TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. May 2, 2021 at 11:06 PM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    I, stupidly, thought everything was painted until I went in for a closer look
  2. May 3, 2021 at 12:33 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    That's a pretty typical rookie mistake. It has happened to the best of us before. ;) :D hahaha.
    Kelvin[QUOTED] likes this.
  3. May 3, 2021 at 1:57 AM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    all good to know. I will only be deleting the downstream cats to keep it somewhat legal. I have a set of hopefully one-day legal DT shorty headers ill be mating to the stock ones upstream. So just pop the stock o2 sensor into the pipe and good to go? Do I need to run anything on HP tuner at this point or just if I had them deleted up top?
  4. May 3, 2021 at 6:36 AM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
  5. May 3, 2021 at 7:49 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Sounds like they've taken cues from Toyota's 3.0 V6 from back in the day. :der:
  6. May 3, 2021 at 8:10 AM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Or the current gr yaris
    Norton[QUOTED] likes this.
  7. May 3, 2021 at 8:21 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Gut, don't delete. Don't intentionally make things complicated for yourself down the road bro.
  8. May 3, 2021 at 10:10 AM
    nudavinci64
    Robert
    It won’t be.
  9. May 3, 2021 at 10:13 AM
    nudavinci64
    Robert
    what did you do to have no restriction just no cats? I want to have enough "guidance" when I go back to the exhaust shop.
  10. May 3, 2021 at 10:55 AM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    The merge point is/was shit sized at about 2.25-2.5". I made it a true 3".. still collecting data on if its better but a true equal length system should do good with a little bit of restriction. As for the video I said I would take of the sound-it sounded so different in the clip I took- I felt it wasn't an accurate representation.
  11. May 3, 2021 at 11:24 AM
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    Got the ZZP IC pump installed and powered up. The plug fits uncomfortably loose even when pinching the clips narrower before connection. Had to use a ziptie to "squeeze" the clips so it remains secure.
    I looked at the swirl tank after. Cant tell if thats a good indicator of more flow volume but the coolant whirlpool didnt look like it was spinning faster.
  12. May 3, 2021 at 11:50 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I understand that completely.
    Years ago, on a few people's trucks with the URD y-pipe, I influenced them (after having done it myself) to remove the outlet flange which was there to bolt to an OEM or aftermarket catback. That merge had a 3" section that then reduced quickly to what was a 2.5" outlet. Taking that flange off and making it a 3" outlet, changed the tone that it was easily evident something was different to a bystander.
    It was also enough to make an improvement, if I remember correctly, on the TRD s/c truck that had it done. Looong time ago on that. Pretty sure a before and after dyno was done. All vague at this point. After that. Many mufflers were added. Lol
    jamesepoop and SUMOTNK like this.
  13. May 3, 2021 at 11:52 AM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Good example at 9:30 mark
    https://www.youtube.com/watch?v=7jNZ4IGi3ME
    disappointing about the connector, maybe that's feedback they need to hear.
  14. May 3, 2021 at 1:41 PM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    Now that I'm a novice welder I am planning on adding a V-Band to the URD pipe and adjusting my exhaust as you describe.
  15. May 3, 2021 at 1:43 PM
    Athlaos
    Leigh
    Edmonton
    I feel it's deceiving to look at the flow in the reservoir. With two pumps in parallel I have to be flowing around 30% faster than stock, but looking at the whirlpool that's not obvious. Even when I compared it to my friend's which has one stock pump, I was like hmm... it has to be flowing faster but it doesn't really look like it.
  16. May 3, 2021 at 2:26 PM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
  17. May 3, 2021 at 2:58 PM
    Athlaos
    Leigh
    Edmonton
    This is the page I was looking at, ya. I originally thought I was comparing points 1 and 3, but upon re-reading it, if the head stays the same, then flowrate is approximately doubled - I would assume on these systems that both suction and discharge head remain approximately the same when two pumps are in parallel, so flowrate should be about doubled - although with some additional losses from extra piping and such, probably more like a 80-90% increase.
    JustDSM[QUOTED] likes this.
  18. May 3, 2021 at 3:12 PM
    findingthingsout
    findingthingsout Well-Known Member
    midwest
    08 Tacoma TRD O/R A.C. MT
    Boost, armor, lights, big tires, no savings.
    If you do gut, I would try to get a through-pipe installed to avoid unwanted sounds and a hindrance to flow with all the added turbulence in the enlarged vessel.
  19. May 3, 2021 at 3:25 PM
    Kelvin
    Kelvin Wheeeeee
    I mean to be fair if they put that engine in the new Bronco I’d probably have one ordered by now :anonymous:
  20. May 3, 2021 at 4:18 PM
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    Hp tuners
