TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jan 3, 2022 at 7:33 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    also, what sucked was doing this shit out in the street on asphalt. having a second person helped too. so if you can grab an extra pair of hands, id suggest it.
    BassAckwards[QUOTED] likes this.
  2. Jan 3, 2022 at 7:55 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    It sure seems so! Which stage are you running and how has it been for you in the longer term?
    Yeah i had to fight mine a little going back in. Got it out by myself but had to have another hand to lift on the front of the motor a little bit to get things to line up.
    That sounds like a real pita. I was doing it on a concrete slab, but asphalt sounds way worse
  3. Jan 3, 2022 at 8:04 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    I'm running the stage 3+ and it has been amazing. Break in took a hot minute, lots of chattering, but now its smooth and grabs like a good clutch should.
  4. Jan 3, 2022 at 10:30 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    yah I’m deciding if going with cast or flow formed 19-21lbs works or if it’s worth it to go big on something like TE’s @Lucario Runner as I also need a lower offset. +2 LT and -38 is going to be super wide for places I take the truck.
    I have been running Willwood Aero-6 brake setup for a couple years it’s a nice but switching over to Stoptech st60 front (2 piece rotors) and rear stoptech st40. I have really been considering those m/t’s @XPOTRPR as well. I like the idea of load range D and true to size.
  5. Jan 4, 2022 at 6:26 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    That's why I stayed away from -38's too. I had -12 prior to the 35s.. and with my research found that -25 might be the perfect balance for 35s.. and for the most part.. it really is.
    So you're not running the actual Wilwood BBK then right? Because mine are 2 piece rotors. Like I said.. they are light! The D rating was the biggest factor for sure though.
  6. Jan 4, 2022 at 8:32 AM
    nudavinci64
    Robert
    Not the one from Willwood. Higher-end calipers but uses 338 TR4 rotor size. I had not seen the Wilwood one at the time. And being able to use off the shelf as needed was a nice add for emergency sake but now I am thinking more performance and weight.
  7. Jan 4, 2022 at 8:43 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    ahh.. I still highly recommend the Wilwood BBK I'm running.
  8. Jan 4, 2022 at 8:49 AM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Me too, the Wilwood bbk is nice. You do need 17’s to run them though. I mention this because you are looking at wheels. @nudavinci64
  9. Jan 4, 2022 at 8:59 AM
    nudavinci64
    Robert
    I have been running TR4 and the Wilwood setup I have now that both run 338mm rotors and require 17's so no issue there.
    Honestly all are great setups with success on each. In some discussions the Stoptech's are supposed to dissipate heat better and heard some potential issues with Wilwood rotors and decided to go with stoptech. Started when I decided to not sell my rear disc conversion and add the BBK calipers in the rear. I was not able to get matching wilwood calipers so decided to stoptech's would be the new change.
    ill find a pic of my current setup.
    JuanitoBonito[QUOTED] likes this.
  10. Jan 4, 2022 at 9:12 AM
    scootter82
    scootter82 Well-Known Member
    Aurora, CO
    there any light weight options for the 16"? I have the stoptech 6 piston up front, but regular trd rotors I think
    Norton likes this.
  11. Jan 4, 2022 at 9:27 AM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    The SCS F5 with 0 offset is just under 19lbs.
  12. Jan 4, 2022 at 10:00 AM
    nudavinci64
    Robert
    yah 18 and change on the 16 and 21 on the 17. not bad for the price.
  13. Jan 4, 2022 at 10:08 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
  14. Jan 4, 2022 at 10:33 AM
    scootter82
    Aurora, CO
    Sorry, I meant lightweight rotors like the 2 piece, but for a 16" rim. Love my baja rims and no plans on ever changing them :)
  15. Jan 4, 2022 at 10:35 AM
    nudavinci64
    Robert
    Stoptech and Willwood both have 2 piece rotor setups for you.
    Norton and scootter82[QUOTED] like this.
  16. Jan 4, 2022 at 1:47 PM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    While on the subject of light weight wheels- What have y'all found for light weight rubber that still packs some offroad performance? In my research the goodyear duratracs are hard to beat for offroad performance and weight but f@@k do they hum.
    rheath08 likes this.
  17. Jan 4, 2022 at 2:13 PM
    JasonLee
    15 TRD OffRoad
    It’s relative to your conditions and terrain, but these KO2s in load range C are quiet and have been great for me on my 1st gen and now the 2nd gen.
    Norton, BenMara and kasnerd like this.
  18. Jan 4, 2022 at 2:20 PM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    I know they get a lot of hate, and while I freely admit they're not the end-all-be-all, the KO2 has been good to me. I really like the C Load offerings up to 37".
  19. Jan 4, 2022 at 2:42 PM
    nudavinci64
    Robert
    My only big complaint on the K02 was mud and wet performance. My truck slid all over the place but aside from that they drove nice and wore well.
  20. Jan 4, 2022 at 2:43 PM
    nudavinci64
    Robert
    I added a bunch from Summit, SCS, Volk and Rays on there. Ill add some more later as I was starting to do the same
    JasonLee[QUOTED] likes this.
