TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Apr 21, 2021 at 1:42 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Yeah I’m glad I didn’t get too sucked down into the s/c mods rabbit hole. I’m still stuck on suspension and everything else
    mr.trd, jamesepoop and henryp[QUOTED] like this.
  2. Apr 21, 2021 at 2:15 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    this is why I wanted the truck operational while you were here.. change that mindset real quick I think. lol
    you'll have to take it for a drive if/when we come up.
  3. Apr 21, 2021 at 2:26 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Happy to do so haha. Or at least get a ride along.
    XPOTRPR[QUOTED] likes this.
  4. Apr 21, 2021 at 3:01 PM
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
  5. Apr 21, 2021 at 3:03 PM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    No idea. I assume so
  6. Apr 21, 2021 at 3:05 PM
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    Looks like it includes the springs is why I was saying good deal. I paid that much for the pro kit with no springs.
  7. Apr 21, 2021 at 3:11 PM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Dam. I bought my Fox pro kit in 2 stages. Fronts then the rears. Together I paid 1100
    ARoman83 likes this.
  8. Apr 21, 2021 at 4:26 PM
    ARoman83
    ARoman83 Well-Known Member
    Alex
    Wisco
    '15 TRD OR DCSB PreRunner
    Only legal stuff
    @JuanitoBunito Did you get your headers swapped yet? I just got my stock headers pulled out, not too bad of a job. Getting the new ones in will be interesting!
  9. Apr 21, 2021 at 4:41 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Pull out the studs.
  10. Apr 21, 2021 at 4:46 PM
    ARoman83
    Alex
    Wisco
    Only legal stuff
    All out. I don't have one-upper titanium studs, just ARP SS lol.
    So do I install the studs after I have the headers lined up? I'm also swapping out the engine mounts. Should help with the install.
  11. Apr 21, 2021 at 4:48 PM
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    That was after the kit was discontinued and no longer readily available. I wanted an original factory set for a time way way down the road. I'd like to install a better mid-travel setup while the trucks in its prime.
    That kit will be purely for aesthetics some day.
    JuanitoBonito[QUOTED] likes this.
  12. Apr 21, 2021 at 5:17 PM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    I plan to keep this Fox set up for the same reasons. My original Baja suspension looked horrible. Still worked great but looked bad. I just pitched it all in the garbage just last week. At some point I’ll get a much better suspension too.
    JacksonTacoma[QUOTED] likes this.
  13. Apr 21, 2021 at 5:19 PM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    I did. A couple weeks ago or so. I wrote about it in my build page.
    RyanL and jamesepoop like this.
  14. Apr 21, 2021 at 5:25 PM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
  15. Apr 21, 2021 at 6:09 PM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
  16. Apr 21, 2021 at 6:17 PM
    jojotoo
    jojotoo Well-Known Member
    Brandon
    Socal
    2015 DCLB
    Insurance paying out $31,500. I paid $32,500, 6years ago. Remove upgrades and re-install stocks. I have till friday.
    I was bit surprised at the estimate .. in a good way.
    Ohh .. they added $200 for my Volks and $400 for Clazzio seat covers.
    Rims are coming off .. they can have the seat covers.
    BassAckwards, RyanL, Norton and 6 others like this.
  17. Apr 21, 2021 at 6:26 PM
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    It's only a few grand. It's okay.
    Nothing like watching the crafts install 200-225' of 30" overhead line made out of monel that has been overlaid with Inconel.
    For the cost of that pipe, you could buy a lot of stuff for your truck.
    Torspd[QUOTED] likes this.
  18. Apr 21, 2021 at 6:27 PM
    Biscuits
  19. Apr 21, 2021 at 6:33 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    Nope! Didn’t fit.
  20. Apr 21, 2021 at 6:35 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    no shit.. sucks when you have to use equally as expensive tooling to cut the expensive material.. and you've got 100+ pieces to do.
