TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Apr 28, 2018 at 8:24 PM
    #3681
    ThomasMore66
    Dallas/Fort Worth & Durango
    I’m thinking double cardan for my vibe solution. Mine’s more of a 1500 rpm thing.
  2. Apr 28, 2018 at 8:27 PM
    #3682
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Mine is in between you and login’s kinda. Ill get a ford 9” hopefully then figure it out
    Speedytech7 likes this.
  3. Apr 28, 2018 at 8:38 PM
    #3683
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    I did disconnect my boost/vac gauge from the boost port and connected it to the inlet side and didnt see any noticeable vacuum to indicate a restriction but that was also with the 2.7 pulley. I am now running a 2.5. It's also hard to tell without a datalog to plot. I was just looking at the gauge as I applied throttle.
  4. Apr 28, 2018 at 9:30 PM
    #3684
    racebug68
    racebug68 Well-Known Member
    Travis
    Chandler, AZ
    05 DCLB 4x4 TRD SPORT SILVER
    I can't leave anything well enough alone
    I'd be very interested in that. Would be a good improvement for anyone that doesn't have a UCON...
  5. Apr 28, 2018 at 9:35 PM
    #3685
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    I dont have UCON, nor am i intending on getting it....at this point, OVtune either. What would doing the cam gears do for me? What degree would be best? Or how would i know what one i should get?
  6. Apr 28, 2018 at 9:36 PM
    #3686
    GT7
    Grant
    Phoenix
    2013 DCLB
    3 degrees like the ucon’s
    Slight volume metric efficiency gain
    Roostfactor likes this.
  7. Apr 28, 2018 at 9:58 PM
    #3687
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    @Torspd
    This is what I'm talking about:
    Roostfactor and loginfailed like this.
  8. Apr 28, 2018 at 10:35 PM
    #3688
    mr.trd
    mr.trd Are you Recreationally Insane?
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Icon coilovers w 14" 700lb springs, Icon billet UCA w/ Delta joints, custom built Icon rear resi-shocks, Icon stage 3 rear leaf pack, Archive Garage Hammer Hangers w/ homemade spreader bar, superbumps up front and timbren bumps in the rear, Crown brake lines, U-bolt flip,4.88's with front ARB locker and ARB dual compressor mounted behind back seat, 285/75R17 BFG A/T KO2's on Bronze Icon Alloy Compression's, 5th gen T4R budget big brake kit, CBI Off-Road Fab. custom Trailmaster 2.0 with swing-away tire carrier, CBI custom tube front bumper, CBI kickout sliders, CBI full flat belly skids including gas tank,CBI Ditch Light brackets w/ Heretic Studio Quattro's, Heretic Studio's 30" Amber on the front, Heretic Studio 40" bar under the Front Runner Roof Rack, Expedition Essentials RAM mount, Leer used shell, OEM black chrome sport headlights, fog lights always on mod, rear locker anytime mod, TRD supercharger, URD Ucon-EMS, Deatschwerks 255 fuel pump w/ URD external fuel filter kit, AFE intake paired to a Safari Snorkel, URD spec-U exhaust w/ factory Tundra muffler behind URD equal length headers.
    Well I guess it is a good thing I like to change my oil. Question is, is it really possible that I am really that rich or is the Innovate that far off? What would be a good number for my long term and shirt term fuel trim?
    Also what would you suggest I use as a tune? If I wanted to keep it simple? Uni-chip? Ucon? Haltech?
  9. Apr 28, 2018 at 10:36 PM
    #3689
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I doubt the stock ECU would ever let anything get that rich. Would be targeting a really low AFR. It's usual thought isn't to throw more fuel at things, when it gets overwhelmed it just pulls timing.
    12TRDTacoma[OP] likes this.
  10. Apr 28, 2018 at 11:16 PM
    #3690
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    In open loop, there isn't any feedback. That is the definition of Open loop. With the inconsistency of the TRD reflash, combined with that elevation, it is probable and very likely happening as such for him.
    @mr.trd could swap in another gauge to cross reference accuracy, but I have my money on the fact that there would be a negligible difference. Innovate gauges work well.
    "Simple" only applies against something less simple. The simplest of the aftermarket tuning solutions, which uses effectively closed loop the whole time, is the UCON.
  11. Apr 29, 2018 at 12:17 AM
    #3691
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    It is my suggestion that @mr.trd installs a Denso first, as I do not trust the fact that he has to calibrate the sensor every single time or whatever frequency he was.
    Hey bud, try replacing the sensor first. If you are still receiving error code 8 (I was getting the same code) than the gauge is just a POS, much like mine was.
    What version sensor are you using? Bosch LSU 4.2 or 4.9? I have listed LSU 4.9 sensor part numbers and their compatibility in a link within the very first post of the page. If you have a 4.2, I have no solution for you as I have not looked into that version sensor replacement in the Denso brand. Yes they are plug and play. The one I used required breaking a small tang inside the sensor connector. After that it was all good, and fully plug and play. Still working amazing to this day. No calibration needed, EVER with my AEM X-Series gauge.
  12. Apr 29, 2018 at 5:54 AM
    #3692
    Biscuits
    Any thoughts on the AFR behavior in my video above?
    loginfailed likes this.
  13. Apr 29, 2018 at 6:09 AM
    #3693
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Ha!
    Mine is 6300 lbs
    Roostfactor and 12TRDTacoma[OP] like this.
  14. Apr 29, 2018 at 8:59 AM
    #3694
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Anyone know what happened to the. 4.0L ovtune thread?
  15. Apr 29, 2018 at 9:00 AM
    #3695
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Looks a little on the lean side at the end of first gear, but at that point boost is only 4psi so it might be ok? @Torspd
    The rest of the pull, it never gets over 12:1 AFR except near the end of third it gets to 12.5 for a brief moment. Could be running out of fuel or just might be the TRD flash. I forget, are you still running the stock fuel pump?
  16. Apr 29, 2018 at 9:05 AM
    #3696
    Biscuits
    Negative. DW255 with a 320 awaiting install. I started observing this phenomenon a few months ago, but since I hardly drive my truck I have procrastinated on doing anything about this.
  17. Apr 29, 2018 at 9:08 AM
    #3697
    StOrMyThEtAcO
    StOrMyThEtAcO @stormythetaco
    Cody
    CO
    18 TRD Sport mom bus
    All of them
    12TRDTacoma[OP] and loginfailed like this.
  18. Apr 29, 2018 at 9:08 AM
    #3698
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
  19. Apr 29, 2018 at 9:16 AM
    #3699
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    This is why I originally installed a fuel pressure gauge. It sucks when you don’t know. You are on TRD flash, right? Maybe try temporarily boost referencing the fuel pressure regulator and do a few pulls to see if it changes the AFR at all.
    Get you one of these and your choice of fuel pressure gauge.
  20. Apr 29, 2018 at 9:35 AM
    #3700
    Biscuits
    Thanks man. I know you're right about the fuel pressure gauge. I also have a new fuel filter to swap in as well and was going to see if that helps.
    Regarding the boost reference, I haven't paid too much attention to it to be honest. If the AFR changes, what does that indicate?
