TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Apr 7, 2021 at 11:46 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    It was pretty obvious just make the hole that connects and moves it to the other side and bam problem solves. I hope its not too tall as for it to clear it would need to be 1/4-1/2" taller.
    JuanitoBonito[QUOTED] likes this.
  2. Apr 8, 2021 at 1:17 AM
    Grape_Salad
    Grape_Salad Active Member
    Oak Harbor
    2021 DCSB TRD OFFROAD ARMY GREEN
    BP-51, Cali Raised Sliders, Safari AIRMAX, UPTOP Alpha
    I have nearly 240k miles on my engine, is an SC not advisable?
  3. Apr 8, 2021 at 5:00 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Did you take good care of the engine? Do you plan to keep the truck?
    12TRDTacoma[OP], Norton and henryp like this.
  4. Apr 8, 2021 at 9:04 AM
    nudavinci64
    Robert
    if its in good shape sure. if not maybe need a few things replaced. there are a few folks with high mileage engines and S/Cs.
  5. Apr 8, 2021 at 9:06 AM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    He need some 10w40....
    henryp, 12TRDTacoma[OP] and Torspd like this.
  6. Apr 8, 2021 at 11:09 AM
    Grape_Salad
    Oak Harbor
    It's in good shape, oil changed every time the light goes off and it had its 200k service. I have no idea how the internals of the engine are. What i don't understand is how to use the tuner, do i need to go to a dyno place? I assume i would buy the tuner version of the magnuson SC?
  7. Apr 8, 2021 at 11:16 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Yes, you would buy the tuner version. The other one has the Bully Dog tune which is not highly regarded.
    You can have someone local flash your ECU, or you can mail it to @JustDSM and he will get you set up.
    As for installing the supercharger itself, if you are not comfortable doing it, a decent shop should be able to read the ~25 page installation instructions and get it done in a day.
  8. Apr 8, 2021 at 11:26 AM
    nudavinci64
    Robert
    The only reason why you WOULD want it potentially is the carb certification for the maggie is tied to the full kit with bully dog tune. No tune no maggie sticker. You can likely get away with the TRD one but depends on the user if your in CA or a state that requires it for others considering it.
  9. Apr 8, 2021 at 11:28 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Get a static compression test. Then, get a cylinder leak test. Make sure the cylinders are within 20 psi variance of each other otherwise your engine fails. Make sure you are within 25-30% leakage maximum on your cylinder leakage test for each cylinder. If those tests pass, you are good to blow.
    Pro tip: If you want to be excessive get a dynamic compression test. You want to see no more 5 psi variance between each cylinder. If you do. Fail.
    If the shop you take it to has no idea what you are talking about on any of these three test events, walk, and go to another.
    ARoman83, henryp and JasonLee like this.
  10. Apr 8, 2021 at 12:01 PM
    Grape_Salad
    Oak Harbor
    I am in CA, so i have to pay extra for a sticker?
    I'll check that out.
  11. Apr 8, 2021 at 12:17 PM
    nudavinci64
    Robert
    You can get a TRD one but if a rep wants to say its not a TRD SC could be an issue. Likely all they want but the updated Magnuson carb sticker is tied to the S/C and Tune itself. I have the Maggie one with the tune (just didn't use it) and it has my serial number on it. If you find a used or shit event new TRD one then you can get the TRD carb sticker that was universal. You could get the tuner kit and get that and if needed get the tune later on. I think you can do that if needed.
  12. Apr 8, 2021 at 12:35 PM
    Grape_Salad
    Oak Harbor
    Any local people on here from La Mesa area? Trucks my only vehicle so i can't mail it.
  13. Apr 8, 2021 at 12:40 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    Say you got the charger and the sticker and the tune. Then changed the tune... emissions would never know you changed the tune. Just sayin
  14. Apr 8, 2021 at 12:45 PM
    nudavinci64
    Robert
    He has my ECU back in a couple days max it was quick. You can also go to the dealer after you setu it up or have them do it.
  15. Apr 8, 2021 at 12:46 PM
    nudavinci64
    Robert
    yah I do not have the tune its more about having the sticker and how picky they are. Mainly noting the Magnuson uses a different carb sticker than the TRD setup which is tied to the tune they sell. I never bothered even hooking itup but I got my sticker and smog done.
  16. Apr 8, 2021 at 1:23 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    What part of California are you in? They should not have you pay extra for the sticker as far as I'm concerned but if they do it's just a couple bucks and they'll send you one via postal service. Since Magnuson is native to our state the sticker should arrive rather quickly.
  17. Apr 8, 2021 at 1:55 PM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    If you don’t buy the kit with the BD you get no tuner. So basically the sticker costs like $500 I think is the discount for the “tuner” version of the kit (no bullydog included).
    honestly if I were to do it over again I would put the trd sticker on and call it a day. It’s identical aside from the branding.
  18. Apr 8, 2021 at 2:31 PM
    Grape_Salad
    Oak Harbor
    I'm in La Mesa, so you have to buy the regular kit to get the sticker? But don't use the tuner.
  19. Apr 8, 2021 at 2:35 PM
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    I would do this...which is what @Murphinator is also saying.
    1. Buy the maggy tuner kit with no BullyDog.
    2. Procure a TRD sticker with the CARB EO #
    3. Every 2 years, if a smog tech refuses to smog it, just go to a different smog shop.
  20. Apr 8, 2021 at 2:56 PM
    nudavinci64
    Robert
    the new maggie ones do have a serial number now. just FYI. but really comes down to whether they know what to look for. prob wouldn't know if you had the TRD one or not but as @12TRDTacoma noted you could just try different shops
    SUMOTNK and 12TRDTacoma[OP] like this.
