TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Oct 11, 2021 at 4:12 PM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    Any of you guys local to me want a magnaflow muffler? The old 3” one URD used to use in their exhaust. You’ve got a bit under 2 years to decide while my house is being built and I goto a fun state. Else it just goes in the trash.
  2. Oct 11, 2021 at 4:50 PM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    I did change the dwell times, to get the most out of the swap.
  3. Oct 11, 2021 at 5:32 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    @JustDSM , is this a capability with the HPTuners?
  4. Oct 11, 2021 at 6:37 PM
    happyabortion
    happyabortion Well-Known Member
    brian
    port arthur TX
    99 tacoma prerunner
    Anyone know where I can get a discount on some gauge pod and some afr\boost gauges?
  5. Oct 11, 2021 at 7:02 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Just the muffler?
  6. Oct 11, 2021 at 7:02 PM
    nudavinci64
    Robert
    Black Friday is coming that will be your best bet
    happyabortion[QUOTED] likes this.
  7. Oct 11, 2021 at 8:32 PM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    They're not currently defined, but the ECU has the ability. One would just need to submit a ticket with HPT to have them defined and added to the editor.
  8. Oct 11, 2021 at 9:12 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That would open up some additional capability.
    12TRDTacoma[OP] likes this.
  9. Oct 11, 2021 at 10:11 PM
    Kelvin
    Kelvin Wheeeeee
    Yes just the muffler
  10. Oct 11, 2021 at 11:48 PM
    nudavinci64
    Robert
    Recall why they changed it?
  11. Oct 12, 2021 at 12:20 AM
    Shadowhunter
    Shadowhunter Well-Known Member
    Nate
    Birdsview Washington
    13’ DCSB MT Sport
    Front and Rear Locked, 35’s, Chevy 63” swap, Fox Suspension and a bunch of other shit too long to list.
    @White lightning boosted I was catching up in the cool guys S/C thread and see your having a problem. Did you swap your Elocker rear for the Sport 8.4’”? I can’t remember if you did . Anyways I have a 8.4” housing with a 3.73 diff with no axles chilling out underneath my shop bench if your fix doesn’t work.
  12. Oct 12, 2021 at 4:16 AM
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
    If no one else needs this I would give it a go. Can I bolt this to my 2.5” TRD pipes? Maybe an adapter? They’re pretty rusty.
  13. Oct 12, 2021 at 6:52 AM
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    its holding for now. if it gives out id be greatful. its 8.4 now.
  14. Oct 12, 2021 at 8:57 AM
    findingthingsout
    findingthingsout Well-Known Member
    midwest
    08 Tacoma TRD O/R A.C. MT
    Boost, armor, lights, big tires, no savings.
    Regarding the coil packs; is there any proof of the performance other than vendor claims and butt dynos? Looking at swapping mine out as they have 200K mi on them. My 1st Gen coil packs made it over 200k as well. Probably stick to OEM unless I see some proof. Cheaper and better does not sound likely with the RIPP and SOS offerings. I know some feel like they made a difference, but maybe the difference is comparing old packs to new, or some other variable is involved?
  15. Oct 12, 2021 at 10:18 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    High performance Yaris coil packs, would be more a direct swap. Yes. High performance Yaris. Probably would have to swap the boots over.
  16. Oct 12, 2021 at 10:29 AM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    So with the Yaris parts that should add at least 2 mpg's right? Lol
  17. Oct 12, 2021 at 10:29 AM
    findingthingsout
    midwest
    As in the GR Yaris? Man, is the US getting screwed again on another car that would be a nice option for many over here...
    Torspd[QUOTED] likes this.
  18. Oct 12, 2021 at 10:34 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    This. All just a thought at this point. At least something for the curious to investigate.
  19. Oct 12, 2021 at 10:41 AM
    EricRippSuperchargers
    EricRippSuperchargers Member
    Eric
    Yes unfortunately this was my mistake on the backend of the website. Accidentally opened up all Toyota products when I only meant to open Lexus sales. Should've had that second cup of coffee....
    The SOS coil is packed into the OEM size. We did this at first and barely gained anything without overheating it internally. The gain comes from how much larger our core is and the increased winding.
    We cannot comment on other manufacturers however we can assure that ours come from a different manufacturer than any other aftermarket performance coil. We specifically sought an OEM coil manufacturer rather than a bulk relabeled product manufacturer.
    I am not 100% positive on the Toyota side of tuning but I have R35 coils on my SR20 S13. Dwell time did need to be adjusted.
    The orange Tacoma in our videos was far too new to have worn coils. Additionally our TRD PRO was brand new and gained the same power with the coil swap. Our new HEMI coils made 30whp on a 2500 mile Scat Pack Challenger.
    Remember there's another side to "cheaper and better". Nissan coils are a great example.
    If you buy OEM Nissan 350Z ignition coils they are $96 per coil. If you buy the Hitachi coil, which is literally the same coil directly from the manufacturer rather than from Nissan, it is $31. Anything made outside of OEM titled products are vastly cheaper solely due to the OEM markup.
  20. Oct 12, 2021 at 10:46 AM
    Kelvin
    Kelvin Wheeeeee
    Honestly have no idea. But if I had to give it a guess, probably profit.
    Would need to be welded. The muffler was just cut out after I wrecked my 4Runner I think. So one of those cone adapters that go from 2.5-3.0” and make up your own tailpipe section.
    zerotimeouts[QUOTED] likes this.
