
  6. Feb 19, 2021 at 8:11 AM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
  7. Feb 19, 2021 at 8:22 AM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Since the VCT solenoid is a Pulse Width Modulated (PWM) solenoid that regulates oil pressure into and out of the phaser (adjustable intake cam gear), the only thing this can really do is alter that oil flow by having the ports repositioned from OE locations and/or increasing/decreasing the port volume there by changing the intake cam timing and rate of change assuming the port volume is altered.
    If you don't have ECU access, this is a way that you could tweak the VVTi mapping, albeit crudely, as there's no way to know how much of a change you're making by altering the port timing/sizing.
    If you do have ECU access, you're probably better off telling the ECU what cam angles you want, and when.
  8. Feb 19, 2021 at 8:22 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Hard to say. Read through the PDF, and they use a stronger spring and magnet. Might also have a change in the ports. We assume quicker reaction and higher pressures used.
  9. Feb 19, 2021 at 8:25 AM
    smelly621
    smelly621 Well-Known Member
    SF Bay Area
    2011 AC TRDOR 6MT
    It's DLX son!
    Will this give me vtec all the time?
    henryp and JustDSM like this.
  10. Feb 19, 2021 at 8:27 AM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    I kind of think of it like in my ford powerstroke. To make it easy for explaining the oil pump does both the lubrication and fueling. On the fuel side the oil applies pressure to the injectors. More pressure equals more fuel and more fuel means more power. In the 1gr the vvti has fixed rates or how far and fast it'll work so I'm not sure honestly how it'll respond. It could be positive or could equal zero. I haven't looked hard at it as I'm trying to warm up in tx but thought it was cool to share.
  11. Feb 19, 2021 at 8:28 AM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Vanos all tyme
    smelly621[QUOTED] likes this.
  12. Feb 19, 2021 at 8:42 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Q/C hubs and pulleys are designed to work/fit together. Unless something's changed URD's 2.8 pulley is a standalone solution, that's incompatible with a Q/C setup. How do you plan to mix/match these things?
  13. Feb 19, 2021 at 8:44 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    URD's quick change pulley perhaps?
    TVH475 and Norton like this.
  14. Feb 19, 2021 at 8:49 AM
    Norton
    I forgot they offered that. Showing my age, I guess. :anonymous:
    Do they also have other size Q/C pulleys for their hub, or is their hub the same config as Smoothflow and Pulley Boys?
    TVH475 and Torspd[QUOTED] like this.
  15. Feb 19, 2021 at 8:55 AM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    https://www.urdusa.com/supercharger-pulleys/
    TVH475 and Norton[QUOTED] like this.
  16. Feb 19, 2021 at 9:02 AM
    nudavinci64
    Robert
    yah big and red and URD specific which is a bummer since the others are a bit interchangeable to some point (with some shims)
    Norton[QUOTED] likes this.
  17. Feb 19, 2021 at 9:36 AM
    Norton
    Thanks, guys. I haven't spent much time or money on URD stuff in recent years because I prefer less "conspicuous" pulleys and Gadget's become such a curmugeon.
    SUMOTNK and Torspd like this.
  18. Feb 19, 2021 at 9:40 AM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    You showed your age again lol
  19. Feb 19, 2021 at 9:44 AM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Um, do I make a boomer joke or na?
    TodayWasTHeDaY likes this.
  20. Feb 19, 2021 at 9:46 AM
    Norton
    You're welcome to, but a Gen X joke would be more appropriate.
