TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Apr 29, 2018 at 10:05 AM
    #3701
    ThomasMore66
    Dallas/Fort Worth & Durango
    “Or nitrous systems..,”. Boom!
    loginfailed[QUOTED] likes this.
  2. Apr 29, 2018 at 10:29 AM
    #3702
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    The FPR mod increases fuel pressure as boost goes up. If fuel pressure goes up, AFR should be a little richer.
    Here’s the quote from the first post
  3. Apr 29, 2018 at 10:44 AM
    #3703
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    During the beginning of the pull, the AFR's stayed high. Then shot down to the 12 - 11's. From there they are steady between 11-12, except during shifts where it richens up some. Looks good overall.
    Edit* Loginfailed beat me to it. :thumbsup:
  4. Apr 29, 2018 at 10:57 AM
    #3704
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
  5. Apr 29, 2018 at 11:30 AM
    #3705
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Im sitting here at 4400 with me in it.
    U guys need them smaller pullies bigtime
    jojotoo likes this.
  6. Apr 29, 2018 at 11:33 AM
    #3706
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    It's a fact
  7. Apr 29, 2018 at 11:34 AM
    #3707
    inwood customs
    Dave
    Ill say, ur well above my gvwr
    U regularly haul a mini cooper in the bed?
    Biscuits likes this.
  8. Apr 29, 2018 at 12:18 PM
    #3708
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    That’s a suggested GVWR
    :D
  9. Apr 29, 2018 at 12:37 PM
    #3709
    mr.trd
    mr.trd Are you Recreationally Insane?
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Icon coilovers w 14" 700lb springs, Icon billet UCA w/ Delta joints, custom built Icon rear resi-shocks, Icon stage 3 rear leaf pack, Archive Garage Hammer Hangers w/ homemade spreader bar, superbumps up front and timbren bumps in the rear, Crown brake lines, U-bolt flip,4.88's with front ARB locker and ARB dual compressor mounted behind back seat, 285/75R17 BFG A/T KO2's on Bronze Icon Alloy Compression's, 5th gen T4R budget big brake kit, CBI Off-Road Fab. custom Trailmaster 2.0 with swing-away tire carrier, CBI custom tube front bumper, CBI kickout sliders, CBI full flat belly skids including gas tank,CBI Ditch Light brackets w/ Heretic Studio Quattro's, Heretic Studio's 30" Amber on the front, Heretic Studio 40" bar under the Front Runner Roof Rack, Expedition Essentials RAM mount, Leer used shell, OEM black chrome sport headlights, fog lights always on mod, rear locker anytime mod, TRD supercharger, URD Ucon-EMS, Deatschwerks 255 fuel pump w/ URD external fuel filter kit, AFE intake paired to a Safari Snorkel, URD spec-U exhaust w/ factory Tundra muffler behind URD equal length headers.
    And I regularly tow a 6k lbs travel trailer. Lol that is where I am all the sudden scared that I have been washing my cylinders. Cause I run in the boost a ton! Or did before the new gears. With the 4.88's it is like a whole new truck. Tranny temps are down 50 degrees just driving around town. And down almost 80 degrees with a small 2k lbs trailer.
  10. Apr 29, 2018 at 12:42 PM
    #3710
    mr.trd
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    I have the 4.9 sensor. I will order a Denso and see if I am truly that rich. I do have the URD Spec.U equal length headers with the A/F sensor extensions so the factory sensors are in the collector not just the middle bank tube and the AFR guage sensor is right behind the factory one on the passenger side. Would anyone suggest moving it? Or moving the factory sensors back to the center cylinders?
  11. Apr 29, 2018 at 1:40 PM
    #3711
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Definitely not in the center cylinder or you'll only get a snapshot of that bank's performance.
  12. Apr 29, 2018 at 3:00 PM
    #3712
    mr.trd
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Thst is what I thought. That is why I bought the extensions to move them to the collector at least. The Doug Thorley long tube headers I had on before these only had that option. I never liked that.
  13. Apr 29, 2018 at 3:22 PM
    #3713
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    If the gauge continues to fluctuate and freak out on you giving E8's, plan on getting an AEM gauge. I would not trust an innovate gauge as far as I can throw it these days.
  14. Apr 29, 2018 at 3:26 PM
    #3714
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    I'm in process of aem gauge install. Am I correct to understand the bosch o2s it came with are poor? If so where is the best place to buy the right one?
    12TRDTacoma[OP] likes this.
  15. Apr 29, 2018 at 5:33 PM
    #3715
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    There are part numbers on the first page of this thread. First post as a matter of fact. There’s also an Amazon link to the one OP used.
    I’m going back to check it out now. My Bosch is dead.
    EDIT
    It’s here: https://www.tacomaworld.com/threads/bosch-lsu-4-9-pn-cross-reference-and-compatibility.501754/
  16. Apr 29, 2018 at 6:27 PM
    #3716
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    I may have the deaded coolant leak from my resi. I saw it crusted around my hose clamp on the lower hose (drivers side). Is this the same problem everyone else had???
  17. Apr 29, 2018 at 6:32 PM
    #3717
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Sounds like what I have at a few of my joints. Been like 2yrs and the level hasn't gone down enough to even warrant a top off. I just wipe the crustyness off whenever I am cleaning the engine bay and call it good
  18. Apr 29, 2018 at 6:34 PM
    #3718
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    You add nos to yours already? :D
  19. Apr 29, 2018 at 6:35 PM
    #3719
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    Same here. I added maybe 100mL this afternoon for the first time.
  20. Apr 29, 2018 at 6:40 PM
    #3720
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Yeah, that’s what I did. I’ll obviously keep an eye on it. When I go to do my CSF radiator and drain the system I’ll inspect that joint further and replace the hose/clamp if needed.
