TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jun 28, 2021 at 2:27 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    That's basically the way I was doing it. At least chatting with Tom at SOS he was noting the stoptech dissipates heat a bit better than the Wilwood. I picked up the rear BBK stoptech instead of Wilwood and may just swap it. Seems to have way more people set up on stoptech with good results. Also you have a master setup for 4 wheels discs so likely we have a different feeling in general. It was feeling pretty good before but this last bleed it doesn't feel as good and I did it a few times.
    I have been running ATE 200. Been using this stuff for years in different cars. I am wondering with the use of the truck if I do not need as high of a performance fluid.
    Any of the race boys have a take on higher heat brake fluid? I was considering going with another brand or a lower heat rating as I was curious if it doesn't work as good until it heats up. I do noticed it seems to work better when warm but those panic stops are scary.
  2. Jun 28, 2021 at 3:28 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Our trucks call for DOT 3 brake fluid, which has boiling points of at least 401°F (dry) and 284°F (wet). DOT 4, which has boiling points of at least 446°F (dry) and 311°F (wet), far exceeds that standard. Motul RBF/600 (594°F dry and 401°F wet) and ATE 200 (536°F dry and 388°F wet) are both great choices. FWIW, my fun cars currently get Brembo LCF 600+ (601°F dry and 399°F wet), while the truck gets ATE 200. I'm thinking about switching the fun cars over to Redline RL-600 (604°F dry and 400°F wet), primarily due to availability and cost of the Brembo fluid. In my experience, higher heat rated fluid is advantageous when operating near those outer temperature limits. Until then, they all tend to perform similarly. YMMV.
    I found this Brake Fluid Comparison Chart useful when comparing options.
  3. Jun 28, 2021 at 3:40 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Good to know. I'm gonna look into some of those when I do my Wilwoods.
    Norton likes this.
  4. Jun 28, 2021 at 3:59 PM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    I bleed my brakes with truck running. Takes no effort and I haven’t had issues with air so far. Only vehicle I’ve done that with, but it works. You can literally run the reservoir dry in 10 seconds, so do one corner at a time and refill.
    jamesepoop and Norton like this.
  5. Jun 28, 2021 at 4:31 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Dot 4 on all of mine. I'm in the severe category.
  6. Jun 28, 2021 at 4:53 PM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Since we are on brakes and such……would there be any benefit of adding a Wilwood master cylinder to our application?
  7. Jun 28, 2021 at 5:17 PM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    no need when there is the tundra master, unless you just want the bling.
  8. Jun 28, 2021 at 7:43 PM
    jamesepoop
    jamesepoop Well-Known Member
    California
    2007 Fj Cruiser
    Same here on the russell speed bleeders. Even with the speed bleeders I was monitoring and my brother was pumping until clear, held the pedal and I closed it. I would try the bleed again but understand how tedious it can be. And after you run thru a couple quarts of ATE = $$
    I'd probably blame the rotors for that. I've seen a lot of Wilwood on offroad race trucks but not so much Stoptech TBH. I wonder if price is the reason why but most of the street trucks run Stoptech. The reason why it's negligible when they're out in the dirt, if they can't drive worth a darn, they probably won't be able to use the potential of either brand brakes.
    By the way, do you use any wheel cleaner product? I I stopped using it after one try of the Meguiars product because it cleaned the brake deposits on the rotor. Felt like it ruined the stopping until I started laying down some more pad material.
  9. Jun 28, 2021 at 9:30 PM
    nudavinci64
    Robert
    no cleaning products. Im lazy when it comes to doing that stuff nowadays. Usually covered indirect and brake dust mostly.
    Yeah I will get around to bleeding them again. Drive the truck to Mexico and back and some mounts recently and it was okay in slow but those panic stops catches up to you.
    Good to hear on Dot 4. I was wondering if I just wasn't operating them at a high enough temp and the fluid was not performing to its potential. the ATE200 has been great. used to use it when it was super blue then kept using it on the clearer version. Was thinking about others.
