TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Sep 14, 2021 at 6:23 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
  2. Sep 14, 2021 at 6:23 PM
    wrmathis
    Bonaire, GA
    parts and stuff
  3. Sep 14, 2021 at 8:04 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    I recall I used the info @mightytacoman had. His write up was solid.
    mightytacoman likes this.
  4. Sep 15, 2021 at 2:29 AM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Link to my write up in my signature. I can walk people through the install too as needed
    :cheers:
  5. Sep 15, 2021 at 11:13 AM
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
    Did anyone ever find/recommend an alternate fuse for pump that doesn’t go on/off intermittently when truck is off?
  6. Sep 15, 2021 at 11:33 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    All I remember is that the suggestion was to set up your own power tap hooked up to a relay that is triggered by an ignition-powered source.
  7. Sep 15, 2021 at 1:15 PM
    racebug68
    racebug68 Well-Known Member
    Travis
    Chandler, AZ
    05 DCLB 4x4 TRD SPORT SILVER
    I can't leave anything well enough alone
    While I can't argue that a separate ignition controlled relay is best - is there any real issue having it hooked to the evap system, which does random tests? If it kills your battery, I'd argue the battery was on its way out anyhow. Did it scare you when it came on? Who cares? - my hybrid vehicles make all sorts of noise when they are off...
    When hooked to the evap system the way the instructions tell, does the pump run when the ignition is at acc, or only on/run? I'm trying to decide if I want extra complication in the system, and I can't recall what the original complaint was with it connected to the evap system. Thanks in advance
    Athlaos and 12TRDTacoma[OP] like this.
  8. Sep 15, 2021 at 1:37 PM
    zerotimeouts
    Nor Cal
    2011 DCSB 4.0 S/C
    I think the original complaint was camping and having it go on….
    mom not sure it’s worth the hassle either but I was also thinking I could probably use similar fuse tap style to a circuit in dash if I didn’t want to worry about an additional relay that could fail unknowingly to me although unlikely
  9. Sep 15, 2021 at 1:48 PM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    There's already a relay used to turn on that pump (mine was located between the rad and headlight area) so you'd just need to change the trigger wire from the efi circuit to a different trigger.
    No additional relays need to be added.
    That pump scared me a few times when super focused and working in the engine bay and it would turn on randomly.
  10. Sep 15, 2021 at 2:05 PM
    zerotimeouts
    Nor Cal
    2011 DCSB 4.0 S/C
    Hey @Roostfactor so the Temp measured is air temp not the liquid, correct?
    At first I was imagining liquid temp check in the lines but most of those seem to be 1/8” tapped and the Davtron specs are 5/16. Might be too big for 3/4” line
  11. Sep 15, 2021 at 2:16 PM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    What are you guys thoughts on intercooler foam strip? Ditch it or leave it?
  12. Sep 15, 2021 at 2:18 PM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    I just replaced mine a couple days ago when I did the cam gears.
  13. Sep 15, 2021 at 2:22 PM
    TodayWasTHeDaY
    Russ
    Calgary
    I could not get mine to stick well no matter what I used.
    I brake cleaned the crap out of it. Roughed up the metal for adhesion. Tried both super 77 and high temp RTV and the last time I took the lid off the gasket was barely clinging on so I said fuck it and yanked it out.
    I never did try a new gasket.
    I theorize Meth injection may have something to do with it.
    zerotimeouts and henryp[QUOTED] like this.
  14. Sep 15, 2021 at 3:23 PM
    JasonLee
    15 TRD OffRoad
    Alcohol (methanol) will soften the adhesive. I'm surprised RTV didn't work.
  15. Sep 15, 2021 at 3:29 PM
    kasnerd
    kasnerd candied bacon
    SoCal Yokel
    '14 SC LT Mall Runner
    Mods? Yes, oh yes..
    or the electric brake booster going off in your ear working on the ac compressor. fun times. almost needed a change of shorts.
  16. Sep 15, 2021 at 4:17 PM
    nudavinci64
    Robert
    I’ve gotten so used to the pump going on that it doesn’t matter anymore.
  17. Sep 15, 2021 at 4:31 PM
    scootter82
    scootter82 Well-Known Member
    Aurora, CO
    Hptuner arrived, fun times ahead!
  18. Sep 15, 2021 at 4:49 PM
    kasnerd
    SoCal Yokel
    Mods? Yes, oh yes..
    i need to get on this. truck is weird at 2500-3000. sounds like its lean and gravel in the sc. fine everywhere else. fine WOT but under load and before the downshift kicks in because of pedal position and low rpms. looking forward to a more lively tune.
    scootter82[QUOTED] likes this.
  19. Sep 15, 2021 at 4:55 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    I brake cleaned the living hell out of mine and then scuffed up the surface with some 180 grit then applied Hondabond RTV to it. It's been holding great since.
    I think it is your meth injection throwing you for a loop here.
  20. Sep 15, 2021 at 5:11 PM
    racebug68
    Travis
    Chandler, AZ
    Really! My truck is a 2005, I've owned since 2012, and can't say that I know what the sound is when it runs. I thought it did it in the middle of the night, only on random days every week or less. You have heard it a lot? What does it sound like and how often and how long does it run for? Is there any difference in that system over the years, maybe we have different systems or algorithms or something.
