TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Apr 27, 2021 at 11:47 AM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    I concur. Only time I've used red is on my '06 kick start lever. Bolt kept backing out and the lever would fall off. Not ideal. So glue it on!!
  2. Apr 27, 2021 at 11:55 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Would doing the dowel pin swap require drilling of sorts?
  3. Apr 27, 2021 at 11:57 AM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    Mine required ever so slight use of a rat tail file, and then a square edged file to help the solid pin fit.
  4. Apr 27, 2021 at 12:00 PM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    Make sure to grease the steel sleeve on the crank pulley when installing as per @Torspd wisdom. Helps keep leaky seal from happening.
  5. Apr 27, 2021 at 12:39 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Anyone have meth injection setup?
    Anyone have meth injection setup as a back-up in coordination with a Fail-safe AFR gauge?
    Or does the ECU pull back timing enough while watching the knock sensors?
    BillDaCat8 likes this.
  6. Apr 27, 2021 at 12:40 PM
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    Yeah I wasn't planning on buying the tool anyway. Just feel robbed of weight reduction....(joking)
  7. Apr 27, 2021 at 7:31 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    I always felt if surfaces are even and things are tight enough then none of that stuff is really needed, maybe locking washers beneath the nuts and a washer or two to keep things true, but that's it. Thread locker has its uses no doubt, but I can almost count on my hands how many times I have actually used it. Outside of that never any issues unless I forgot to out a series of washers on or the actual surface requiring fastening wasn't level, but as long as you get peace of mind from it then that's all that matters. I have felt uneasy by using certain things before so I know what that feels like. Lol.
  8. Apr 27, 2021 at 7:44 PM
    JasonLee
    15 TRD OffRoad
    I am still getting set up with my tuning setup worked out, but I have a laptop with HP Tuners VCM suite now (no MPVI2).
    Can someone DM me a log file to open and get familiar with VCM Scanner?
    Also, could someone send me a tune file for a 1GR Tacoma so I can start to get familiar with the VCM Editor?
  9. Apr 27, 2021 at 10:47 PM
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
  10. Apr 28, 2021 at 5:51 AM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Kick ass model train or a better pump...damn I'ma let the coin decide for me.
    jamesepoop, SUMOTNK and Athlaos like this.
  11. Apr 28, 2021 at 5:59 AM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Sent. Though you wont be able to open the calibration in the VCM editor until you have an MPVI2 plugged in.
    JasonLee[QUOTED] likes this.
  12. Apr 28, 2021 at 6:11 AM
    TodayWasTHeDaY
    Russ
    Calgary
    SUMOTNK[QUOTED] and Athlaos like this.
  13. Apr 28, 2021 at 6:58 AM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    Hmm. I already have two stock pumps in parallel, but methinks if I had two of these upgraded pumps in parallel it would be very close to twice the flowrate of a single stock pump.
  14. Apr 28, 2021 at 7:14 AM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Now I see why you needed 2 Coolant tanks
  15. Apr 28, 2021 at 7:16 AM
    JasonLee
    15 TRD OffRoad
    Anyone have a temperature sensor on the inter cooler or coolant lines? Or just watching the IAC temps drop when doing these upgrades?
  16. Apr 28, 2021 at 7:30 AM
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    Roost did and posted his analysis somehwere in this thread or maybe his ypipe thread at one time. He reported that the intercooler does pretty well at maintaining temps for its size.
    Norton and JasonLee[QUOTED] like this.
  17. Apr 28, 2021 at 7:32 AM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Do you worry the coolant may flow too quickly and cool less due to not spending enough time in the LTR?
    Norton likes this.
  18. Apr 28, 2021 at 7:33 AM
    Athlaos
    Leigh
    Edmonton
    No but I should really get one.
    JasonLee[QUOTED] and Murphinator like this.
  19. Apr 28, 2021 at 7:33 AM
    Athlaos
    Leigh
    Edmonton
    No I don't worry because it's proven that the big radiator at the front does an excellent job of cooling the fluid. Also I have a supplemental radiator anyways.
  20. Apr 28, 2021 at 7:35 AM
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    TodayWasTHeDaY likes this.
