TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Aug 23, 2021 at 1:48 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Hoping to order today if anyone has any added input. if the additional fan is worth it I am all over it. but wanted to get a consensus from the boosted folks.
  2. Aug 23, 2021 at 1:57 PM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    I'd get the fan if it was temperature controlled automatically. That would be good to have. If not, you'll be ok without it.
  3. Aug 23, 2021 at 2:03 PM
    kasnerd
    kasnerd candied bacon
    SoCal Yokel
    '14 SC LT Mall Runner
    Mods? Yes, oh yes..
    JD did a sweet trans cooler for the beast Tacoma. Mine will get one as well. :cool:
  4. Aug 23, 2021 at 2:05 PM
    nudavinci64
    Robert
    thanks that's what I was thinking. The additional in-line thermostat you can control to turn on ad a specific temp so say 195 and up it turns on. that part I liked. The question then would be pusher or puller style upfront.
    Any info on it?
  5. Aug 23, 2021 at 4:30 PM
    kasnerd
    SoCal Yokel
    Mods? Yes, oh yes..
    ah, it's buried somewhere in that thread. mounted to the cross bar in the bed with a new cross bar at the top of the shock towers.
  6. Aug 23, 2021 at 4:38 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    I ran a mishimoto 160 for a couple months and had to swap back to the URD 170. The truck never got up to temp and would idle around 1k rpms. Fuel mileage also took a dump so I swapped back to the 170 and haven’t looked back. Not trying to steer you away, but my 160 didn’t like the mild winters we have here in TX so just something to consider
  7. Aug 23, 2021 at 4:42 PM
    nudavinci64
    Robert
    ah ok a pull setup in the bed. For that is not an option unless I want to toss it on the top of the truck. Would be a great setup if I had a different setup.
  8. Aug 23, 2021 at 5:18 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    any clearance difference to the s/c belt?
  9. Aug 23, 2021 at 5:40 PM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I have the Mishimoto 160 as well. Only issue I had was a P0128 (not warming up quick enough) but I fixed that with HP Tuners. To me it warms up plenty quick, but I think it was just barely over the threshold in the stock tune when its really cold (for Houston) and I'm driving like a grandpa. Around town the truck runs 180-190. Still creeps up slowly to 200 if I sit idling with AC on for around 30 minutes. Eventually I'll figure out the Camaro fan and that should take care of the idle temp creep.
  10. Aug 23, 2021 at 6:22 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    Good to know, exactly what I was afraid of / looking to see if it’s been a problem for anyone.
    I doubt I’ll have an issue in SoCal, but I think I’ll go for it and see this “winter”
    BassAckwards[QUOTED] likes this.
  11. Aug 23, 2021 at 6:49 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I'm running the URD 160. I wanted as much as I could get being in the Arizona desert and I had some overheating issues prior during the sand drags and long wheeling trips. Haven't had any issues with it but also haven't looked into or compared the temp difference too much afterwards... I just haven't had the overheating issues since.
    BassAckwards and loginfailed like this.
  12. Aug 23, 2021 at 9:18 PM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    It's been a while since I posted here. I didn't catch up on everything but it's nice to be reading the conversation again.
    Thought some of you might appreciate this. Given that a couple of the intercooler lid bolts had stripped out holes, I drilled and tapped for larger bolts. Kind of an engine bay dress up thing at the same time.
  13. Aug 23, 2021 at 9:45 PM
    BassAckwards
    Are you running a bigger radiator? I remember getting that code too. I bet it’d be okay during the summer here. I probably made the mistake of swapping it in right before it got cold lol.
    Definitely give it a shot and see how your motor likes it. The worst that could happen is another swap and some more coolant
    great work! I need to do this as well. What size did you go with, M8? The round head bolts look good as well
  14. Aug 23, 2021 at 9:47 PM
    Athlaos
    Leigh
    Edmonton
    Yep M8x1.25. Found a pack of bolts on Amazon. Honestly I was just like "I'm pretty sure these will work" without really measuring and they worked very well.
  15. Aug 23, 2021 at 10:13 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    love that mod spirit.
  16. Aug 24, 2021 at 3:37 AM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Yes, the CSF 7076
  17. Aug 24, 2021 at 5:11 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I like that. Those bolts strip way to easily
  18. Aug 24, 2021 at 8:28 AM
    Sterling_vH111
    Sterling
    socal
    You have something grounded to the top lid bolt?
    I figured it was for the oem air box or something and I won’t be using it when I install.
    Also noted on the weak lid bolts.. I’ll be careful torquing then.
    BassAckwards and Norton like this.
  19. Aug 24, 2021 at 10:13 AM
    racebug68
    racebug68 Well-Known Member
    Travis
    Chandler, AZ
    05 DCLB 4x4 TRD SPORT SILVER
    I can't leave anything well enough alone
    Any reason not to replace the bolts with a stud and nut setup (either M6 or M8)? That would eliminate the in/out wear on the threads with a short bolt and possibly loose thread engagement. It appears the bolts are all on the same plane, but perhaps the lid would be really hard to remove if it had to slip over a bunch of studs that weren't all perfect?
  20. Aug 24, 2021 at 10:17 AM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    My thoughts!
    nudavinci64 and loginfailed like this.
