TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jul 26, 2021 at 7:52 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I agree.
  2. Jul 26, 2021 at 2:07 PM
    ARoman83
    ARoman83 Well-Known Member
    Alex
    Wisco
    '15 TRD OR DCSB PreRunner
    Only legal stuff
    The heat hose can be a bit of a challenge...
    MightyMouseTom likes this.
  3. Jul 26, 2021 at 2:37 PM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    For the cam gears………valve cover gaskets, the gears themselves, orange blower intake gasket (optional)……are there any other gaskets or items I need??
  4. Jul 26, 2021 at 2:43 PM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Bottom of post one on my cam gear page has all the gaskets. (Link in signature)
  5. Jul 26, 2021 at 3:05 PM
    ARoman83
    Alex
    Wisco
    Only legal stuff
    HPS heater hose.
  6. Jul 26, 2021 at 5:26 PM
    findingthingsout
    findingthingsout Well-Known Member
    midwest
    08 Tacoma TRD O/R A.C. MT
    Boost, armor, lights, big tires, no savings.
    You'll want a couple dabs of gasket maker for the seam where the valve cover gaskets lay. I think it's pointed out in some manual somewhere...
    JuanitoBonito[QUOTED] likes this.
  7. Jul 26, 2021 at 9:32 PM
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
    Optional - replace rubber washers on bolts along middle of valve cover.
    I replaced other rusty bolts and these were cheap.
    I also replaced all the water bypass hoses and clamps. I think there are 4 or 5. One is buried in right next to driver side valve cover. Easy when everything is off. Have part numbers if you need them.
  8. Jul 26, 2021 at 9:54 PM
    zerotimeouts
    Nor Cal
    2011 DCSB 4.0 S/C
    Jon seems like nice guy but they are pretty busy. Expect about a month to get it back.
    Talked to him directly today, sounds like They’ve done a few of these but didn’t sound like very often. I asked to get the case ported like Stiegermeister does but they wouldn’t do it as they said it’s not worth it due to intake runner restriction. (probably true) but I figured even small
    Improvement that is hidden is good in Cali, and I dropped a hefty shipping fee getting it there
    • They have a reservations policy for $250 to reserve spot
    • I called multiple times to try and book a spot and only got message machine
    • Tried email too and multi day delay
    • Called them back after missed call - busy signal ?!?
    • Called again left message
    • Eventually got message I was 4-5 in line (about 1.5 weeks ago)
    • Shipped s/c there and it’s been there at least a month
    • Jon’s working on my estimate for machining about and port matching intake so hopefully they can do that this week but nothing confirmed yet.
    I don’t have alternative recommendations but the delay and trouble getting in touch was pretty annoying even if understandable.
  9. Jul 26, 2021 at 10:09 PM
    henryp
    henryp A member of TW
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    Please do share PN
    JuanitoBonito likes this.
  10. Jul 26, 2021 at 10:23 PM
    zerotimeouts
    Nor Cal
    2011 DCSB 4.0 S/C
    Water Bypass hoses (can't find diagram but it's out there somewhere)
    16267-0P030
    16281-0P010
    16282-0P010
    16264-AD010
    16261-AD010
    clips - 96136-42501, 96136-41501 (optional - double check diagram to make sure I got the right ones I ordered lots of parts at same time)
    washer seals for valve cover (I think...) 90210-06013 (double check these but I think this is right.)
    JuanitoBonito and henryp[QUOTED] like this.
  11. Jul 27, 2021 at 6:49 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Those hoses can be spotted on here:
    http://japan-parts.eu/toyota/us/201...e-fuel/1603_radiator-water-outlet/2?pnn=16267
    I've confirmed those o-rings for the valve cover bolts are correct:
    http://japan-parts.eu/toyota/us/201.../1104_cylinder-head?pnn=11201B&pa=90210-06013
  12. Jul 27, 2021 at 7:21 AM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    I've re-used the valve cover gaskets multiple times. Is that not recommended? (even if it isn't, I'll probably still do it)
  13. Jul 27, 2021 at 7:23 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    I would get the o-ring for the s/c lid. I tried reusing mine and had to take it back apart and replace to get a good seal
  14. Jul 27, 2021 at 8:26 AM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    The orange one
    BassAckwards[QUOTED] likes this.
  15. Jul 27, 2021 at 8:30 AM
    BassAckwards
  16. Jul 27, 2021 at 8:38 AM
    garciav
    garciav Well-Known Member
    Houston, TX
    2013 Tacoma TRD Off-Road 6MT
    TRD SC,HPTuners
    The APS 997 is a legend !
    I used to do car alarms back in college and did quite a bit of these- actually preferred it as an alternative to some of the DEI remote starts. Didn't know they were integrating bypass modules now, thats pretty slick!
    loginfailed[QUOTED] likes this.
  17. Jul 27, 2021 at 9:05 AM
    zerotimeouts
    Nor Cal
    2011 DCSB 4.0 S/C
    Probably fine but since they are <$1 and I was already ordering seals etc I just replaced them. It depends how dry they are really. Sometimes old rubber stuff deforms and loses rebound to fill in gaps but these are pretty small so should be ok.
    Athlaos[QUOTED] likes this.
  18. Jul 27, 2021 at 10:45 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    @prise
    One of you fine gentleman that knows the HP Tuner better than myself help this man. @JustDSM perhaps
    JustDSM likes this.
  19. Jul 27, 2021 at 10:48 AM
    prise
    prise AZ's Toaster Strudel Low T Andrew
    Prise
    Rally Runner 04 GX470
    Hola friends! I was wondering if having the HP Tuner will allow me to delete the URD MAF Calibration unit thingy for the URD CAI and not have a check engine light? I want it for all the other good reasons, but this was a specific question that came to mind. Thanks in advance!
  20. Jul 27, 2021 at 10:51 AM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
