TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Mar 17, 2021 at 3:04 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Why would you want to go back to ucon?
  2. Mar 17, 2021 at 3:05 PM
    jojotoo
    jojotoo Well-Known Member
    Brandon
    Socal
    2015 DCLB
    maybe I ask why you’re considering going back to UCON ?
  3. Mar 17, 2021 at 3:06 PM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    Read his username
  4. Mar 17, 2021 at 3:07 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    same went from n/a to boost and its fine thanks to @JustDSM
    BassAckwards likes this.
  5. Mar 17, 2021 at 3:21 PM
    TVH475
    TVH475 Well-Known Member
    Montrose CO
    Well my 2.8 pulley Tacoma runs pretty damn good, but not new mustang good! Ol'boy was pretty surprised I was still close to him though!!!
    smelly621 and BassAckwards like this.
  6. Mar 17, 2021 at 4:03 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Lol yeah it might seem like a dumb question but ive been having head gasket issues with the other truck so i am definitely curious if everyone is happy in the long term. I am loving the HP tune so far, just looking for some more safety features for the engine since its now back to being the daily
  7. Mar 17, 2021 at 4:04 PM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    which is having a HG issue?
    BassAckwards[QUOTED] likes this.
  8. Mar 17, 2021 at 4:05 PM
    BassAckwards
    Im super paranoid so the guardian feature would be nice to have. Also the adaptives can dial in the AFRs for the 625ml/min of water meth im spraying. Mainly just a safety thing and i was considering a 2.8 pulley and my truck is HP tuned for the 2.5 right now so UCon could dial that in too
  9. Mar 17, 2021 at 4:06 PM
    BassAckwards
    The damn 4 cylinder. Already have the head off and had it resurfaced. Waiting on the new head gasket and toyota fipg to put it all back together
    rheath08 likes this.
  10. Mar 17, 2021 at 4:07 PM
    BassAckwards
    Touché:rofl:
  11. Mar 17, 2021 at 4:08 PM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    take a straight edge to the block?
  12. Mar 17, 2021 at 4:12 PM
    BassAckwards
    No sir sure havent, but the truck has never even been overheated. The gentlemen at the machine shop said the head looked great and it didnt take much for him to true it up so im hoping the block is good. Its iron too, so it has that going for it. I am definitely gonna take a straight edge to it before i reassemble though. Best to go from one corner to the other when checking right?
  13. Mar 17, 2021 at 4:27 PM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Check every which way you can think of. A warp can present itself in many ways.
  14. Mar 17, 2021 at 4:42 PM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    Was the UCON actually built with meth in mind? I'm wondering if the adaptives are compensating for the different afr values of meth vs gas? Both have different afr values so the readings when meth is sprayed get skewed. If you tune for a good gas afr value WITH meth spraying at the same time it's not a good thing. @JustDSM brought that to my attention before.
    The two options are:
    Tune safely for gas and then add meth for cooling and more power.
    Or tune on a dyno and have fail-safes installed so you don't grenade your engine if the spray stops.
    Athlaos and BassAckwards[QUOTED] like this.
  15. Mar 17, 2021 at 5:16 PM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Iron blocks can still twist. Not saying that's what going on for yourself but just something to look at. Corners yes but also look around the bores. Simple straight edge and flashlight can help determine either it's true or not. Did the shop tell you how much much they took off and have a gasket to compensate the difference? Did you get new head bolts or studs?
  16. Mar 17, 2021 at 5:51 PM
    BassAckwards
    Will do, thank you for the advice!
    I'm not sure, i would venture to say no as far as the design goes. I dont think the sensors would be adjusting based on gas or meth but rather only gas.
    That is a very good point, but it always runs richer than in the 11s at WOT so i dont think there is a big issue as far as the tune goes, but i could definitely see how that could be a no no if you tune to be dependent on it and then something in the system fails. Scott told me at one point that the UCon was pulling around 20% fuel on the WOT adaptive when the water meth was spraying. I think with my truck the UCon targets a 10.5:1 AFR because of the overall load on the motor. It used to be around 11.5 that it'd target when i had a larger pulley on it, but when i dropped a size and reset i guess it passed that engine load/target AFR threshold. Definitely some good food for thought though
    Thanks for the heads up, i will definitely give things the evil eye before reassembly.
    Yes, i told the shop to take .010" off and i took the old gasket in and it measured to .020". The new gasket i ordered is .030" so it should work well. Yes i did upgrade to ARP head studs so hopefully this gasket will last longer than the 5k that the other two did
  17. Mar 17, 2021 at 6:16 PM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    I'm pretty sure honda bond is the same. Hit up your local honda power sports shop. It is an item they keep on the self. I used it on the front timing cover on my engine. I think it make more power now.
  18. Mar 17, 2021 at 6:22 PM
    mightytacoman
    Kel
    4.5L 1grfe
    Would recommend copper coat on the head gaskets before installing too.
  19. Mar 17, 2021 at 6:24 PM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    if you need a hand in reassembly lmk
  20. Mar 17, 2021 at 6:46 PM
    BassAckwards
    Thanks brother, will do
