TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jun 13, 2021 at 9:01 PM
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    Yeah. The Tacoma version does not have any vents like the Fj version. Looks cool tho ;)
    92A48F4A-061B-4587-88D9-201E05F31C53.jpg 2146E61C-DC86-4C27-A2B4-1A0904B55A07.jpg DFF3A6AD-9309-43BE-9EDB-2BC94C780435.jpg
  2. Jun 13, 2021 at 9:26 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Let’s see under the hood on the bottom!
  3. Jun 13, 2021 at 9:41 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    time for a later 2nd gen conversion to the updated setup.
    BillDaCat8 likes this.
  4. Jun 13, 2021 at 9:42 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    na...
  5. Jun 13, 2021 at 9:45 PM
    BillDaCat8
    Jake
    PHX
  6. Jun 13, 2021 at 9:46 PM
    nudavinci64
    Robert
    Did you ever install the AFE intake with it or did you keep the TRD setup?
  7. Jun 13, 2021 at 9:50 PM
    BillDaCat8
    Jake
    PHX
    I haven’t yet. AFE has made it difficult to get ahold of the correct tube I need. They won’t sell it separately. So, sadly, to answer your question, no. :(
  8. Jun 13, 2021 at 10:16 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    The FJ CSF radiator in there is massive, heat shouldn't be a concern regardless if the hood is warm. If you want to vent the engine bay for better heat extraction, you should use rear facing hood louvers. You want the low pressure zone of air flowing over the louvers to extract air/heat from the higher pressure engine bay to maintain/improve proper airflow through the front end heat exchangers. Using a forward facing vent will force air into the engine bay at speed, which will disrupt the designed cooling airflow and reduce heat exchanger performance and reduce heat venting performance. Really shouldn't be an issue at speed as cooling issues typically happen at lower speeds, but rear facing vents are far superior in every way. If really concerned about heat, I think an electric fan is also worth consideration. Having the fan speed tied to engine RPM sucks. Climbing long steep grades in 4low at low speeds in desert heat just doesn't get the airflow needed to prevent noticeable climbs in coolant temp, because the fan just isn't turning fast enough. But even in those harsh desert hill climb conditions that FJ CSF radiator crushed the temps that the OEM unit would run, enough so that I was satisfied with the cooling performance. I'd pay more attention to swapping out the OEM trans cooler, as those temps climb much higher than the engine coolant in off road conditions.
  9. Jun 13, 2021 at 10:18 PM
    nudavinci64
    Robert
    Which tube do you need? the one that I sent was the Tacoma-specific one. Are you trying to get a different one?
  10. Jun 13, 2021 at 10:21 PM
    nudavinci64
    Robert
    2nd and 3rd that. the CSF does a damn good job at speed but lower speeds, sitting, crawling, hills is where I have had issues and high temps. I will be re-sealing my radiator, I have an e-Fan setup to install and plan to have a bigger trans cooler setup but have not decided which way to go. routed with the radiator or direct to trans. The Trans cooler will help big time. On a recent trip another guy with upgrade cooler was pulling 15-20 lower trans temps almost the entire trip compared to me.
  11. Jun 13, 2021 at 10:39 PM
    BillDaCat8
    Jake
    PHX
    I need the tube for the 10+ 4Runner. I’m running that MAF and throttle body.
  12. Jun 13, 2021 at 10:55 PM
    nudavinci64
    Robert
    ah gotcha! I removed mine for now until the trucks making more juice and flowing more air.
  13. Jun 13, 2021 at 11:01 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    In mid-so Cal trans temp warm up may not be as much of a concern, but I'd run it through the designed radiator passage. In extreme load scenarios the engine should be running much cooler than the trans, and will provide adding cooling benefit that you'd be leaving on the table otherwise. It will also provide faster warm up and more stable operating temps. I don't see any reason/benifit to bypass it.
    As for the crawling, an e-fan is really the solution. You need airflow across the heat exchangers, and at slow speeds, with low RPM, that requires an e-fan. It is important to get a good contoured shroud to pull air efficiently across the entire heat exchanger surface. A good e-fan should draw serious current so an alternator upgrade may also be in order. The e-fan in my JT draws 850w, or ~71A, with the factory upgraded cooling package. But of course I have radiator and transmission cooler upgrades planned there as well.
  14. Jun 13, 2021 at 11:04 PM
    nudavinci64
    Robert
    totally I have the DEO e-fan already just need to install it. So far everyone @12TRDTacoma and @Murphinator in this group are fans and have noticed the difference. Just got back from Mexico and truck was hatting me while we were waiting to cross the border. It was fine driving but those standstill or heavy heat days were no good. Last summer on some savage hill climbs almost toasted the trans too so that's def happening.
    Makes sense on the trans, I have seen both sides argued and running it inline with the current (replacing the existing trans cooler) is also less involved which for now is preferred.
  15. Jun 13, 2021 at 11:15 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    To be clear, I was specifically referring to the transmission cooling lines in the engine coolant radiator. I'd replace the OEM transmission cooler with an aftermarket one entirely, unless also installing the transmission thermostat and wanting crazy cooling ability. You don't want to over cool something where it doesn't get up to designed operating temp.
  16. Jun 13, 2021 at 11:25 PM
    nudavinci64
    Robert
    yah I am with you. Just commenting since I have seen folks run it inline with the stock one which to me was another point of failure and wasn't a big fan of daisy-chaining more coolers than I need and possibly over cooling as you noted.
    crashnburn80[QUOTED] likes this.
  17. Jun 14, 2021 at 5:16 AM
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    Is there some kind of rubber boot or gasket to seal the connection from the hood to the airbox when closed?
  18. Jun 14, 2021 at 6:29 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That may have been @mightytacoman
  19. Jun 14, 2021 at 6:51 AM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    I had installed hood louvers. They worked pretty good at taking heat outta the engine bay.
  20. Jun 14, 2021 at 7:01 AM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Same. Dropped my IAT’s about 10 degrees
