TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Apr 5, 2021 at 2:18 PM
    findingthingsout
    findingthingsout Well-Known Member
    midwest
    08 Tacoma TRD O/R A.C. MT
    Boost, armor, lights, big tires, no savings.
    So they are just modding the position with a spacer instead of rotating the body? That means they'll sit taller off the valve cover and possibly have more conflicts? Thinking about the supercharger side...
    BassAckwards and mightytacoman like this.
  2. Apr 5, 2021 at 2:30 PM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    I think the spacer makes it so it is angled for clearance. I’d take the word “spacer” lightly. I believe yes, it is technically a spacer per say but it shouldn’t really raise the height very much. Or......maybe they never took the blower into consideration and they are gonna be long as fuck. o_O....idk.
  3. Apr 5, 2021 at 3:05 PM
    lemon177
    lemon177 Well-Known Member
    Matthew
    Oahu
    09 tacoma 4x4 sport pyrite mica
    TRD supercharger, URD 2.85" stealth pulley, TRD exhaust, TRD intake, DTLT headers, URD y-pipe, TRD boost gauge, PLX DM100 touch with OBDII and SM-AFR modules, 885 OME 3", Icon UCAs, Satoshi grill, Solid rear window, SCS stealth 6, 285/75/17 toyo AT2.
    Guess you really won't be able to change spark plugs with blower still installed. It's already a tight fit to get the coils in/out on the driver's side.
  4. Apr 5, 2021 at 3:36 PM
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
    Stock coils... easy....
    lemon177[QUOTED] likes this.
  5. Apr 5, 2021 at 8:35 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    All of you guys are high. I run the Ripp coils and have had zero issues with removing them even with the blower installed when doing spark plugs. It's really not a big deal and actually it's easier with the Ripps because of how the boots are flexible instead of rigid like the OE ones are.
    jamesepoop likes this.
  6. Apr 6, 2021 at 5:01 AM
    findingthingsout
    midwest
    Maybe so, we want to get "Ripped" like you!
    There's a joke in there somewhere...
    12TRDTacoma[OP] and jamesepoop like this.
  7. Apr 6, 2021 at 6:35 AM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    I am also running the ripp packs not designed for this motor with no complaints.
  8. Apr 6, 2021 at 11:16 AM
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    Yeah just get high on a can of this when you install the coils. You'll be good.
  9. Apr 6, 2021 at 2:36 PM
    lemon177
    Matthew
    Oahu
    Might wanna talk to a doctor about that
  10. Apr 6, 2021 at 3:24 PM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    Anyone running the gesi high flow cats?
    After putting on a set with shorties I have cat efficiency faults for both banks.
    Is there special tuning required?
    The retailer said they can't do anything for me.
  11. Apr 6, 2021 at 3:34 PM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    The sensitivity of the system so tight. You have a couple of options. If you’re tuned, you can go that route. If not it’s up the Sims
  12. Apr 6, 2021 at 3:38 PM
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    I ran the vibrant GESI hi flows for forced induction on my DT shorties with no problems. No tuning required
  13. Apr 6, 2021 at 4:35 PM
    rheath08
    Russell
    Bakersfield, CA
    I got the GESI G-sport 50025 less than a week I get this surprise. So much for EPA approved.:frusty:
  14. Apr 6, 2021 at 8:20 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Sure you don't have exhaust leaks?
    12TRDTacoma[OP] likes this.
  15. Apr 6, 2021 at 8:53 PM
    rheath08
    Russell
    Bakersfield, CA
    I have replaced the gaskets at the y-pipe and it still came back. The doughnut at the cat back is new, but I see water leaking during cold starts. that one is well after the cats and the secondary o2 sensors though.
    Torspd[QUOTED] likes this.
  16. Apr 7, 2021 at 8:56 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Just run low profile spark plug anti foulers of the stainless steel variety. I have them installed in both of mine and my light of the CE disappeared forever despite my one failure. :thumbsup:
    Make sure you get that leak addressed unless you don't care. If it is post downstream o2 then no harm no foul. Otherwise you are good to go.
  17. Apr 7, 2021 at 8:58 AM
    rheath08
    Russell
    Bakersfield, CA
    @12TRDTacoma yes the leak is down streak after the secondary cats.
    I'll look into the anti foulers.
  18. Apr 7, 2021 at 8:59 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I got a set of four accidentally thinking they would only be sold as one. I can send you the link for them if you want. Just make sure you get the low profile, after all, we live where we live.
  19. Apr 7, 2021 at 9:00 AM
    rheath08
    Russell
    Bakersfield, CA
    Sounds good.
  20. Apr 7, 2021 at 11:44 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    yah def curious of fitment then ill order away.
