TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jul 18, 2021 at 6:07 PM
    dib
    dib Well-Known Member
    Gary
    Escondido, CA
    11 TX Pro
    Camburg LT and Magnuson Supercharger
    Cool, D60 it is! Anyplace better than another to order from? Been pricing stuff out on ECGS but I'm in San Diego if someplace local is an option.
    Wish I could DIY but I cannot.
  2. Jul 18, 2021 at 6:11 PM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    I did the Dana 60 when I get added my cryo treated Nitro gears. It’s funny because I ran the stock gears for 10 years with the supercharger and never had an issue. If I were to do it over again, I would absolutely go with the Ford 9”. I’d get it bare (no mounts) and update your rear suspension at the same time. JD Fab has a good product over there.
    jamesepoop likes this.
  3. Jul 18, 2021 at 6:15 PM
    DocME
    California
    '07 FJ Cruiser
    Not sure how far you plan to take your truck, but one main consideration for me now days is trussing the rear end. The Dana 60 is harder to truss and maintain all the up travel that I desire. It’s convenient as ECGS has a bolt in option, but if you start down the road of improvements to the rear suspension, you’ll find yourself cutting off all the mounts and I’ll tell you right now, they build a stout rear end with 1/4” mounts. It’s a lot of work. If you’re staying stockish then You’ll be happy
    dib[QUOTED] likes this.
  4. Jul 18, 2021 at 6:18 PM
    DocME
    California
    '07 FJ Cruiser
    Did you get the fans all figured out?
    loginfailed[QUOTED] likes this.
  5. Jul 18, 2021 at 6:18 PM
    dib
    Gary
    Escondido, CA
    11 TX Pro
    I currently have the camburg rear cage long travel suspension with bypasses and fox bump stops. Does that help or hurt me?
  6. Jul 18, 2021 at 6:57 PM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    The Camaro fan won’t work with the Autocoolguy controller. I don’t want to use the Lingenfelter controller so I just abandoned that idea for now.
    I installed one of those new Flex Wave fans from Flexalite today. It seems like it moves more air than the Volvo fan, but that’s just in the driveway testing. I’ll see if it’s any better over the next week or so.
  7. Jul 18, 2021 at 6:57 PM
    Scorchedtaco
    Scorchedtaco Well-Known Member
    AZ
    2012 ac trd 4x4 sc , 2012 sequoia 4x4
    Thanks , Easy fix...
  8. Jul 18, 2021 at 7:10 PM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I agree with what you’re saying. But tinkering is therapeutic for me. It keeps me sane and it’s cheaper and less troublesome than coke and hookers.
  9. Jul 18, 2021 at 10:04 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    More info about that autocoolguy box. Does the AC trigger at your specific command % when you turn on the AC?
  10. Jul 18, 2021 at 10:58 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Means you’re going to have to do a lot of cutting, grinding and fitting to make the D60 from ecgs work. It’s meant for a “bolt in” stock application and you’ll need to redo all of the shock mounts, bump strike pads, spring perches and what not. Just like you would for just about any other upgraded axle.
  11. Jul 18, 2021 at 11:57 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    man, that sucks pretty much the same thing that happened to me earlier this year. I was just getting on the road on 4.56 and 315's as well and bam it said no thanks. I am def looking for a new rear axle as well. Depending on your setup you can also get the rear wider to better line up with the LT and not have to run spacers if you are. I plan whenever I get to it to go 4" wider (+2 on each side) to go with the front. the ford 9" sounds like a solid deal but have been seeing a bunch of Tundra as @snowsk8air2 noted so we can keep all our Toyota factory spec goodies.
  12. Jul 19, 2021 at 1:16 AM
    DocME
    California
    '07 FJ Cruiser
    Yes. The controller has a small screw that allows you to override fan rpm so you can go to a set speed when running AC. The Ice box that we have is essentially a timing relay to hold that latch so the fans don’t ramp up and down with compressor lock up.
  13. Jul 19, 2021 at 5:27 AM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    I was just wondering why no one is running the flex a lite fan? It's a kit just for the taco.
    loginfailed likes this.
  14. Jul 19, 2021 at 7:38 AM
    dib
    Gary
    Escondido, CA
    11 TX Pro
    I tried to price a full float from camburg but that was like $8k starting, lul. Good to know that I will have to grind to fit the D60 as that means I gotta do extra homework on this. Really appreciate all the input.
  15. Jul 19, 2021 at 8:30 AM
    DocME
    California
    '07 FJ Cruiser
    Or just order your rear end bare. I’m sure they would be more than happy to ship sans mounts and for a few hundo cheaper
  16. Jul 19, 2021 at 10:10 AM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    @DocME Sums it up below. The Autocoolguy controller allows you to set what fan speed you want when the A/C is on. It’s triggered by a (+) input. But the taco doesn’t have a constant (+) output when the A/C comes on. If you wire the controller to the compressor relay, then the fans don’t stay running when the compressor cycles off.
    The IceBox is basically a pulse stretcher that takes the on-off-on-off (+) pulse from the compressor relay and turns it in to a constant (+) output that you then feed to the controller’s input so that the fans stay on between compressor cycles.
    In my case, I don’t think the shroud will cover whole radiator since I have the one made for the FJ. I’m still playing around with fan ideas. I may eventually end up with one like @Torspd has.
  17. Jul 19, 2021 at 10:26 AM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Probably. I like the idea of using the stock shroud and using one fan. I might bribe @Torspd with many beers and we'll figure out the relays and wiring crap. My brain has arteries and veins terminology, placement, etc occupied where wiring should be. Lol
  18. Jul 19, 2021 at 10:34 AM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    If I could get the Camaro fan working I think that would be pretty much the best setup. It looks like it will move a ton of air. I’m just not sold on the Lingenfelter controller. I was thinking maybe there could be a way of using a junkyard Camaro ECM and just use it to run the fan. Then you could use HP Tuners to adjust the PWM map vs temp.
  19. Jul 19, 2021 at 10:39 AM
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    While on the subject of cooling, how long do our stock radiators usually last?
    I have 165K on mine, no problems or heat issues. I plan to upgrade to a larger radiator, and wondering if I should just do it now, or wait until I have a need/issue.
    Also, what is the consensus on the replacement - CSF or aFE?
  20. Jul 19, 2021 at 11:35 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    The Class 7 desert race truck that I just finished working on, was using two Flex-a-lite fans. Simply on a On/Off switch.
