TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Dec 11, 2021 at 6:25 PM
    smelly621
    smelly621 Well-Known Member
    SF Bay Area
    2011 AC TRDOR 6MT
    It's DLX son!
    We've been down this road before. Tons of premium down in Baja. Can't recall a pemex that didn't have it last trip, and there are more gas stations and than ever. All the snow birds pulling trailers and monster slide in campers get thirsty.
    12TRDTacoma[OP] and TacoJova like this.
  2. Dec 11, 2021 at 6:43 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    I’m saying a TRD tune for 455 injectors will run rich with a S/C equipped engine sans S/C belt. Even in causal driving situations
  3. Dec 11, 2021 at 6:46 PM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    That's not correct.
    Athlaos and 12TRDTacoma[OP] like this.
  4. Dec 11, 2021 at 6:53 PM
    TRON
    Well in my experience when my S/C belt broke on the TRD tune…. Driving home gingerly was no fun. My AFRs were hitting 9 even though I was barely giving it the gas pedal. And the engine would definitely bog down at any speed over 40/50 mph.
    To be clear. The engine definitely ran right at idle and it would creep along at very slow speeds fine. But nothing was right keeping up with normal traffic speed from my experience
  5. Dec 11, 2021 at 7:01 PM
    JustDSM
    Justin
    Ogden, UT
    The ECU in our application is strictly airflow based. The ECU doesn't know whether there's a supercharger, turbocharger or not installed.
    The airflow model (MAF Calibration) defines the amount of air entering the engine, the fuel model (injector calibration data) defines the flow rate of the injector for its pulse width calculation. The closed loop AFR is hard coded in the ECU (14.6) and regardless of what method of induction you have, it's going to calculate the appropriate pulse width based on the airflow and fuel models to achieve the target stoich point.
    When the ECU knows the airflow and you have a solid airflow model, good injector data, the truck will run 100% regardless of what aspiration you have.
    I cannot speak to what you experienced, but I am confident there was something more at play than a broken belt. Was this by chance on the UCON/or APR variant? If so, that would explain things.
    (EDIT)
    I should further clarify. Though I said the engine will run 100%, that's not to imply it'll feel like a N/A engine without the S/C installed. I mean that in the sense that the MAF calibration and injector calibration data will allow the truck to target appropriate injector pulse widths to achieve targeted closed loop AFR's.
    The engine will be a bit of a dog, as you have a rotor pack acting as a restriction to the intake tract. It'll feel like a dog sure. But the fueling portion will be ok.
    If you do experience richer than stoich AFR's with a belt removed, it's likely due to the fact you're using more throttle to overcome the induction restriction of the rotor pack. This could potentially put the truck into Power Enrichment (Open Loop) fueling which targets much richer mixtures. Or, if you're into the throttle heavy for a sustained duration you could enter COT enrichment (catalyst overtemp enrichment). Which is another form of PE or Open Loop fueling.
    But the point remains, the way the ECU calculates the injector pulse width is based off airflow alone, regardless of what induction type you have fitted to the vehicle.
  6. Dec 11, 2021 at 7:15 PM
    TRON
    Pretty sure TRD tune but maybe HPtune. Regardless, definitely 455s. Once I got a new S/C belt installed everything was good to go.
    But like I edited my last post. Yes the engine would idle perfectly fine and even very slowly drive okay. Like 25 mph slow. But driving near or over 50 mph in 6 gear was bogging like crazy. And AFRs were 8-9s
  7. Dec 11, 2021 at 7:17 PM
    JustDSM
    Justin
    Ogden, UT
    I made an edit to my post to provide some clarity/further explanation which may explain your observation.
  8. Dec 11, 2021 at 7:50 PM
    TRON
    Good point! Makes sense the rotor pack blocks the air flow.
  9. Dec 11, 2021 at 9:48 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    i broke a belt and drove for a day on it till i got a new one and it just felt like driving around with out ever going into boost. thats with 660 injectors and UCON. pretty sure i even got on the interstate for a short period of time. this was like 8/9 years ago tho.
    I just wanted to add i had 93 in the tank. with 87 yeah might be some issues with that even without the supercharger making the boosts
  10. Dec 12, 2021 at 8:50 AM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    maybe elevation has an effect on that. when i broke a belt i went 10+ miles on the freeway fine. had zero passing power though. but made it to a place i could lace up a replacement. im at near c-level too.
    JustDSM likes this.
  11. Dec 12, 2021 at 1:50 PM
    lawless
    lawless the rent is too damn high
    Lawson
    San Jose, CA
    2012 dcsb mgm sc
    i empty my catch can about every 5,000 miles and this time there was 3 to 4 times the typical amount of oil. there seems to be quite a bit of fuel in the oil.
    i am hoping there is a solvable PCV issue and not something more sinister going on here. so, where is the PCV on a SC Tacoma? is this it?
  12. Dec 12, 2021 at 2:06 PM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    Yes
    12TRDTacoma[OP] likes this.
  13. Dec 12, 2021 at 2:17 PM
    lawless
    Lawson
    San Jose, CA
    2012 dcsb mgm sc
    thank you. looks like i'm taking the blower off to get in there. SC mileage is 51,793.
    i've got 5/16 hose on the PCV and SC. it's too small for the SC barb so i'm thinking 3/8 will be a good replacement.
  14. Dec 13, 2021 at 2:55 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
  15. Dec 13, 2021 at 3:42 PM
    scootter82
    scootter82 Well-Known Member
    Aurora, CO
  16. Dec 13, 2021 at 3:48 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    A lot of hotness going on in those photos gents.
    scootter82 and zippsub9 like this.
  17. Dec 13, 2021 at 4:14 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    FIFY
  18. Dec 13, 2021 at 5:06 PM
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
  19. Dec 13, 2021 at 8:16 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
  20. Dec 13, 2021 at 8:22 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    had no idea that was a thing.:frusty:
    12TRDTacoma[OP] and Norton like this.
