TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Sep 15, 2021 at 5:25 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    Got these in the mail yesterday. Urd heavy flywheel and stage 3 clutch. Total weight of the box was 72lbs. The fly wheel is one heavy bastard.
    EA7F1721-3694-4425-9CCC-00E237118F11.jpg D30579A9-07D8-4A6A-9934-A8651CB9C67A.jpg
  2. Sep 15, 2021 at 5:46 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Meth injection is cooling the IAT far better than what that foam seal is trying to accomplish.
  3. Sep 15, 2021 at 5:47 PM
    TRON
    What throwout bearing setup you going with?
    Norton likes this.
  4. Sep 15, 2021 at 5:50 PM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    Yeah, that's what I figured as well. Also get a bonus increase in airflow!
  5. Sep 15, 2021 at 5:56 PM
    TodayWasTHeDaY
    Russ
    Calgary
    It randomly turns on with the 2012+ trucks as the circuit is part of the emissions air injection system.
  6. Sep 15, 2021 at 5:59 PM
    wrmathis
    Bonaire, GA
    parts and stuff
    ive had the clutchmasters for almost 2 years now with no issues
    rheath08 likes this.
  7. Sep 15, 2021 at 6:43 PM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    Yep! I need to get around to selling mine.
  8. Sep 15, 2021 at 7:02 PM
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
  9. Sep 15, 2021 at 7:27 PM
    wrmathis
    Bonaire, GA
    parts and stuff
    unzip it, then use the index.html. select whatever you need to and it will open the PDF file
  10. Sep 15, 2021 at 7:55 PM
    Amo-cat3
    Amo-cat3 Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    You guys think it would make a difference if I did a compression test with the supercharger off - open intake? I don't see it being an issue as long as nothing drops down the intake:fingerscrossed:
  11. Sep 15, 2021 at 8:01 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That will work fine.
    Amo-cat3 likes this.
  12. Sep 15, 2021 at 8:40 PM
    rheath08
    Russell
    Bakersfield, CA
    if it is off already then no. if you are worried about incorrect readings do to restrictions, wedge the throttle plate open. i would keep the belt on so the rotors spin.
  13. Sep 16, 2021 at 12:44 AM
    racebug68
    racebug68 Well-Known Member
    Travis
    Chandler, AZ
    05 DCLB 4x4 TRD SPORT SILVER
    I can't leave anything well enough alone
    Ahh... ok so the turn on noise is part of the air injection system... I thought it was part of the evap system, where it pumps a vacuum on the tank every great once and a while to check if there are any fuel tank or fuel vent line issues. Makes sense that I haven't heard it then! thanks!
  14. Sep 16, 2021 at 2:39 AM
    australian hilux
    australian hilux Well-Known Member
    Justin
    2005 Toyota hilux v6 4.0L 1gr-fe
    None at this point
    Wow! Funny you post this. I’m actually about to buy a heavy duty clutch as the except HD clutch is shit and slips had when I’m in 4H and gunning it. Was about to ask if anyone has any advise on what flywheel I should get?
    I’m looking at getting a 4terrain clutch. If that means anything to you guys.
    Athlaos likes this.
  15. Sep 16, 2021 at 2:41 AM
    australian hilux
    Justin
    None at this point
    Correction…excedy HD clutch
  16. Sep 16, 2021 at 6:42 AM
    scootter82
    scootter82 Well-Known Member
    Aurora, CO
    Finally got a tracking number, arrives Saturday!
    Norton and Torspd like this.
  17. Sep 16, 2021 at 5:23 PM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Guys….need a little help. Does someone here make the air injection tube block off plates? I have a Toyota part number however it shows discontinued everywhere and it looks like I can’t buy them.
    edit…..does someone know the measurement bolt hole to bolt hole on our size. I may be able to find an off brand
    scootter82 likes this.
  18. Sep 16, 2021 at 5:51 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Just hit up @Roostfactor he makes or at least made them.
    If all else fails you can hit up Hewitt-tech as they should sell them as one offs.
  19. Sep 16, 2021 at 6:18 PM
    scootter82
    Aurora, CO
    Thanks, I wish I had the foresight to remove this pos system before I installed lt headers this summer...
  20. Sep 16, 2021 at 10:34 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    Removal post install isn't that hard. The only thing that's a pain is the bolt on the back of the block holding the tube that runs back there.
    ARoman83 and 12TRDTacoma[OP] like this.
