TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Oct 23, 2021 at 11:05 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Relocate from Cali? Are they even in Cali?
    Engineered performance is the newly sourced place?
  2. Oct 23, 2021 at 11:09 AM
    ThomasMore66
    Dallas/Fort Worth & Durango
    Norton, 12TRDTacoma[OP] and Biscuits like this.
  3. Oct 23, 2021 at 11:27 AM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    source for those bolts? lol!
    12TRDTacoma[OP] likes this.
  4. Oct 23, 2021 at 11:37 AM
    ThomasMore66
  5. Oct 23, 2021 at 11:40 AM
    ThomasMore66
    They are in Cali. What a cluster.
  6. Oct 23, 2021 at 11:45 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    What vibes?
  7. Oct 23, 2021 at 5:30 PM
    ARoman83
    ARoman83 Well-Known Member
    Alex
    Wisco
    '15 TRD OR DCSB PreRunner
    Only legal stuff
    My vibration is aggressive lol :rofl:
  8. Oct 23, 2021 at 5:40 PM
    rheath08
    Russell
    Bakersfield, CA
    What mounts have the best daily ability? Yeah I know that is not of thee English of proper.:p
  9. Oct 23, 2021 at 5:57 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    My truck was my daily for years after I installed my Bonzen mounts. They are still in to this day.
    rheath08[QUOTED] likes this.
  10. Oct 23, 2021 at 6:07 PM
    rheath08
    Russell
    Bakersfield, CA
    Good info thanks.
  11. Oct 23, 2021 at 6:36 PM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    Can lady friends get the big 'O' when riding shotgun?
  12. Oct 23, 2021 at 7:14 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    They're more partial to big D. ;)
  13. Oct 23, 2021 at 7:45 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Same with my dmz mounts.
    TodayWasTHeDaY likes this.
  14. Oct 23, 2021 at 7:47 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Usually gets them screaming when riding shotgun for sure
  15. Oct 24, 2021 at 11:58 AM
    rheath08
    Russell
    Bakersfield, CA
    @Torspd should i have the rods shot peened? or are they good from the factory?
  16. Oct 24, 2021 at 3:02 PM
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
    same here my Bonzen mounts are 3 years old and I don’t remember what it felt like before. Seems smooth even at idle. It vibrated a little after install but I notice more tire and road noise now than engine vibes
  17. Oct 24, 2021 at 4:02 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    OEM rods? A cryo treatment may be better than that. They are still inherently weak.
    Check Molnar rods. See if they have any in stock? Them or Brian Crower.
  18. Oct 24, 2021 at 4:23 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Forged rods and Pistons. E.o.s.
  19. Oct 24, 2021 at 6:42 PM
    rheath08
    Russell
    Bakersfield, CA
    :help: well $2200 down another $2000-$2500 to go. Placed an order for the Molnar rods and Darton mid sleeves.
    :spending:
    If nothing else it will be stout and I will be able to rebuild it multiple times. @Torspd I may be messaging you during this for first hand experience and the other guy, I cant seem to get the tag to work.:facepalm:
  20. Oct 25, 2021 at 9:50 AM
    racebug68
    racebug68 Well-Known Member
    Travis
    Chandler, AZ
    05 DCLB 4x4 TRD SPORT SILVER
    I can't leave anything well enough alone
    I have an '05 and about 150K miles, not my daily driver - it is a loaded up camping rig. Haven't put the supercharger on yet that is sitting in the garage :( One concern is the head gaskets, being that it is in the notorious & prone failure years... What is the consensus from the group here? Should the blower w/2.8 be installed and run it with fingers crossed? Or should I go for a head gasket upgrade, along with whatever else we find (like timing chains, tensioners, etc) either before or as part of the blower install? Obviously would be the time to put on the 3 degree cam gears that are also on the shelf. I have the general thought that fixing it after it inevitably fails is way harder/worse/expensive and the failure will happen at a bad time due to Murphy's law...
    Can anyone give information about the cost for parts and labor of pulling the heads off to put a new gasket down? What are the 'good' gaskets to use? Any risks of doing a new gasket that I should be aware of, such as issues with the valvetrain since the cams have to be removed to get to the bolts? Do heads need to be machined if there is no gasket issue now? I hope some of you experienced guys can chime in with thoughts, costs, pitfalls, advice, etc. Thanks in advance
