TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Apr 23, 2021 at 7:30 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Since you're building your own... how feasible is it to make two collector sections that you can swap out on dyno day to test out each type?
    jamesepoop likes this.
  2. Apr 23, 2021 at 7:35 AM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    I've run both systems..
    The Spec-U system lost quite a bit of low end torque compared to Roost's setup. Both lost low end torque on a N/A engine, however I think the frequency Roost's Y is tuned for is a better fit for a stock engine and it's RPM operating window. Now, folks with forged rods and pistons enter into a different arena where 6000+RPM operation is possible and desired from a power production standpoint, and the Spec-U system might favor operation in that range. I'm sure Roost or someone with the math to do the calc's could determine the tuned frequency of the Spec-U system and what RPM range that would favor.
    I think the low end lacking with the Spec-U is more a function of the length of the secondary's than the merge. However, I did have issues with the Spec-U merge. It resonated HORRIBLY at a very specific RPM/Load. I know he's since redesigned the Spec-U system as a result of the complaints he got from it.
    I like the layout of the older (what you pictured) Spec-U system, and I think it'll work well and be fairly easy to fabricate while working well for those turning 6K+. However if I was building a system, it would utilize a merge collector like Root's system.
  3. Apr 23, 2021 at 7:46 AM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Make the 2.25 ends slip fit and the 3" a vband set up. Actually wouldn't be hard to accomplish.
    Do you mean this as in for your na motor you would do the 2.25" into 2.5" than cone to 3"
    Or do you mean that is what you would do for my built fi motor were it yours?
  4. Apr 23, 2021 at 7:49 AM
    JustDSM
    Justin
    Ogden, UT
    In general. That design will have an advantage over a the straight merge in terms of exhaust gas velocity with it's venturi
  5. Apr 23, 2021 at 8:37 AM
    mightytacoman
    Kel
    4.5L 1grfe
    Now you really got my thinking of trying both.
    Even for a butt dyno stand point.
    SUMOTNK and JasonLee[QUOTED] like this.
  6. Apr 23, 2021 at 8:40 AM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    with the hptuner you got maf and afr for your points of data x rpm. so it will be quantifiable that way.
    SUMOTNK, Torspd and mightytacoman like this.
  7. Apr 23, 2021 at 9:19 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Has welder, will try. Since you have the resources to be scientific, be scientific. :thumbsup:
    Complementing what @Lucario Runner
  8. Apr 23, 2021 at 9:23 AM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    T-minus 3 weeks. Who’s coming racing? Hopefully I can get the truck done in time.
  9. Apr 23, 2021 at 9:26 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Damn, I would! Get that truck ready!
  10. Apr 23, 2021 at 9:45 AM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Just need to build my shackles this weekend and I can roll the tundra axle under and start fitting it in. I’m hoping I’m done next weekend but I’m sure there will be a few loose ends to figure out
    rheath08 likes this.
  11. Apr 23, 2021 at 11:36 AM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Either way, I am curious to see what comes of this. I am having a shop do some work on my setup here soon. They are big on track cars but not so much Tacomas. If I can give some pointers to the em that would be key. so far I have 2.25 > 3" merge but the roost effect of merge into 2.5 then to 3" curious to that setup (I am on a waitlist for JFR but this will do in the meantime). I likely was going to go with a similar design you noted on the Y. not expecting the same madness as the JFR on this setup. Any other tips I can relay to the shop?
  12. Apr 23, 2021 at 11:38 AM
    JasonLee
    15 TRD OffRoad
    I'm moving onto the next step in my tuning setup process and figured it would be worth asking y'all:
    Do you have a spare HPTuners MPVI2 setup for sale? With or without credits. If I can save a few bucks here, that money goes towards other mods :)
    Or, do you have any functioning HPtuners coupon codes?
    The least expensive MPVI2 with 4-credits (shipped to me in Denver, CO) is from Over The Top Performance ($501.75).
    Edit: $489.95 from Hinson Motorsports. That's a $32 savings over direct from HP Tuners that will go towards an AFR gauge.
    Elphane likes this.
  13. Apr 23, 2021 at 11:49 AM
    nudavinci64
    Robert
    no real discounts on HP tuners that I have seen. There was one shop with slightly lower credits but in general no big sales. I went that route ended up buy @DocME but was a new unit and was buying some other stuff off him.
    JasonLee[QUOTED] likes this.
  14. Apr 23, 2021 at 11:56 AM
    mightytacoman
    Kel
    4.5L 1grfe
    I'm far from an expert so I'm standing on the shoulders of giants here with any info I can provide. Only tip that isn't obvious would be to try and keep things equal length per side.
    2.25" pipe pre merge is preferred.
    3" post merge for fi systems.
  15. Apr 23, 2021 at 11:59 AM
    JustDSM
    Justin
    Ogden, UT
    Summit has the same price as Hinson w/ free shipping.
    https://www.summitracing.com/parts/hpt-m02-000-04
    You can also meet up with some CO folks and use their MPVI2 if you're really looking to save costs.
    Norton and JasonLee[QUOTED] like this.
  16. Apr 23, 2021 at 12:25 PM
    nudavinci64
    Robert
    thanks! yah I am on board there and the basics I have ready. I'm a newb when it comes to exhaust.
  17. Apr 23, 2021 at 12:46 PM
    JasonLee
    15 TRD OffRoad
    Yeah, I still need to find time to meet up with @Norton either way :)
    Norton likes this.
  18. Apr 23, 2021 at 12:55 PM
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    Looks like so much fun. The state just put the kibosh on the sand drags at our dunes until the park gets some kind of permit.....after 50+ years with no permit and very few safety incidents.
    Solo test and tune is authorized but no side by side testing
    SUMOTNK and snowsk8air2[QUOTED] like this.
  19. Apr 23, 2021 at 1:09 PM
    JasonLee
    15 TRD OffRoad
    It looks like SDPC has a package with an AEM X-gauge AFR Wideband for only an additional $100? It looks like buying just a bare X-Gauge is at least $130+ with no sensor.
    https://sdparts.com/i-24132279-sdpcs-hp-tuners-mpvi2-wideband-tuning-kit.html
    Your choice of wideband:
    -AEM X-Series 30-0300
    -AEM UEGO 30-4110
    -NGK AFX 90067
  20. Apr 23, 2021 at 1:18 PM
    JasonLee
    15 TRD OffRoad
    @BillDaCat8 - Are you still running the failsafe gauge? How and what do you have the failsafe functionality hooked up to?
