TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jul 30, 2021 at 8:24 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Finally got around to getting on the truck again after it being down for so long. Feels good.. but still having the "surging" issue under hard pulls I've been experiencing off and on for years. I plan to do some datalogging this weekend so hopefully it'll show up.
  2. Jul 30, 2021 at 8:26 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Quite curious what you find.
  3. Jul 30, 2021 at 8:34 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    You know this has been going on for some time Tor. I've changed, fixed, tested everything I could think of to cause it. No codes. No other symptoms.
  4. Jul 30, 2021 at 8:42 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Nah, these cats are just the suck is all. Typical mileage for them to go with the supercharger installed is 130-150K miles on the clock. Use premium only, and make sure your oil changes are up to date, no longer than 5000 miles, do your spark plugs even 20-30K if you are not tuned and you'll be good to go. :thumbsup:
    Spark plug defoulers work in place of the URD sims. ;)
    When exactly in the RPM range is this surge occurring? I need more info to attempt to help you.
  5. Jul 30, 2021 at 8:46 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    It's sporadic.. and I don't even have enough info myself. Lol. Hence the data logging. Just when I'm WOT. Doesn't matter if it's off the line or I roll into. Occasionally it'll start surging/bucking/hesitating.. I let off the accelerator.. ease back into it.. if it's still there I let off again/more.. and ease into it again.
    Really sucks when you're pulling on someone and it starts acting up.. and you gotta let off a bit then get back into it.. and they pass you.. lol
    12TRDTacoma[OP] likes this.
  6. Jul 30, 2021 at 8:56 AM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    I did all the right things with mine and the stock ones lasted 60K and were replaced under warranty. I'm on my third set now. And the de-foulers do not work as well as the simulators, but its certainly worth a try. At least they didn't work for me. Unfortunately there are no approved replacements in certain states, so you have purchase factory parts that have an integrated manifold. Has anyone priced out new full replacements? Its enough to make you cry.
  7. Jul 30, 2021 at 8:59 AM
    findingthingsout
    findingthingsout Well-Known Member
    midwest
    08 Tacoma TRD O/R A.C. MT
    Boost, armor, lights, big tires, no savings.
    Could this related to the somewhat recently discovered hesitation causes resulting form dirty VVTI filter screens/ sensors? Maybe you swapped the screens already...
  8. Jul 30, 2021 at 9:14 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    This I don't know. I have not messed with that at all.
  9. Jul 30, 2021 at 10:55 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I've had this issue for a long time now. I have not done anything about it because I was never sure if it was a screen issue or a solenoid issue or even if it was a CMP issue. Based on the symptoms and how it is a sometimes and not an all the time thing I am more inclined to want to replace the VVT solenoids on my own truck first before any of the other items I mentioned. Especially since I know that these solenoids suck across the Toyota lineup in general having replaced more than enough of them after 80K+ miles.
  10. Jul 30, 2021 at 10:57 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    They definitely worked for my setup. They don't work as well, I agree, but if you are just starting to experience failure then they can and more than likely will resolve your issue.
  11. Jul 30, 2021 at 2:20 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Where in Colorado are you located, @TearingOut55 ?
    Could it be a fuel pressure issue?
  12. Jul 30, 2021 at 3:05 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Maybe. I thought maybe injectors or something. I've changed the fuel filter. I just figured I'd see something if that were the case. Hoping the Data Logging will show something.
  13. Jul 30, 2021 at 5:38 PM
    TearingOut55
    TearingOut55 Member
    Colorado
    2008 Tacoma TRD Off-Road
    Supercharger, 3" lift + 33's, GFC pending
    @JasonLee Denver area
  14. Jul 30, 2021 at 8:10 PM
    JasonLee
    15 TRD OffRoad
    There’s a few of us around if you need some help. I have a windows laptop with an HPTuners MPVI2 if you want to do some tuning.
  15. Jul 30, 2021 at 8:53 PM
    HappyGilmore
    HappyGilmore LambTek Innovations
    Huntsville, AL
    2013 SC’d DCSB TRD OR 4x4 | 2012 Lexus IS-F
    Yes
    So had some time to do some digging today - after a compression and leak down test I’ve concluded cylinder #5 has low compression due to a leaking exhaust valve. Looks like the supercharger and head is going to have to come off for a refresh…:annoyed:
    Pics are cyl 1, 3 & 5
    27E34F2A-C388-4739-9514-8F4820AA5FDF.jpg 0022120A-2E52-4E1A-B7F6-25A485612D52.jpg 4C7DACB3-A919-4320-9555-557C843D20BA.jpg
    Norton and DocME[QUOTED] like this.
  16. Jul 30, 2021 at 8:55 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    +1
  17. Jul 30, 2021 at 9:13 PM
    Amo-cat3
    Amo-cat3 Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    NO!! That's two of us this month dealing with cylinder heads. I'm dealing with a dropped intake valve seat cylinder 6. Good luck my friend!
  18. Jul 30, 2021 at 10:06 PM
    scootter82
    scootter82 Well-Known Member
    Aurora, CO
    Oh, I got lucky. Just got mine earlier this year. Anyone know if I can just install the factory midpipes/cats and pass an emissions test? I'll be damned if I'm swapping out the long tube headers...those were a pia to install
  19. Jul 30, 2021 at 10:13 PM
    scootter82
    Aurora, CO
    I'm in denver and have a second techstream thingie you can have if it helps
  20. Jul 30, 2021 at 10:34 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    I highly doubt you'll pass with only the rear two cats installed. If you do, it will be at a shady shop that doesn't care. You will fail visual every day of the week.
    12TRDTacoma[OP] and nudavinci64 like this.
