TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Sep 17, 2021 at 6:51 AM
    scootter82
    scootter82 Well-Known Member
    Aurora, CO
    Ya but then I could've ordered the non sais version of the headers. Those are now a permanent install
  2. Sep 17, 2021 at 9:32 AM
    JaxJacket
    JaxJacket Well-Known Member
    2013 DCLB
    The blockoffs that came with my hewitttech fit the airvalve flanges, but not the exhaust manifold flanges. Ticked me off cause I cut my knuckles up pretty good trying to mount them on the manifold first.
  3. Sep 17, 2021 at 10:26 AM
    scootter82
    Aurora, CO
    On the previous topic of engine temps and the fan. I'm watching the HPTuners tutorial and towards the end he talks about Fan Control and 170* thermostats, and adjusting the fan speeds. Is this something that would help the overheating crowd?
    Right after he talks about intercooler pump controls..
    https://youtu.be/DWYKVoFcOmk?t=2913
  4. Sep 17, 2021 at 3:32 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Fan speeds are non adjustable as they are based on engine RPM speed, and engine intercooler pump controls are non existent, as they have one speed, one speed only and only have a relay driving it on and off. They are not PCM connected and have no other way to control them.
    scootter82[QUOTED] and JasonLee like this.
  5. Sep 17, 2021 at 8:59 PM
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
    Mostly I’ve seen write ups related to older Yotas but you can make slight adjustments to fan by using different oil in the clutch. Not sure it would be substantial temp change but clutch is actually pretty simple inside.
    scootter82[QUOTED] likes this.
  6. Sep 18, 2021 at 4:22 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Someone did this here, during discovery. Used a thicker shock oil. I believe that was in the CSF radiator thread.
  7. Sep 18, 2021 at 4:37 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I think it was @Roostfactor
  8. Sep 18, 2021 at 5:10 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    loginfailed likes this.
  9. Sep 18, 2021 at 1:03 PM
    TacoJova
    TacoJova Well-Known Member
    Central Oregon
    2025 Underground DCLB Sold 21 Ram TRX Sold 2015 White DCSB Offroad
    Stock for now
    I don’t remember who but I found my stock set of injectors if anyone wants them. Also how much do stock headers go for? And i have a stock intake manifold too that someone can have
  10. Sep 18, 2021 at 6:30 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    i sold low mileage stock manifolds for 250. very reasonable price compared to dealer. sold fast.
    Torspd likes this.
  11. Sep 18, 2021 at 7:57 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    can anyone give a parts/labor estimate for a gear change?
    i want to go 4:30. reason is unfortunate. my trac bar 3rd member mount stressed and im leaking:mad: repaired twice without luck. what a bitch.
    Athlaos likes this.
  12. Sep 18, 2021 at 8:28 PM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    It’ll be a couple grand. That’s what I paid.
  13. Sep 18, 2021 at 9:16 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    www.gearinstall.com zuk is the man when it comes to toyota diffs
  14. Sep 19, 2021 at 9:15 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Your trac-bar bolts to the 3rd member bolts. Yes?
  15. Sep 19, 2021 at 9:21 AM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Yep he did mine this year and I was super pleased. Only other route I’d go would be the 3rd member core swap from ECGS. But Zuk will be my first suggestion.
    DocME likes this.
  16. Sep 19, 2021 at 9:24 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Id suggest Randy’s Ring and Pinion in Everett, one of the best on the area. I’ve had 3 trucks done there. Though I’m not following what the issue is.
  17. Sep 19, 2021 at 9:27 AM
    wrmathis
    Bonaire, GA
    parts and stuff
    i had a front diff that was locked by ECGS. whwen i regeared later, the shop that i had do it was surprised how it still worked with all they found wrong with it.
  18. Sep 19, 2021 at 9:50 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    no. it is welded to the 3rd. thought this was the better choice. now seriously regretting it.
  19. Sep 19, 2021 at 9:53 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    where my tracbar is welded to my 3rd member the weld gave out and its weeping fluid. neighbor helped weld it up but its still got a slow leak. im kinda screwed i figure. likely need a new housing, figured its a time for gears.
    crashnburn80[QUOTED] likes this.
  20. Sep 19, 2021 at 10:08 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Pictures please.
    crashnburn80 likes this.
