TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Mar 16, 2021 at 1:41 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Do you want to pay $30 per plug just to run Ruthenium? If yes AND you want to run 8s it requires A. Higher horsepower levels (think 400+) and B. A very precise wideband AFR logged tune.
    Colder plugs produce more hydrocarbons which translates directly to more misfires. You will likely take a fuel economy hit and the plugs may foul quicker as their self cleaning properties would not be as good since you don't have the power levels to support them.
    I ran 8s once upon a time, and I was not particularly happy with them, so I went back to the IKH-22s at the time. If you want to pay cheaper but not exactly pound for pound a 100% match to OE style (but still works obviously) but be Rutheniums go with the NGK 95125s. Yeah sure they are made for VWs, but they are correct in every aspect including reach and thread pitch. They just have a funky look on the top of them. You know how those Germans roll.
    The Ruths that I run now self cleanse pretty darn well and now that I am 100% AFR sensor tuned for HPT, they should last that much longer. I'll see about pulling one in about 5-10K miles just to see how they are looking.
  2. Mar 16, 2021 at 8:19 AM
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    Help me understand this. Spark plugs don't create hydrocarbons - hydrocarbon is already there in the form of gasoline and your engine isn't a distillation column. Can't make more or less of it.
    I'm assuming you're meaning that the lower heat range of the colder spark plugs in low temperature applications (i.e. engines that operate at lower RPMs and thus produce less heat) is more likely to create carbon fouling on the plug. Less heat is available to keep the carbon from depositing on the spark plug tip. The opposite would be true of a colder spark plug in a high heat application: the higher temperature of an engine that operates at high RPMs is sufficient for a more efficient burn of the hydrocarbon, thus reducing the creation of carbon fouling on the spark plug. In either a high or low RPM (heat generating) engine, there is a limit to the spark plug heat range that can be efficiency used.
  3. Mar 16, 2021 at 8:55 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I agree with what you are explaining. If you were to throw a vehicle on a 5 gas analyzer with the incorrect heat range for the engines power levels it's making you would find a elevated level of HCs being reported due to its colder heat range in comparison to a vehicle that has the appropriately matched plugs for its power levels. The presence of more porcelain vs less (I'm pretty sure that's what it was, I may have it backwards) on the plug is doing a better job at drawing away heat from the combustion chamber doing a better job at keeping it cooler in result lowering the amount of HC output at the tailpipe. HCs are indicative of misfires and the less you have usually the better fuel economy you get. Maybe I explained it in an incorrect wording, but you get the idea anyway.
    Also, HCs are not measured as fuel, that's measured as CO (raw fuel) on the analyzer just to clarify in case you confused the two.
  4. Mar 16, 2021 at 9:21 AM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    no plans to run those but was curious what benefit they would have if any besides the hole in my wallet.
  5. Mar 16, 2021 at 9:31 AM
    nudavinci64
    Robert
    turns out they are Dough Thurley not JBA so no Carb OE.
  6. Mar 16, 2021 at 9:58 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    YET. They will be soon, however, confirmed as of today per my phone call to them. ;)
    JasonLee likes this.
  7. Mar 16, 2021 at 10:09 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    im pausing on the making the truck CARB approved since I am in Colorado.... I don’t want to do anything irreversible though.
  8. Mar 16, 2021 at 10:35 AM
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    Clarification please? Did jba or DT tell you that their shorties with carbEO will be re-released soon?
  9. Mar 16, 2021 at 10:37 AM
    SUMOTNK
    Eddie
    If I was i CO and had the remote possibility of moving to CA.... I would get long tubes (or EL) headers and keep the stock exhaust manifolds intact. Slap the stocks back on if you come back to CA.
    ARoman83 and JasonLee[QUOTED] like this.
  10. Mar 16, 2021 at 11:24 AM
    JasonLee
    15 TRD OffRoad
    Yeah, I’m not touching or cutting up the stock exhaust.
  11. Mar 16, 2021 at 11:28 AM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    What's a stock exhaust?
  12. Mar 16, 2021 at 12:03 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Why go F/I just to push air through 4 stock cats? :rolleyes:
  13. Mar 16, 2021 at 12:05 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Like farting through a straw. Lol
  14. Mar 16, 2021 at 12:14 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    JBA can piss off. They abandoned us and left us to die. Doug Thorley will be picking up what JBA dropped and be the new provider for CARB compliant shorty headers. They are just waiting for the state to approve their full generation extension to allow the 2012-2015 SAI provision on the shortys for compliancy.
  15. Mar 16, 2021 at 12:35 PM
    nudavinci64
    Robert
    If I was not in CA I would go LT for sure. Its not irreversible as you can always put in your stock ones. They connect to factory Y if you want that. If you replace you can keep the factory Y as well. cutting or not it can all be reversed. The shorty's when they come from now DT will be carb compliment so if you cut them up they still have the factory cats so your good to go.
    Lets see how long it takes to make them CA legal. I tried 2 different places to get them this past week and all failed. I put in an order last night to auto anything but that likely is going to get canceled as well. (unless they have mystery ones laying around).
    - Robert
  16. Mar 16, 2021 at 12:44 PM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    When I ordered mine from autoanything they shipped quick. That was a few years ago but maybe you will get lucky.
  17. Mar 16, 2021 at 12:47 PM
    nudavinci64
    Robert
    yah hasn't been canceled yet. Maybe they had a hoard of them. All other places say discontinued and had my order canceled. If i get it cool if not prob better to have DT since it will be supported still.
    Murphinator[QUOTED] likes this.
  18. Mar 16, 2021 at 12:51 PM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    usually, they are a drop shipper. hoping it goes well for you
    12TRDTacoma[OP] likes this.
  19. Mar 16, 2021 at 12:53 PM
    nudavinci64
    Robert
    yah figured as much. I do not have high hopes but it was worth a shot. JBA needs to figure it out because a ton of shops still "sell" it. Doesn't seem like it's being updated anywhere.
  20. Mar 16, 2021 at 1:16 PM
    JasonLee
    15 TRD OffRoad
    Because I’m still farting, and that’s better than being NA.
