TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Mar 8, 2021 at 11:20 AM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    From what I have heard you cannot do solid trans with out solid motor mounts. Once you do solid motor you are good to go with a solid trans mount.
    I think with solid mounts you will get a little bit more vibration but the truck will put down the power a lot better.
    Hope this helps.
    12TRDTacoma[OP] likes this.
  2. Mar 8, 2021 at 11:28 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Definitely helps. Thanks guys. I know it'll transfer more into the truck.. but at this point.. I feel it would be pretty minimal in the grand scheme of things. The truck is just loud and squeaks, and rattles already. I just want to keep this from happening again and gain the performance benefit with the solid mounts.
    So.. then I should JUST get the motor mounts.. and leave the trans alone. Is this the general thinking.. or because I'm running the valve body @Lucario Runner ?
    Murphinator[QUOTED] likes this.
  3. Mar 8, 2021 at 11:28 AM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    DMZ solid motor and trans. Just do it all at once and be done. Makes a major improvement
    Torspd, 12TRDTacoma[OP] and JasonLee like this.
  4. Mar 8, 2021 at 11:32 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    was gonna go with Bonzens mounts. The Solid Offroad mounts. I'd prefer not to do the Trans if I dont have to.. just because of the valve body. It's already violent and hard enough. lol
  5. Mar 8, 2021 at 11:35 AM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Are you running one of the spicy trans tunes? Could always dial that back some. Personally I’d do them all so things are solid
    nudavinci64 likes this.
  6. Mar 8, 2021 at 11:39 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Well I just looked up the DMZ ones.. and I dont see a full kit. Just gussets.
    and no, the Valve Body is a beast on its own. Its shifted hard since day one. thats why I DONT want to solid the trans..it might be too much? :notsure:. I look at it as software vs hardware.. I already have the hardware to make it shift hard.. IDK how more hardware on top of that would react.. if that makes sense.
  7. Mar 8, 2021 at 11:52 AM
    henryp
    henryp A member of TW
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    So you cracked your crank case? There must be some epic wheeling story behind that.
  8. Mar 8, 2021 at 12:02 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    It could have happened during a few instances honestly..
  9. Mar 8, 2021 at 12:03 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Yeah they’re not on his website I don’t think. The gussets are for 2005-6 models only. He’s got solid mounts for motor and trans, just need to call. I’ve heard mixed reviews about fitment from various other companies but these were perfect. Did hear that bonzens were too as well though.
  10. Mar 8, 2021 at 12:04 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Pretty standard stuff here. Mine cracked back in 2015 and I've been running JB Weld on it ever since. No problems. Lol.
    Normally I'm not a fan of those type of repairs but given it's location and how stupid it sounds like it is to replace I'll just stick my JB fix.
    TheFang and henryp[QUOTED] like this.
  11. Mar 8, 2021 at 12:06 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Never solid mount the trans but not the motor. Unless you like broken bell housings.
  12. Mar 8, 2021 at 12:06 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Got ya. I'll compare pricing. Talking to Bonzen now.. possibly might get some expedited.. otherwise itll be a couple weeks, which isnt terrible I guess. It's just gonna be sitting at their shop.
  13. Mar 8, 2021 at 12:07 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    thought about that route too.. they even mentioned it. hmmm.. IDK, with my luck.. it'd fail. quickly too. :rolleyes: I think its better just to truly replace it and do the motor mounts while I can.
    :thumbsup:
  14. Mar 8, 2021 at 12:08 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Its the cheapest option and doesn't add in complexity to the driveline angle. I have the brozen mounts on both my 1gr trucks
    Torspd and XPOTRPR[QUOTED] like this.
  15. Mar 8, 2021 at 12:09 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    good to know.
  16. Mar 8, 2021 at 12:45 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
  17. Mar 8, 2021 at 1:45 PM
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
    Negative no pics, I had it on turbo Subaru. I know I removed it wheni traded in for Taco. Ill have to look around
  18. Mar 8, 2021 at 1:59 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Solid Offroad Motor Mounts ordered. should be here later this week.. and the truck will get buttoned up then as well. Hoping they can work with me on labor cost.. since I just took it to them last Friday to get this fixed.. paid 400 bucks.. for it to still leak. So basically because they didnt do their due diligence.. I paid for a 400 dollar oil change. I trust them and have used them for years now, so I'm sure they'll take care of me.
    jamesepoop and Torspd like this.
  19. Mar 8, 2021 at 2:00 PM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    I went Dirt Designs got engine and auto tranny. Pretty damn nice price point if you ask me and they had them in stock. Nice units. Total pain in the ass install, but that’s true of all of them.
  20. Mar 8, 2021 at 2:10 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Dude if I did it in the sand dunes with several napkins and a container to drain the rest of the oil out of the oil pan then you can do it too without it failing. It won't fail as long as you use Quiksteel or Steelstik. You basically do one layer let it cure a while and then apply your second one over that.
    Seriously, my repair of it was that on the spot on the fly, because I had no other option. I drove it over 200 miles straight home after I let it cure for like an hour and fifteen minutes. Lol. It works and that's all that matters.
    jamesepoop and JasonLee like this.
