TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. May 4, 2018 at 7:05 PM
    #3861
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Think they're on page 1
    12TRDTacoma[OP] likes this.
  2. May 4, 2018 at 7:25 PM
    #3862
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Thanks. Thought I read there were different ones for driver and passenger sides.
  3. May 4, 2018 at 7:44 PM
    #3863
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Oem non supercharged trucks from the factory come with one bank NGK and the other bank denso. Same coldness plugs Toyota just seems to split the manufacturing demand between the two I believe
  4. May 4, 2018 at 7:49 PM
    #3864
    Jesse
    Poulsbo
    15' DCSB OR S/C
    So are the cooler of the two plugs on page one a good choice?
  5. May 4, 2018 at 8:37 PM
    #3865
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    I haven’t swapped them in but it seems like a lot of people do switch to the 24s. I haven’t read any horror stories on doin it either.
  6. May 4, 2018 at 10:59 PM
    #3866
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    If you dont know how many miles are on your plugs it's not a bad idea to change them so you have a reference point. The IKH22's are fine for stock and mild mods. When you start going smaller than 2.85, headers, etc, then go to the 24s. If you plan on staying with your 2.85 I suggest staying with the same IKH22's.
    Norton, RyanL and JacksonTacoma like this.
  7. May 4, 2018 at 11:02 PM
    #3867
    Roostfactor
    TX panhandle
  8. May 5, 2018 at 12:59 AM
    #3868
    HamerMan
    HamerMan Well-Known Member
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    It’s the 30-40LE I believe. Either way, it’s a A340 series which is why I was wondering if some of the internals were similar. I can’t find too much on it. I’m not looking for the whole swap just some internals.
  9. May 5, 2018 at 6:00 AM
    #3869
    ThomasMore66
    Dallas/Fort Worth & Durango
    Biscuits had the dreaded strike-through. Permanent or temporary ban?
  10. May 5, 2018 at 6:14 AM
    #3870
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    What happened to biscuits???
  11. May 5, 2018 at 6:20 AM
    #3871
    Roostfactor
    TX panhandle
    What!? We cant lose @Biscuits!
    loginfailed likes this.
  12. May 5, 2018 at 6:23 AM
    #3872
    Jesse
    Poulsbo
    15' DCSB OR S/C
    No good. Was he spotted at a Nissan dealership??
    loginfailed and JacksonTacoma like this.
  13. May 5, 2018 at 6:24 AM
    #3873
    ThomasMore66
    Over in Texas Tacoma Stalkers. Things got moderately out of hand.
  14. May 5, 2018 at 6:26 AM
    #3874
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    This ruins my cinco de mayo.....
    loginfailed and Roostfactor like this.
  15. May 5, 2018 at 6:27 AM
    #3875
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Now it’s cinco de mustard
  16. May 5, 2018 at 6:31 AM
    #3876
    Roostfactor
    TX panhandle
    Now that's funny Juanito! What a coincidence today is huh?
    I didnt see anything in that thread that was horrible but what do I know, I'm not a moderator.
  17. May 5, 2018 at 6:36 AM
    #3877
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    It’s just no bueno....
  18. May 5, 2018 at 6:37 AM
    #3878
    ThomasMore66
    Me neither. But I’m not that sensitive, at least according to my wife.
  19. May 5, 2018 at 6:42 AM
    #3879
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    So no one knows what even happened
    Murphinator likes this.
  20. May 5, 2018 at 6:44 AM
    #3880
    ThomasMore66