    The Wilwood makes sense on many trucks due to their universal formats. You can mount and set up them up almost any way you can think which makes great for a builders brake setup.
    Partially I was thinking the Stoptech since they have a solid setup for Tacomas at least. I love the setup we got but I think they half-assed it when the -DS version did not fit so I think they are slightly off. I got some funky brake wear too but def feel like there is air somewhere.
    would too much fluid causes funky issues? It looks topped off but I won't rule out anything at this point.
    If I do not figured it out ill prob pull it all when I swap out the front suspension coming up here soon and go from there. I may start fresh with new pads, I have new rotors.
  10. Jun 28, 2021 at 9:31 PM
    nudavinci64
    Robert
    also, the Baja has a sport master or the electronic one the off-road has? I thought it did. If it does then limit to no options for upgrades.
  11. Jun 29, 2021 at 8:33 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    I used to use the ATE super blue stuff on my master cylinder back in the day (like back in 2010-2012). Found out the stuff got banned like 2 or 3 years ago and life hasn't been the same since.
  12. Jun 29, 2021 at 8:36 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    I learned something new today.
    Please Note: As of late 2013 'Blue' tinted brake fluid is no longer DOT approved or legal for use or sale in the USA.
    Sale of ATE Super Blue is discontinued but ATE Type 200 'Gold' color will thankfully continue to be available for all fans of Super Blue.
    All orders will be fulfilled with Type 200 "Gold".
    Safety Note:
    It has been determined that ATE Super Blue does not comply with the applicable US DOT Federal Motor Vehicle Safety Standard for brake fluid, due purely to blue-tint for the color. The federal standard requires motor vehicle brake fluid to be colorless or amber in color and distribution of super "blue" has been suspended. However, the same Fluid with out the Blue tint continues to be available!
  13. Jun 29, 2021 at 8:44 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Ooo... So they have the gold stuff now which is the derivative equal-to. That is good to know! I will be swapping out to that stuff when it is time for me.
    JasonLee[QUOTED] likes this.
  14. Jun 29, 2021 at 8:57 AM
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
    Cause DA put it in washer fluid also stories of some one drinking it..... I still have 2 unopned bottles of the Blue ATE from my Hot Import days..
  15. Jun 29, 2021 at 10:13 AM
    nudavinci64
    Robert
    Indeed! That’s what I have been using. It was a bummer to hear the blue went away it was so nice to use but the gold continues on.
  16. Jun 29, 2021 at 3:45 PM
    ARoman83
    ARoman83 Well-Known Member
    Alex
    Wisco
    '15 TRD OR DCSB PreRunner
    Only legal stuff
    A one-upper MC?!
    TodayWasTHeDaY likes this.
  17. Jun 29, 2021 at 4:18 PM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    :rofl:
  18. Jun 29, 2021 at 4:28 PM
    scootter82
    scootter82 Well-Known Member
    Aurora, CO
    Baja has the electronic one. I bought the tundra master cylinder before I reliazed it wouldn't work. Been debating now if I'll even convert the rear to disc now. Have the kit just sitting in a box waiting
  19. Jun 29, 2021 at 6:12 PM
    nudavinci64
    Robert
    yah same with me. I have had the rear disc setup for 2 years in a box.. I have talked with a few folks running stock master or the electronic one and all like it. a bit softer pedal but overall they were a go to do it. A few folks on this thread included which got me to make the decision to go all in and do it.
  20. Jun 30, 2021 at 7:45 AM
    scootter82
    Aurora, CO
    Thing is, I've had several incidents in the last year where I had to literally slam on the brakes, and the truck stopped itself sooner than I thought. The abs definitely did its job! And makes me think the front BBK setup is enough. I'll probably end up ordering new drum pads from beefedupbrakes. Com and just paint the drum cover red
