TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Nov 16, 2021 at 12:29 PM
    Hawk373
    Hawk373 Well-Known Member
    2012 TRD Sport DCLB
    DMZ, ADS, King, JFR, SOS, ECGS, LSK
    Ok, I guess I’m in somewhat uncharted territory.
    I have the choice of +1 or +2 on both the exhaust and intake. I’m going with supertech based off a local builder’s general advice.
    With past engine builds I’ve gone as big as the heads would allow, so I guess I’ll stick with that philosophy (based off past results). This engine is a much different animal than what I’ve dealt with before (pushrod two valve carbureted) and wasn’t sure if going too large was self defeating with a 4 valve OH setup.
    My R1 was 5 valve, but I just changed the cams and that was way way more than enough.
    Wish I ended up using the stroker crank, but after the Dustin JE Ultra piston fiasco I was over it.
  2. Nov 16, 2021 at 12:33 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    oh that would be a sexy setup.
    12TRDTacoma[OP] and Biscuits like this.
  3. Nov 16, 2021 at 1:33 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Mine are 1mm over. Intake and exhaust. Not sure if they can fit larger. Especially with cams and overlap.
    With the valves, you'll get a nice amount of flow potential.
    Heck. With just that build, it'd be good to get an N/A dyno....wink wink. Should there be time in your build for it. :D
  4. Nov 16, 2021 at 1:43 PM
    Hawk373
    2012 TRD Sport DCLB
    Rgr that
    edit: my dyno runs would suck with 35” tires though
  5. Nov 16, 2021 at 1:45 PM
    Hawk373
    2012 TRD Sport DCLB
    I do have a Dragy that gives some great real world very accurate data though.
  6. Nov 16, 2021 at 5:59 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    get some 285's for dyno time.
  7. Nov 16, 2021 at 6:03 PM
    nudavinci64
    Robert
    I also Almost held onto mine too. I may find a dyno that takes off the wheels to see. My tires will def kill all power
  8. Nov 16, 2021 at 6:33 PM
    Hawk373
    2012 TRD Sport DCLB
    That’s an idea, I forgot about the hub mounted style.
    nudavinci64[QUOTED] likes this.
  9. Nov 16, 2021 at 7:04 PM
    nudavinci64
    Robert
    Yah unless I source some spacers and smaller tires that’s my choice
    Hawk373[QUOTED] likes this.
  10. Nov 16, 2021 at 7:29 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Hey y'all I haz two questions. Do I need to run the double bearing pulley on the roush tensioner and can I run a stock size belt on a 2.8 pulley with the roush tensioner?
  11. Nov 16, 2021 at 7:40 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    You can run the OE pulley on the Roush tensioner and you can run the stock length belt on the 2.8. I recommend the RPM belt though if you do so. The construction of it allows the belt to last a SUPER long time in comparison to the OE offering.
  12. Nov 16, 2021 at 7:42 PM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Cool. Looks like I'll just get a new belt and have the old one as a spare.
  13. Nov 16, 2021 at 8:54 PM
    nudavinci64
    Robert
    No need but it’s a nice pulley. that’s what I’m running with the RPM that @12TRDTacoma noted. Roush, double roller and RPM
    12TRDTacoma[OP] likes this.
  14. Nov 16, 2021 at 9:16 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Agreed. It's worth the extra work needed to run it and I anticipate it to be the last part of the system that will need servicing.
  15. Nov 17, 2021 at 6:03 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    you dont have to run that double bearing.
    but it may last much longer giving peace of mind.
  16. Nov 17, 2021 at 6:25 AM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    Wasn't part of the problem when running the stock bearing the belt is right on the edge of the roller so something has to be done to adjust it.
    I know mine was absolutely right on the edge of the roller until I replaced it with the double bearing roller. I didn't feel comfortable running it the way it was long term.
  17. Nov 17, 2021 at 9:31 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Well, it WAS a really narrow roller which was barely larger than the width of the belt itself, which is what prompted me to find that dual bearing roller, it was just more peace of mind as a whole for me and it seemed like it would provide a lot more stability over it's single bearing counterpart.
  18. Nov 17, 2021 at 9:59 AM
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    I'm curious if the 38/32 valves from the roller cam GR and UR engines could be modified to work. The intake valve is only 1mm longer in the stem... the exhaust is a little over 3mm, but it appears as though the extra length is all contained in the tip. The Lexus IS F 2UR-GSE Titanium intake valves, and high nickel Stainless exhaust valves, are an absolute bargain.
  19. Nov 17, 2021 at 10:27 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Would need to get one in hand to measure and compare. The tops can always be ground down. Should the retainer reliefs be in the same locations.
  20. Nov 17, 2021 at 10:34 AM
    Jowett
    Brian
    North Adams, MA
    I can give you any measurements you want...
    rheath08 likes this.
