TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Apr 21, 2021 at 6:38 PM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
  2. Apr 21, 2021 at 7:07 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    nudavinci64 likes this.
  3. Apr 21, 2021 at 7:24 PM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Disconnect the steering shaft and loosen the bolts to the starter enough to wiggle it out of the way. It’ll make the driver side much easier.
    ARoman83[QUOTED] likes this.
  4. Apr 21, 2021 at 7:30 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    You can also peek from the wheel well and line them up. Mark and disconnect steering shaft and you should be ok. Maybe remove the starter is another thing that might be needed
  5. Apr 21, 2021 at 9:02 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    I’m here. Yeah. It’s my truck. 2020 just was a bad time.
  6. Apr 21, 2021 at 9:05 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Welcome back!
  7. Apr 21, 2021 at 9:09 PM
    ThomasMore66
    Thank you.
  8. Apr 21, 2021 at 9:11 PM
    ThomasMore66
    It took me awhile to catch up. I didn't know you had seen the video. I talked to @DocME earlier today and I got a hint that the video was out there. What started as new Kelford cams became a problem and we decided to go big. I dunno. It may all go to shit, but we're gonna make a try.
  9. Apr 21, 2021 at 9:17 PM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    What all are you doing or did you do??
  10. Apr 21, 2021 at 9:27 PM
    ThomasMore66
    The motor is out of the truck at EPR in Alvarado, TX and in pieces. It's about to get a full rebuild. Attached is the file sans pricing. You are correct to think this is the most moronic thing you have ever seen for a Tacoma. I don't care. I am concerned that the Magnuson won't be able to feed the rebuild, but we'll find out. Hate away.​
  11. Apr 21, 2021 at 9:39 PM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Holy jeebus can't wait to see where this goes. My only concern on your list is if that ATI damper will fit w/ the supercharger pulley. If it does please let us know!
    Athlaos likes this.
  12. Apr 21, 2021 at 9:46 PM
    ThomasMore66
    We'll see. I saw that and wondered the same. This company builds race motors for quite a few people and I'm a little stoked to have a fully balanced motor with solid motor mounts and forged internals. Bigger valves and total porting have to move more air. The engine is basically an air pump as we have discussed. We will add meth injection and tuning with HPT. We will dyno the truck. I'm ready to have it back.
  13. Apr 21, 2021 at 9:50 PM
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    What's your HP goal? I mean for instant power the maggie is great, but I think it may be a bit small if you are going for big big power. But if you are going for all top end the pro charger may be the way to go. Or slap a snail in there :drool:
    Smokehouse, Biscuits and Torspd like this.
  14. Apr 21, 2021 at 10:06 PM
    ThomasMore66
    Builder says 5-600 is good with this configuration. More requires internal mods. I want to see where we are with the Magnuson. I think Procharger is the next step if the Magnuson can’t flow the air.
  15. Apr 21, 2021 at 10:10 PM
    ThomasMore66
    On another note, I spent Christmas alone in BigBend. It was unbelievable. If you get the chance, do it.
  16. Apr 21, 2021 at 11:52 PM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    No one will hate in this thread or the performance section. The rest of tw on the other hand are too busy adding more LEDs and rtts to appreciate.
  17. Apr 22, 2021 at 3:29 AM
    jamesepoop
    jamesepoop Well-Known Member
    California
    2007 Fj Cruiser
    It doesn't fit. The center of the ATI damper is not wide enough to fit the maggy pulley and the ATI has bolts that hold the damper together. I ordered one before my build @ThomasMore66 and they said they didn't have time to custom make one with the main pulley. That may have changed since 2 years ago when I bought it.
    Biscuits likes this.
  18. Apr 22, 2021 at 3:36 AM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Potentially the fluidampr will be a good fit with the booster if they have enough interested parties.
  19. Apr 22, 2021 at 5:40 AM
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    Wow.
  20. Apr 22, 2021 at 5:46 AM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    The maggy feeds my 4.5L but it's definitely pushing the limit. A procharger or snail would have been a better option. I can push 9-10psi on a 2.3 pulley but that's at the edge of the efficiency Island. With our built internals and the right FI- I would think pushing 16psi or maybe more would be safely possible
