TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Dec 23, 2021 at 5:18 AM
    IvanhoeTaco
    IvanhoeTaco Well-Known Member
    Eastern NC
    2005 Supercharged Converted Prerunner
    Total Chaos 3.5 LT, King Coilovers, 35x11.5r17 on Falcon T2, ADV 4 inch fiberglass, 4.88 gears, FJ cruiser transfer case, 4 runner front diff, Cab mount relocate, archive hangers, shackles, king 2.5x14 rear shocks, icon rxt leaf springs, king hydro bumps
    Asking because im sire with tax and everything is close to 7000$
  2. Dec 23, 2021 at 6:20 AM
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
    Alternative method that might be in that thread but I got a pigtail from Stinger Alternators a while ago that does this but in line direct from Alt. Looks like he has a partner or alt site now for these. There was a group buy thread also for more information https://voltageboostmods.com/
  3. Dec 23, 2021 at 6:48 AM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    I run full synthetic oil... were you running conventional in the XP filter?
    nudavinci64 likes this.
  4. Dec 23, 2021 at 7:34 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Little late here.. and I'm sure you've got all the info needed.. but just wanted to give some feedback as well. I'm in Phoenix as well with pretty much the exact same setup.. even the IPT kit (you're going to love it, whole other animal). I noticed the drop in PSI when I fully opened up the exhaust like you and I sit right there at 7 PSI myself.
    Curious where you're going for the Hub Dyno.. I'd be interested as well. I've never dyno'd the truck.
    overlanderaz[QUOTED] likes this.
  5. Dec 23, 2021 at 8:40 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    You are running 0-20? I run 5-30 dino oil but I've been considering switching out to 10-30 just for peace of mind.
  6. Dec 23, 2021 at 8:40 AM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Would any of you guys have a want/need for the factory manifolds (or just the cats) off my 2015? They have about 30K on them and are in mint condition.
    rheath08 and 12TRDTacoma[OP] like this.
  7. Dec 23, 2021 at 8:40 AM
    overlanderaz
    overlanderaz Well-Known Member
    Phoenix
    2013 SR5 4x4 SC'd
    35" tires, 6"lift, Volant cold air intake, Magnuson SC, 2.4" pulley, AEM Methanol Injection, AEM 340LP, Cam Exhaust Gears, HD-SKO Rock Sliders, ARB compressor, RTT, LED lighting, ARB Lockers, and 4.56 gears.
    I have seen you on the forums and have kept an eye out for your truck, as I am in Awhatukee....
    Are you running meth as well? Seemed like a no-brainer to add for the summer out here, but at 6-7 psi it seems unnecessary.
    I did go ahead and order the 2.4" pulley, the next RPM belt size down, and the MAF....cause why not...I should be able to switch setups back and forth in an hour (not that I will be hot swaping). However, options are good and what's another $250 at this point.
    I setup an appointment at Xact Dyno in Tempe for late Jan, so I can install IPT first . It's a hub dyno, so no worries with big tire shenanigans.
    I was in turmoil between remote and local, as the remote community knows the trucks like no one else....but the dyno is the dyno. Since we live in the city and Dynos are so accessible, it just made sense. However, I am not discrediting the remote folks, as they do amazing work.
  8. Dec 23, 2021 at 8:53 AM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Is the XP better if your running synthetic which I assume most of us are? I have been running 5w30 Mobil 1 for most of its life and recently switched to 5w30 Amsoil. Always used factory filters
  9. Dec 23, 2021 at 8:58 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    How long are you going between intervals?
    I would still stick to the standard version. As the XP is made for use with thinner oils and does not capture as much junk as the standard version will.
  10. Dec 23, 2021 at 9:08 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    I wonder if you should jump up to the larger diameter FJ intake and MAF while you’re at it…
  11. Dec 23, 2021 at 9:21 AM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    I actually thought of sourcing a set of manifolds with stock cats Incase I ever needed to switch back
    JustDSM[QUOTED] likes this.
  12. Dec 23, 2021 at 9:31 AM
    overlanderaz
    Phoenix
    2013 SR5 4x4 SC'd
    Hey Jason,
    Thanks for the reply....
    Bigger MAF tube....Idk? Maybe?
    I just ordered the $100 MAF sensor that was added to page one, because it seemed fairly cheap (relatively) and I ordered it from Amazon (I had GC credit and easy returns)....this way I can put in the 2.4" pulley and install the MAF if I throw a code....and not install MAF if I don't.
    I havnt spent as much time reading up on MAF upgrades as other upgrades, but my impression was its based on need (code throwing). However, I assume there is a flow threshold for stock TB and MAF tube...but its got to be pretty high, no?
    I am not sure if the MAF tube is being replaced by guys running 2.1" pulleys or what....but, I assume my airflow will kick to the next restriction fairly quickly, but thats an assumption.
  13. Dec 23, 2021 at 10:01 AM
    JustDSM
    Justin
    Ogden, UT
    There's a lot more to using that MAF than just putting it "in".
    And just FYI, we also offer remote calibration services while you're on the dyno. That way you can take advantage of our knowledge and experience of the platform and get your numbers. Also, keep in mind there's a lot more to the tuning we do besides what is shown on a dyno (WOT, and RPM sweep from 2K-5.5K). Our tunes are specifically calibrated to provide more low end/midrange in part throttle conditions where most folks spend the majority of their time driving, not just optimizing a very specific operating area that makes for a line printed on paper.
  14. Dec 23, 2021 at 10:02 AM
    JustDSM
    Justin
    Ogden, UT
    If you want a set, I'll get you hooked up right as one of my preferred customers :)
  15. Dec 23, 2021 at 10:37 AM
    nudavinci64
    Robert
    makes sense. I have not seen a need for it just yet. I try to keep it at 5k or so. My oil end up super dark and I can feel it. the 0-3k is the sweet spot but that's way too pricy to do that often.
  16. Dec 23, 2021 at 10:37 AM
    nudavinci64
    Robert
    If your MAF is maxing out the bigger TRD FJ tube is the way to go.
  17. Dec 23, 2021 at 10:48 AM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    If anyone needs that Subi MAF from page 1 let me know. I have one that’s been on my truck for a month and will be coming out very shortly. I’ll be switching back to the stock maf.
  18. Dec 23, 2021 at 11:13 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You know I feel the same way myself. 0- 3K tends to be the sweet spot as well. Anything over is a lot for it and I start to feel it as well, there is this sluggish sort of feeling when driving. My oil comes out pretty dark as well, but I usually wait 5K.
    Why are you switching back?
  19. Dec 23, 2021 at 11:15 AM
    TacoJova
    TacoJova Well-Known Member
    Central Oregon
    21 Ram TRX Sold 2015 White DCSB Offroad
    Supercharger Hybrid audio stage 3 and stage 2 rear with 2 image Dynamics IDQ10's and alpine amps Bilstein 5100 with OME 887 Dakars and Icon 2.0 in the rear URD SPEC U Headers URD Y Pipe Borla muffler 18" Magnaflow Resonator Morimoto fogs
    I sold mine to some recycling place in New York for like 400
    scootter82 and JustDSM[QUOTED] like this.
  20. Dec 23, 2021 at 11:16 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Wow. Thats an impressive amount of money for the OE manifolds, junked out at that.
