TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Nov 18, 2021 at 6:04 PM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    I got the same one.
  2. Nov 18, 2021 at 6:21 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    can
    cant beat that for the money. definate contender!
  3. Nov 18, 2021 at 6:31 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Gonna have to buy one of these thanks for the recommendation! The dang fan always gets in the way of my ratchet too
  4. Nov 18, 2021 at 6:34 PM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    You just attach the small flat extension so it sticks out the the right of the tensioner and then attach the long part to that and flex away!
    Simple basic tool that works.
  5. Nov 18, 2021 at 8:15 PM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    jamesepoop and TodayWasTHeDaY like this.
  6. Nov 18, 2021 at 8:21 PM
    TodayWasTHeDaY
    Russ
    Calgary
    JuanitoBonito likes this.
  7. Nov 18, 2021 at 8:32 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    You just have to break the HF ones in the first 90 days and it's like the 1st gen owners who love the "lifetime warranty" parts store CV axles… Break it, swap it out… repeat.
    TodayWasTHeDaY likes this.
  8. Nov 18, 2021 at 11:59 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    first time i used a breaker bar but the last time when i had to swap that's what i used and based on feedback you can swap the belt using the gearwrench one from the side. I second this! I picked it up based on your feedback too @12TRDTacoma
  9. Nov 19, 2021 at 12:02 AM
    nudavinci64
    Robert
  10. Nov 19, 2021 at 12:28 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    That style tool is what the professionals in shops use for the tensioners that are located in tight confines. It's perfect for our style application and the guys using them should run into no problems using them. :thumbsup:
  11. Nov 19, 2021 at 4:31 AM
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    Anyone have a persistent issue with the fuel filter leaking?
  12. Nov 19, 2021 at 4:50 AM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Which fuel filter? The hose or the filter itself.
  13. Nov 19, 2021 at 5:18 AM
    Biscuits
    Might be from the hose on the upstream side.
  14. Nov 19, 2021 at 5:30 AM
    Biscuits
    But this is the second time in as many years. Previous filter was the URD/NAPA filter and now it's the K&N filter. Cut some of the hose too when installing the K&N filter to have a fresh connection. Maybe the worm clamp needs to be re-tightened but this is nonetheless worrying.
  15. Nov 19, 2021 at 5:57 AM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Can try this but you'll need to change out/modify your hose
    https://www.summitracing.com/parts/vpe-16886
    Or go to a fst or i.d. style fuel filter.
  16. Nov 19, 2021 at 6:06 AM
    Biscuits
    I need to do something different because the status quo isn't working.
  17. Nov 19, 2021 at 8:48 AM
    Biscuits
    I was wrong. Leak was on the downstream side. Tightened the worm clamps and the leak disappeared. Assuming I need to find a better way to secure the fuel filter from moving around. It's just secured to another line with zip ties.
  18. Nov 19, 2021 at 10:10 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    People still run those? :confused:
    Biscuits[QUOTED] likes this.
  19. Nov 19, 2021 at 10:14 AM
    Biscuits
    Yes?
  20. Nov 19, 2021 at 10:22 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I know I know. I was just being dumb. :D
