TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Feb 24, 2021 at 7:17 AM
    Camby
    Camby Well-Known Member
    Brian
    Denver
    2006 Tacoma TRD Off-Road
    Magnuson Supercharger TRD CAI Catch Can After market dual exhaust Heated Mirror Kit Install Aftermarket Head and Tail lights Several accessory Mods
    Same here. I really wish we could customize the appearance of the gauges
  2. Feb 24, 2021 at 7:31 AM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    I’m just surprised to see it erase itself.
  3. Feb 24, 2021 at 7:44 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    The cold can do funky things. Expansion, contraction. Density. Heat time after start-up. Etc
    I learned that in my tune, my air temp enrichment table, when around 25° F and lower, is pulling fuel. I was at first thinking something was wrong with the truck. Warmed up to 30° F+ and AFR's back to normal.
    Norton and JuanitoBonito like this.
  4. Feb 24, 2021 at 7:57 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    @JuanitoBunito is your secondary air pump still working as intended? It runs on start-up to help heat up the cats for more efficiency, so if it's not working (or in race / off-road mode), maybe that is causing the occasional error.
  5. Feb 24, 2021 at 8:22 AM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Yup still working as usual......both times I threw the code was on my way home from shift.....not right away either. Like 6-8 miles after leaving the firehouse. Also, I warm up my truck for 10-15 before I even leave
    JasonLee likes this.
  6. Feb 24, 2021 at 9:54 AM
    henryp
    henryp A member of TW
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    I hosed off the right cat after spilling coolant on it (I relocated my intercooler reservoir). Temp dropped to -10 (from 40s) overnight and threw same code, this was a few years ago. Never had another cat code again.
    JuanitoBonito[QUOTED] likes this.
  7. Feb 24, 2021 at 10:02 AM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    That’s good to hear.....I’m thinking it was just the frigid cold air we had. I’m switching to long tubes anyways but it was still frustrating
  8. Feb 24, 2021 at 10:10 AM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
  9. Feb 24, 2021 at 12:40 PM
    ARoman83
    ARoman83 Well-Known Member
    Alex
    Wisco
    '15 TRD OR DCSB PreRunner
    Only legal stuff
    Was it after you washed your truck?
  10. Feb 24, 2021 at 12:40 PM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    When the computer see that the code has not set for "X" amount of drive cycles it will turn the light off, but the code will still be stored. It should rease the code after "XX' drive cycles without detecting the fault.
  11. Feb 24, 2021 at 12:51 PM
    henryp
    Henry
    Montana
  12. Feb 24, 2021 at 1:15 PM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    1 time I think. But if I remember correctly both times I pulled my truck into the bay for the night to get it out of the cold for the night. Then on the way home 3/4 of the way home on a 9-10 mile drive it popped on both times. Both times it was crazy cold. Today will driving to work in 40 degree weather, I noticed the 2 lights weren’t on anymore. Check engine/trac off
  13. Feb 24, 2021 at 1:16 PM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Yeah I remember reading that......now I’ll have to see if it comes back
    rheath08[QUOTED] likes this.
  14. Feb 24, 2021 at 2:35 PM
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
    henryp[QUOTED] likes this.
  15. Feb 24, 2021 at 2:43 PM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Belt......still good!!
    JustDSM, Norton and jamesepoop like this.
  16. Feb 24, 2021 at 3:05 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Sorcery!!!
  17. Feb 24, 2021 at 4:45 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    That, or a lack of (dealership) ass-hattery. :D
    JuanitoBonito likes this.
  18. Feb 26, 2021 at 1:55 PM
    racebug68
    racebug68 Well-Known Member
    Travis
    Chandler, AZ
    05 DCLB 4x4 TRD SPORT SILVER
    I can't leave anything well enough alone
    never thought I'd see the day when this thread didn't have any responses for 2 days. End of an era I guess. Or are all of you power boosters going over to some other location to continue the discussion? BookFace is not for me...
    SUMOTNK and jamesepoop like this.
  19. Feb 26, 2021 at 2:18 PM
    Norton
    I think the thread's fearless leader remains in Mod-imposed exile. Many decided to join him in "another location" for the duration.
  20. Feb 26, 2021 at 2:21 PM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    He's done his jail sentence day in a day or two. There's been a small group on dischord and it's mostly just three or four people chatting.
